Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted
Parts for Sale/Wanted Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods.
Old Wed, Jul-04-2007, 03:57:15 AM   #1
eshaun
RATEDM
eshaun's Avatar
Reputation: 0 eshaun is on a distinguished road
Default FS: SF - e46 M3 vividracing/ksport 36 Way Adjustable Coilovers
Ran these on my 04 M3 for roughly 4k miles over a period of 4 months or so - mostly daily commuting and fun weekend trips up in the twisties. Had them professionally installed and aligned and these really are an excellent value for the money. Decided to get them removed since I need the funds for other things more important.
Vivid Racing and Ksport collaberated on the development to bring these to market. Below is their description, along with photos of the like new condition of the actual coilovers and of my car and a buddies, both with identical ksport coilover setups.
Asking $825 or best offer...I dont need them collecting dust! Vivid Racing is selling them for $1050+tax, shipping etc...
Possible trade for new or close to new PS2's or T1-Rs in 235 or 245 Fr & 265 or 275 Rr
email or pm... shaungt2 AT gmail DOT com
http://www.vividracing.com/catalog/p...ducts_id/35712
Ksport Kontrol Pro Coilovers BMW E46 M3 00-05
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
-36-way adjustable dampening
-Made from high quality 6061 Aluminum with T6 for increased hardness
-Compression/Rebound adjustable
-Adjustable spring perch for height adjustment
-Adjustable body allowing maximum suspension travel
-Pillow Ball Top Mount w/ adjustable camber (not available for some models)
-Monotube High Pressure Design reduces oil leakage
-Electroplated body for protection from corrosion and rust
-One Year Limited Warranty
Incl. Front Pillow Ball Mount & Rear Top Mount...
|| www.eshaun.com ||
Jump to top eshaun is offline
Rate Seller View Rating
Old Wed, Jul-04-2007, 06:21:56 PM   #2
eshaun
RATEDM
eshaun's Avatar
not sure if i made this clear,
- Possible trade for new or close to new PS2's or T1-Rs in 235 or 245 Fr & 265 or 275 Rr.
- If you just have fronts or rears you're going to have to offer up some cash as well.
- Also may consider a complete set of oem 18s with plenty of rubber left (ps2, t1r only) + $250 cash
|| www.eshaun.com ||
Jump to top eshaun is offline   Reply With Quote
Old Sun, Jul-08-2007, 05:37:40 PM   #3
eshaun
RATEDM
eshaun's Avatar
still for sale, great deal on coilovers, $775 for local pickup in norcal!
|| www.eshaun.com ||
Old Sun, Jul-08-2007, 06:29:41 PM   #4
Ervin87
Ervin87's Avatar
Reputation: 0 Ervin87 is on a distinguished road
Bosnia and Herzegovina
How is the ride on these? How does it perform over stock?
I've heard that these are bouncy and not that great. You've had them on your car so you could best explain your opinion.
Thanks
EUROPROJEKTZ - NorCal Chapter
Ervin (Bay Area Detailer)
___________________
2002 SG M3
2000 B5 S4 Stage III
1989 E30 325i
2004 MB M3 (sold)
Jump to top Ervin87 is offline   Reply With Quote
Old Mon, Jul-09-2007, 06:37:41 PM   #5
eshaun
RATEDM
eshaun's Avatar
Thanks
Overall I didnt have any negative experience with them. I had a track experienced mechanic take care of the install, someone I trust and pay to get the job done right the first time. Nothing against others or shops who have done the install themselves, but I'm willing to bet there were some minor nuances that had to be addressed by my installer (as is the case with any install more complicated than swapping out some grills or clear corners). I also had the car corner balanced during the alignment as well.
The ride quality was very similar to variety of other cars ive driven with pss9, ground control single adj, etc. Much less body roll and more confidence inspiring than stock. Far better than any M3 with just lowering springs. I did have upgraded sway bars on the car so it was substantially more stiff. The kit also comes with solid bushings on the endlinks which significantly boosts turn in response. If you're not looking for that track ready handling, turner motorsports modified endlinks and retaining stock sways will surely smooth things up.
Lastly remember that these folks are hitting the market with a product far below the costs of tckline, JIC competition, moton etc and some others out there. Do not expect that sort of outcome, but an excellent, ride, fitment, and fit and finish for 1k bmw e46 M3 coilover suspension...far better than any ebay or pieced together setups out there for those on a budget.
Hope that helps
|| www.eshaun.com ||
Old Mon, Jul-16-2007, 12:33:32 AM   #6
oshin02
Reputation: 0 oshin02 is on a distinguished road
How low can these go? and by any chance, do you have a pic of a car the the ride hieght set to the lowest with thses coilovers? Thanks!
-Oshin P.
Jump to top oshin02 is offline   Reply With Quote
Old Mon, Jul-16-2007, 02:00:04 AM   #7
BAV_M_PWR
BAV_M_PWR's Avatar
Reputation: 0 BAV_M_PWR has a reputation beyond reputeBAV_M_PWR has a reputation beyond reputeBAV_M_PWR has a reputation beyond repute
Not sure I understand your real intentions for selling these, but
check on Ebay for the PS2s. You can often find tires with
more than 60% tread life for like $80 + shipping. They are
usually off cars that were dealer trade-in or were leased.
They are repair-free and usually guaranteed by the seller.
Just a suggestion, AND you get to keep your coilovers
2003 JET BLACK ///M3 SMG
Originally Posted by //Ali View Post
What's lesson #2, oh Lord of Ridiculous Posts
Jump to top BAV_M_PWR is offline   Reply With Quote
GC double adjustable coilovers E46 M3 spankypokie Parts for Sale/Wanted 9 Mon, Feb-25-2008 04:59:17 PM
KSport Coilovers? ///M3_me E36 M3 (1992-1999) 6 Wed, May-23-2007 03:48:46 AM
Coilovers Ksport or Kw M3_il E46 M3 (2001-2006) 4 Thu, Apr-12-2007 06:09:00 PM
FS: Tckline Double adjustable E46 M3 coilovers edmo7 Parts for Sale/Wanted 18 Sun, Apr-01-2007 07:12:34 PM
TC Kline Single-Adjustable Coilovers for E46 sleepless Parts for Sale/Wanted 1 Tue, Jan-17-2006 08:31:23 PM
Discussing FS: SF - e46 M3 vividracing/ksport 36 Way Adjustable Coilovers in the Parts for Sale/Wanted Forum - Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
