Old Wed, Sep-13-2006, 06:27:34 PM   #1
so gti
LUST for M
so gti's Avatar
Reputation: 0 so gti is on a distinguished road
Default How do I disable Brake pad sensor?
mine is completely useless now. i just wanna disable it since the warning light is ALWAYS on right now. Yes i did put new pads. any good way to do it? I have e46 m3.
thanks!
Jump to top so gti is offline   Reply With Quote
Old Wed, Sep-13-2006, 06:56:21 PM   #2
elh0102
Reputation: 0 elh0102 has disabled reputation
thanks!
The light should not be on unless the sensor was activated. The first time I replaced pads, I cable tied the sensors out of the way and haven't connected them since. If one was activated by pad wear, then you will probably have to plug in a replacement sensor. There is a connection near the caliper where the last foot or so of the sensor wire unplugs. Could be that just removing the sensor end will shut off the light (doubt it).
Jump to top elh0102 is offline   Reply With Quote
Old Wed, Sep-13-2006, 07:08:13 PM   #3
tfro
tfro's Avatar
Reputation: 0 tfro has disabled reputation
If its always on, then the sensor has been tripped and you'll either need a new sensor or you can cut that sensor and strip the wires and short them together to turn off the light. But if you activated the sensor once, you might do it again and 15 bucks for a new sensor is good insurance against possibly serious damage.
Jump to top tfro is offline   Reply With Quote
Old Wed, Sep-13-2006, 08:45:51 PM   #4
vinnymac
Reputation: 0 vinnymac is on a distinguished road
Pull the sensor out of the pad and tie wrap it off.
Jump to top vinnymac is offline   Reply With Quote
Old Thu, Sep-14-2006, 03:42:56 PM   #5
so gti
LUST for M
so gti's Avatar
well for some reason sensor got messed up after track day. it melted or something. so i was thinking since i tie wrap both front and rear, there should be the way i can disable?
Old Thu, Sep-14-2006, 06:28:45 PM   #6
tfro
tfro's Avatar
You can either buy a new sensor and zip tie it to something or cut the cable you have now and short the wires together. Thats how you bypass the system...
Brake pad wear sensor? one-fifteen E46 M3 (2001-2006) 6 Sat, Jun-21-2008 09:08:26 PM
Brake pad wear sensor CantbePhaded04 E36 M3 (1992-1999) 7 Mon, Jan-22-2007 12:51:08 PM
brake pad sensor question adv3rsary E46 M3 (2001-2006) 5 Fri, Mar-11-2005 10:41:09 PM
Brake Pad Sensor stocksure E46 M3 (2001-2006) 2 Wed, Jan-05-2005 01:06:20 AM
brake pad wear sensor ///sleeper E36 M3 (1992-1999) 13 Wed, Dec-08-2004 06:10:52 PM
Discussing How do I disable Brake pad sensor? in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
