Old Tue, Nov-20-2007, 03:58:39 AM   #1
KalizeM3
KalizeM3's Avatar
Reputation: 0 KalizeM3 is on a distinguished road
Default koni shocks...
I'm interested in getting a set of Koni shocks...I just wanted to know if they will lower the car even more once i get them installed?
right now i'm using just H&R springs with the stock shocks (I know..shouldn't do that)
thanks in advance.
2006 BMW 330i Sport SDN (E90) | Spark Graph | DKTA Leather | Steptronic | ZSP | ZPP | ZCP | NO Nav
2004 BMW ///M3 CPE (E46) | Jet Black | SMG | PDC | HK System | Sunroof | 19" OEM Wheels | 19" OEM ZCP Wheels | ZPP | HID | NO Nav | Heated Seats | Homelink | V-CSL Front Bumper | V-CSL Bootlid | V-CSL Diffuser | Keyhole delete | Depo Smoked Corners | Blacked Out Kidney Grille | Blacked Out Side Vents | Bimmain SMG Paddle Shifters | ///M Pedals | ///M White Face Gauges | Hartge E-brake Handle | PC Angel Eyes | CP Rasp Pipe | K&N Intake System | AA Gen 4 Exhaust | TM Front Camber Kit | KW Variants 2's | Brembo Front BBK 4 pot 355mm
Jump to top KalizeM3 is offline   Reply With Quote
Old Tue, Nov-20-2007, 04:08:27 AM   #2
dreaM3
dreaM3's Avatar
Reputation: 0 dreaM3 is on a distinguished road
you should be able to add another 3/4"-1" lower to your springs. There are some slots on the shocks to place the rings to which the cup looking thing that holds the springs are placed. They also have a purpose, like normal to sport. The lower the rings the stiffer the ride.
Jump to top dreaM3 is offline   Reply With Quote
Old Tue, Nov-20-2007, 04:11:33 AM   #3
DeadSailor
lemonde.fr
DeadSailor's Avatar
Reputation: 0 DeadSailor is on a distinguished road
depends what springs. h&r has sport and race which give diff heights.
what shocks are you getting?? have you looked at the fsd's? theyll fit a e46m3
http://www.koni-na.com/fsd.cfm
Q:Why is Snoop Dogg such a good sculptor?
A:Because he knows how to Chizzle
Jump to top DeadSailor is offline   Reply With Quote
Old Wed, Nov-21-2007, 12:26:34 AM   #4
KalizeM3
KalizeM3's Avatar
considering the yellows but am looking into the FSD's....anyone know which are better
I'm using the H&R sport springs
my car is mostly a DD...not for the track
Old Wed, Nov-21-2007, 12:32:48 AM   #5
Boomers-Journal
Boomer
Reputation: 0 Boomers-Journal is on a distinguished road
I don't see were the FSD's are available for the M3. Site just brings up the yellows.
Jump to top Boomers-Journal is offline   Reply With Quote
Old Wed, Nov-21-2007, 01:31:03 AM   #6
PB
PB's Avatar
Reputation: 0 PB is on a distinguished road
Yellows are what is available, I got H+R sport first and then Koni shocks later, the shocks are great but lowering springs are only OK, they feel unresponsive, I will sell my stuff and buy coilovers. I think you should do the same and then you have height adjustment too.
Jump to top PB is offline   Reply With Quote
Old Wed, Nov-21-2007, 01:33:52 AM   #7
PB
PB's Avatar
Yellows are what is available, I got H+R sport first and then Koni shocks, the shocks are great but they make you realize the springs are not responsive, I will sell my stuff and buy coilovers, you might do the same and then have height adjustment also.
Old Wed, Nov-21-2007, 02:16:32 AM   #8
fourtailpipes
Ch-Check It Out
Reputation: 0 fourtailpipes is on a distinguished road
lower ride does not yield stiffer springrates
goodbye e46 m3. it's been fun. everything's for sale. see my posts.
hello 135i.
My Pictures
Jump to top fourtailpipes is offline   Reply With Quote
Old Wed, Nov-21-2007, 02:49:36 PM   #9
Need4Spd
Need4Spd's Avatar
Reputation: 578 Need4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond repute
I don't think the FSDs for regular e46s will fit. As between FSDs and yellows, I'm on the fence. I have FSDs in my M5 and yellows in my M3 (since I didn't have a choice). The FSDs seem set stiffer than you would set the yellows for street driving and make up for it by having that FSD valve that reacts softer for sharp bumps. But undulating roads make the car go up and down to follow the contours of the road more than a car with yellows set on a softer setting. My M3 will soak up the undulations (they're set a 1/4 turn from full soft) but the M5 will follow them. The M5 still rides relatively well and handles great, however. IMHO, the yellows are a must to tame the buckboard like ride of the M3, but that's just personal preference. I don't track my M3, and it's a convertible.
Past car: '05 M3 'vert, 6MT, custom 18" RAC RG63 Hyperblack monolites, Continental Extreme DW 245/40 and 275/35, Nav, HK, BT, Euro rotors, Custom Performance Rasp Terminator (2nd Gen.), Silverline DICE iPod adapter, EAS Aurora 60 LED Angel Eyes, "-CDV," "free & easy" camber mod (-1.7 degrees), Koni S/A shocks, Rogue Engineering RSMs and transmission mounts, Bimmerworld silicone intake boot, spacesaver spare from LeatherZ, updated OEM RTABS
'11 Jaguar XFR
Jump to top Need4Spd is offline   Reply With Quote
Old Wed, Nov-21-2007, 03:26:32 PM   #10
modthispny
modthispny's Avatar
Reputation: 0 modthispny is on a distinguished road
im also very curious to see if koni yellows will give an additional drop to my eibach pro-kit..anybody know?
Jump to top modthispny is offline   Reply With Quote
koni shocks bmrlvr E46 M3 (2001-2006) 22 Wed, Oct-17-2007 02:13:34 AM
Any other shocks out there besides Koni domino_z E46 M3 (2001-2006) 0 Sun, Jun-17-2007 08:50:31 AM
Koni shocks HELP !!!!! 2003blackbmwm3 E46 M3 (2001-2006) 12 Sat, Mar-10-2007 03:59:17 PM
Koni shocks wellcraft E36 M3 (1992-1999) 27 Sun, Jul-31-2005 02:45:44 AM
KONI SPORT SHOCKS externally damping adjustable shocks 96BmwCosmosM3 E36 M3 (1992-1999) 0 Wed, Jun-09-2004 01:23:31 PM
Discussing koni shocks... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
