| Faults, Fixes and DIY Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! |
Please drive faster
![]() Location: Islamorada, FL
Disclaimer: Do this procedure at your own risk! This is offered for reference only. I disclaim all liability for direct, indirect, incidental, or consequential damages or injuries that result from the use of any of these examples, instructions, or other information.
Well, I performed the S54 valve adjustment yesterday. In my case I had some excessive ticking and the dealer said I probably just needed this adjustment. Otherwise its an inspection I/II thing. It was fairly easy compared to how it is portrayed. Quite entertaining to see that beautiful inline six's valvetrain in your own car in all its glory! Anyway, I found that it was easier then the TIS leads you through. Of particular note is that it is easier not using the crankshaft to move the motor around. Once you get the plugs out, you can *easily* turn the motor over with a 32mm wrench on the fan clutch. The belt does have enough tension to do this. This avoids a bunch of the work messing with removing the fan, undertray, and the fan shroud so you can get to the crank pulley. It also avoids the tool for this. The only special tool I think you must have is the shim installation tool. It is a special little plastic bar with a magnet in it. Well worth the money. You could technically do it without it, but it just wouldn’t be worth the trouble. The tiny little shims would be quite easy to drop without this tool. The feelers from the dealer you can get, but make sure you get the .15 and the .20 if you do. They are a separate tool number and specific for the S54 engines. I ordered the main part number on the TIS, and didn’t get these. I ended up not using the BMW feelers at all, and using a generic and more complete set that had the exact tolerances I wanted. .05 differences between the feelers when you are testing in a .04 range seemed to be kind of silly. I also wanted my valve train down near the lower end of the tolerance range. Quite a few of mine were right at, or a teeny bit over the upper tolerance range. Since the shims are .04 apart, most of these I was then able to get down to right at the .18 (intake) or the .28 (exhaust) the valve required as a minimum value. Here’s what I used for this job: Special Tools -Shim installer, $25.20, 90-88-6-114-400 -Shim Kit, $319.50, 11-34-0-031-525 Seals, rings, gaskets, etc -Sealing rings, $8.43*6, 11-12-7-831-271 -Cover gasket, $34.00*1, 11-12-7-832-034 -Rubber grommets, $2.34*2, 11-12-1-437-395 -Rubber grommets, $2.55*13, 11-12-7-830-972 -Copper sealing rings, $0.38*2, 07-11-9-963-129 Misc supplies from parts store -Measure device - mic or whatever -High temp gasket sealant/maker -Big ass 1 1/4 wrench (or 32mm) for fan -Feelers, as diverse as you can get -Parts cleaner Major things not to forget: -Don't do this on a hot engine, needs to be a cold motor. Period. -Be crazy cautious about dropping shims, tools, dirt, whatever in the motor. -Be anal - not kidding. Measure everything like five times. -Document your work with each valve -When finished, I recommend putting a little lube on each surface in the valvetrain
E93 ///M3 LeMans Blue Convertible w/Black Interior So far: CSL Trunk lid, SmartTop, V1 hardwired, AA Exhaust, Custom Intake, Turner pullies, ditch of all chrome, incluidng vinyling the trim, painted reflectors, and some other stuff. E46 ///M3 Sapphire Metallic Black Convertible w/Cinnamon Interior. SOLD!!! Last edited by JasonSTL739; Fri, May-12-2006 at 07:11:19 PM. |
Please drive faster
The shim kit in all its glory...
Please drive faster
All the parts and stuff...
#4 |
Please drive faster
Removal of cabin air filter, etc...
#5 |
Please drive faster
Be careful with the exhaust cam sensor cable...
#6 |
Please drive faster
Remove ingition coil ground, seal notice...
#7 |
Please drive faster
A dentist like pick thing made it wayyy easier...
#8 |
Please drive faster
Unplug the two O2 plugs... Unplug/remove anything you need to so you can move all that mess up out of the way across the intake.
#9 |
Please drive faster
Remove the all the plugs from the ignition coils
#10 |
Please drive faster
Ignition Coils R&R
| adjustment, diy, information, long, valve |
| Question for the ones who did the valve adjustment DIY | Tuner_D | E46 M3 (2001-2006) | 20 | Wed, Jul-28-2010 02:50:38 PM |
| S54 DIY Valve Adjustment - Critical Missing Ingo | 928s4vr | Faults, Fixes and DIY | 5 | Mon, Jul-13-2009 08:05:44 PM |
| Valve adjustment | aazeez1975 | E46 M3 (2001-2006) | 61 | Thu, Jun-04-2009 02:35:03 AM |
| Valve Adjustment DIY for inspection 2 | gazz | E46 M3 (2001-2006) | 17 | Sun, Jan-20-2008 05:01:51 AM |
| valve adjustment | Guest | E46 M3 (2001-2006) | 16 | Wed, Dec-11-2002 07:18:59 PM |
