Old Sun, Aug-26-2007, 06:54:32 PM   #1
kajtek123
Reputation: 0 kajtek123 is on a distinguished road
Default e36 overheating
hi
my e36 started to overheat yesterday. replaced water pump, thermostat, radiator 10k ago. also replaced new thermostat again yesterday-still overheats. the air comes out cool from vents when set to max temp. also, the electric fan doesn't turn on when temp is 3/4 high but it does start when the A/C is on.
any ideas
thanks
Jump to top kajtek123 is offline   Reply With Quote
Old Sun, Aug-26-2007, 06:57:45 PM   #2
RoodAwakening
The Curmudgeon Cop
RoodAwakening's Avatar
Reputation: 0 RoodAwakening is on a distinguished road
Originally Posted by kajtek123 View Post
hi
any ideas
thanks
Defective fan clutch or motor.
"The descent to hell is easy. The gates stand open day and night. But to reclimb the slope and escape to the upper air: This is labor."
--Virgil, Aeneid, Book 6
Rob
1999 BMW ///M3
Jump to top RoodAwakening is offline   Reply With Quote
Old Mon, Aug-27-2007, 07:47:17 PM   #3
thedood
Can't touch this
Reputation: 0 thedood is on a distinguished road
+1...
Jump to top thedood is offline   Reply With Quote
Old Mon, Aug-27-2007, 08:00:38 PM   #4
Cheeze
Cheeze's Avatar
Reputation: 0 Cheeze is a jewel in the rough
I'm assuming you've checked the coolant level as well. If you've recently replaced/added a decent quantity of coolant you may need to do a proper bleed of the system to get the coolant to circulate properly. If not, I agree with what the others have said.
Jump to top Cheeze is offline   Reply With Quote
Old Mon, Aug-27-2007, 08:02:05 PM   #5
Wrong...
There is a cooling circulation issue, either water pump or improper bleeding. Stating that the air blows out cold when set to max temp is an immediate sign.
Try rebleeding the system. This time park the car on an gentle incline. Fill it up with water/coolant and squeeze the lower and upper rad hoses to help pump the water around. Once the system is topped off, start the car and wait for it to get to middle temp. Set the heater to full heat, and full fan. Rev the car to 2.5k and hold it for a min to get the water circulating into the block and heater core. Keep an eye on temp, dont let the car overheat. Once you feel heat coming out of the vents you know you've got water in the entire system, it's just a matter of topping off the reservoir and cracking the bleed screw to get every last air bubble out.
As for the electric fan not coming on, check your connections, and final stage unit.
Old Mon, Aug-27-2007, 10:03:30 PM   #6
puopolvj
puopolvj's Avatar
Reputation: 0 puopolvj is on a distinguished road
^+1. You have air trapped in the system. This might explain coolant not reaching the heater core.
2000 528it/5/M ed.
Jump to top puopolvj is offline   Reply With Quote
Old Mon, Aug-27-2007, 10:44:22 PM   #7
FAST98
FAST98's Avatar
Reputation: 0 FAST98 is on a distinguished road
stupid ?'s but do you have the heat selector on the hot side? It is the dial located just below the center vent on the left. it has nothing to do with the car overheating but may explain why there is no heat.
+1 on the air thing although it seems strange that it would start doing this after 10k miles and not right away..
As far as the fan not comming on it may be a bad temp sensor. i belive that there are two on these cars.
/// 200k club member
270rwhp 257trq old 1/4 record 13.237 @103.3mph w/1.8 60' New record 13.01 @ 107.231 w/1.64 60' on slicks no nitrous!
UUC Cat back UUC Evo 3 SSK w/DSSR Dinan CAI Dinan BBTB Dinan sway bars Worthless Dinan strut bar Custom tune M50 manifold Samco 3.5" to 3" ASC delete boot Custom ported and polished head with 1mm oversized valves 3.91lsd from diffsonline Kick a$$ stereo(focal components) Custom high flow center section 6 port DI NX wet kit AA DSB and way to much of my time
Jump to top FAST98 is offline   Reply With Quote
Old Thu, Aug-30-2007, 02:01:55 AM   #8
kajtek123
ok guys, the water pump i installed (plastic one) broke so that only the shaft was spinning. put a new metal one this time-learned my lesson
Old Thu, Aug-30-2007, 02:23:12 AM   #9
PhYrE
Mmmmm-3
PhYrE's Avatar
Reputation: 0 PhYrE is a glorious beacon of lightPhYrE is a glorious beacon of light
Composite is the way to go. Metal has bearing failures. Plastic shatters. Composite is the only ones you can get these days from BMW. I assume you had a composite one.
-M
2008 BMW M3 Coupe (White on Fox Red)
CF everything / Lowering springs / EDC / Tint
AA Short Shifter
SOLD - 1997 BMW M3 Coupe (Estoril Blue]
VFE Supercharger Stage 1
Bilstein Sport Shocks/Struts
Euro-M3 Springs
Two-Piece Euro Rotors
JVC KD-AR5500 Headunit
Euro Headlights w/ TSX Projector Retrofit and HIDs
VDO Gauges
Harmon Kardon Amplifier retrofit
18-button OBC conversion retrofit
BMW Euro (clear) corners, tails, sidemarkers
ROH RT wheels / (f) 245/40/17 (r) 265/40/17 Toyo T1R
Jump to top PhYrE is offline   Reply With Quote
Overheating! lou123 E36 M3 (1992-1999) 37 Fri, Oct-03-2008 05:27:15 PM
odd e36 M3 overheating problem... ienjoydrifting Faults, Fixes and DIY 5 Thu, Jun-28-2007 04:58:17 PM
e36 race car overheating problem!!!!! the fello M3 Track: Racing and DE 3 Sun, Jan-07-2007 04:52:13 AM
overheating! please help! brentvelo E36 M3 (1992-1999) 6 Tue, Jun-27-2006 12:16:36 AM
Overheating 99M3Riverside E36 M3 (1992-1999) 20 Tue, May-30-2006 06:24:23 PM
Discussing e36 overheating in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
