Is the right passenger side headlight beam supposed to be higher than the left one?
Automotive Lighting Innovations
![]() Location: Oakland NJ
no, they should be even.
Caesar Rowinski - LIGHTWERKZ 2009 BMW M3 Sedan - Space Gray FS: PFC Pads |
I retrofitted Euro xenons maybe thats why the passenger side is higher. Anyone else know more about this?
#4 |
just realign them.
If your talking about the angle of the slope, then yes the passenger side is higher so you can get better visibility without blinding others.
#5 |
How high should it be?
#6 |
![]() Location: mill town
you should be able to adjust them the way you like...
apv2, k&n typhoon, aps tbe, fuel pump, gm solenoid, tmic and pro tune by jorge |
#7 |
![]() Location: Silicon Valley
At the same height as the headlight is from the ground?
There are knobs that kind of look like sprockets by the headlight under the hood. These are the inner ones. You can just spin it with your hand to adjust height. The outer ones adjust left and right, but if I remember correctly, you basically need a phillips for that so you won't mix them up.
12 Honda CBR 1000RR - Jet Black 09 Lexus GS350 - Sapphire Pearl/Black 04 M3 Coupe SMG - Jet Black/Black (sold) |
#8 |
at 25 feet it should be 2 inches lower then center of the projector.
#9 |
einpresstiefe
![]() Location: northern california
good to know.
#10 |
![]() Location: San Jose, Ca
now i just need to find a surface that's flat and has a wall 25 feet away
PM me for a Shim Kit |
| beam, headlight, uneven |
| Need Help! Low Beam Headlight Is Out! | Fabiolous10 | E46 M3 (2001-2006) | 16 | Sat, Apr-26-2008 10:00:49 PM |
| Headlight Armor Adds Motorcycle Headlight Kits to its Product Mix | HeadlightArmor | M3Forum Sponsor Announcements and Specials | 0 | Mon, Jun-11-2007 01:31:18 PM |
| Adjusting headlight beam | Twins | E36 M3 (1992-1999) | 8 | Sat, Feb-11-2006 06:39:20 AM |
| Headlight question. lo/hi beam/ innie or outtie | NYM3Jack | E36 M3 (1992-1999) | 3 | Sat, Jul-30-2005 12:48:24 PM |
| Low Beam HIDs are uneven | fritzdegner | E36 M3 (1992-1999) | 2 | Tue, May-31-2005 05:01:32 AM |
