Old Thu, Sep-06-2001, 11:14:00 PM   #1
Guest
Guest
Posts: n/a
Default aftermarket xenons
my m3 didnt come with xenons, and i wanted them. anyone know of any options other than getting them installed at the dealer?
Jump to top   Reply With Quote
Old Sun, Sep-09-2001, 05:46:00 PM   #2
Frank
Frank's Avatar
Reputation: 0 Frank is on a distinguished road
I think you can install the bulbs which look like Xenons (white light) or you can convert to Xenons for your low beams.
Here are a couple of links at Bavauto.com
Go to the "Exterior" link on the left menu...there's two types HID Lighting which are actual Xenons...and PIAA Lighting which are non xenons.
Im sure there's others on the market as well...thought I would share these to get you started.
There's a list of aftermarket manufacturers in our BMW Web Resources section.
Good luck!
Jump to top Frank is offline   Reply With Quote
Old Sun, Sep-30-2001, 09:35:00 PM   #3
NickyBlack
NickyBlack's Avatar
Reputation: 0 NickyBlack is on a distinguished road
Greece
You can also try HIDS4LESS.Com
They seem to be pretty good too
Jump to top NickyBlack is offline   Reply With Quote
Aftermarket Xenons? ///bam3 E46 M3 (2001-2006) 11 Thu, May-24-2007 03:38:38 PM
Aftermarket Xenons for Non-Projector Headlights Taste the ///M! E46 M3 (2001-2006) 22 Wed, Feb-28-2007 04:05:03 PM
xenons? granulomatous E46 M3 (2001-2006) 11 Mon, Jun-06-2005 02:04:00 PM
xenons??? Rohit E46 M3 (2001-2006) 3 Fri, Apr-18-2003 03:39:45 AM
Xenons JohnnyRx E46 M3 (2001-2006) 5 Wed, Nov-06-2002 02:42:21 AM
Discussing aftermarket xenons in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
