Old Sat, Sep-16-2006, 03:05:36 AM   #1
m3 hal
Default Evans NPG+ Coolant
Has anyone changed over to the Evans NPG+ Coolant? I've heard nothing but good things about this stuff. A search didn't turn up anything.
Old Sat, Sep-16-2006, 04:35:05 AM   #2
ZeroG
ZeroG's Avatar
Reputation: 0 ZeroG is on a distinguished road
Never heard of it. For me it has always been BMW Blue
Jump to top ZeroG is offline   Reply With Quote
Old Mon, Sep-18-2006, 02:54:23 PM   #3
m3 hal
Anybody? Is this stuff safe to use with the S54?
Old Mon, Sep-18-2006, 09:23:14 PM   #4
Darian
Reputation: 0 Darian is on a distinguished road
Unless you Track the Car its pointless
Jump to top Darian is offline   Reply With Quote
Old Mon, Sep-18-2006, 09:40:22 PM   #5
Synthetic
Synthetic's Avatar
Reputation: 0 Synthetic is on a distinguished road
BMW OE fill and packaged coolant is supplied by Zerex. It's critical you use an HOAT chemistry with the BMWs or you will run into major problems. You will have no need for a different coolant unless you are full out tracking the car all the time; the technology works just fine. If the BMW coolant is too expensive (and it is) than buy Zerex G-05 chemistry as it is the same HOAT BMW uses, they just have it dyed Blue for differentiation.
E46 M3 - Steel Grey AA Stage 3 - SOLD
E36 328is - SOLD
E36 M3 - SOLD
E46 325i - Daily Driver - SOLD
E46 M3 - To Be Found...
My rep if anyone is curious:
http://www.m3forum.net/m3forum/showthread.php?t=153194
Jump to top Synthetic is offline   Reply With Quote
Old Mon, Sep-18-2006, 09:44:20 PM   #6
m3 hal
thanks for the replies; factory coolant it is
Old Sat, Jan-10-2009, 05:31:39 AM   #7
WRXEATR
The Frugal and Outspoken One
Reputation: 0 WRXEATR is on a distinguished road
I know this is an old thread, but im going to have to disagree with the previous posters. I've been running evans NPG in my e36 m3 and am very satisfied. Not only does it allow your cooling system to run cooler, it also lets it operate at lower PSI, decreasing the stress on all of the hoses/clamps/radiator necks ETC. I highly recommend this stuff to anyone considering it.
Jump to top WRXEATR is offline   Reply With Quote
Old Sat, Jan-10-2009, 06:49:11 AM   #8
deilenberger
deilenberger's Avatar
Evans NPG is nothing but 100% propylene-glycol http://en.wikipedia.org/wiki/Propylene_glycol sold at a silly price point. You can buy the same chemical without the pretty coloring from any chemical supply house for about $6/gallon. It's used as an additive in all sorts of things mostly because it's non-toxic and prevents freezing.
As far as a cooling system running colder - not gonna happen unless your thermostat has gone bad. The thermostat regulates the coolant temperature, not the coolant. You can run lower pressure because at 100% concentration it has a high boiling point - but the cooling system WILL be less efficient. Also - at 100% concentration is has a lower heat capacity than standard ethylene-glycol (normal antifreeze) so that also lower the efficiency of your cooling system (making it MORE likely to overheat.)
Don't drink the coolaid. Just say no to evans NPG... it's snake oil slickly sold. It will work, but not as well as a standard coolant/water mix.
From their webpage:
http://www.evanscooling.com/html/tech1.htm
"Evans NPG Coolant is inhibited 100% propylene glycol."
EDIT: WRXEATR - you revived a 3 year dead thread for what reason? I think by now he changed his coolant..
Old Sat, Jan-10-2009, 07:24:06 AM   #9
Tonester
Reputation: 0 Tonester is an unknown quantity at this point
Viet Nam
You can achieve the same w/ water wetter/distilled water or even a drop of Palmolive (IIRC)
Jump to top Tonester is offline   Reply With Quote
Old Sat, Jan-10-2009, 08:11:30 PM   #10
deilenberger
Not quite. What you don't achieve with WaterWetter and DI water is any freeze protection (and rust or corrosion protection). WaterWetter/Water mix is typically used on track because it isn't as slippery as antifreeze if there is a dump on the track. Coolant is very slippery stuff. WaterWetter is a basic surfactant (google it..) which any detergent also is (Palmolive dish detergent prolly..) The surfactant creates a better molecular mating between the liquid and the surfaces it is in contact with (increasing heat transfer when used in a cooling system.)
The NPG stuff isn't technically "wrong" (they even show charts indicating it has lower specific heat capacity than ethelyne glycol) - it simply isn't worth $30/gallon. It probably would actually work better diluted 50/50 with distilled water. As they market it - it's marketed as "magic" - and we know magic really isn't true..
coolant, evans, npg
Is it Bad to Mix Blue Coolant with Green Coolant? WishIHadAnM3 E36 M3 (1992-1999) 20 Mon, Oct-10-2011 03:17:15 AM
Coolant Warning Light ..wad coolant do i use? M3_Jetblack E46 M3 (2001-2006) 6 Sun, May-06-2007 03:40:44 PM
CHECK COOLANT...Coolant all over my oil pan...is this bad?? Master_Yoda E36 M3 (1992-1999) 15 Thu, Mar-29-2007 03:33:48 PM
Capt. K. Evans swish Off Topic 12 Sun, Dec-10-2006 06:28:44 PM
Add coolant warning lamp and coolant level sensor titaniummm E46 M3 (2001-2006) 0 Mon, Sep-18-2006 06:15:14 AM
Discussing Evans NPG+ Coolant in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
