Old Wed, Jan-06-2016, 01:11:29 AM   #81
chatleyg
Reputation: 0 chatleyg is on a distinguished road
Default Re: Shock dynos, Fat Cat Motorsports and custom valved Bilstiens
Great thread, now I understand why my front end feels so stiff once I installed BG springs and Bilstein HDs. I will be trimming front bump stops, thanks Shaika for the great video showing how to trim the stops, and installing GC street camber plates. Can anyone tell me the OD and ID for bump stop packers? I plan on making different thickness packers out of Delrin or UHMW.
TIA, Glenn
Jump to top chatleyg is online now   Reply With Quote
Old Fri, Jan-08-2016, 05:42:08 PM   #82
ShaikhA
Fat Cat Motorsports
Reputation: 0 ShaikhA is on a distinguished road
Very eloquently stated, Shaikh.
This is something that I've known, instinctively, for years. Many people here have heard me preach that "softer is better, more travel is better" (to a point) in almost all driving situations. Sure, the car may not corner table-top-flat or be razor sharp to driver inputs and so it doesn't "feel" as sporty, but, it's ultimately the better "handling" car.
I've also MUCH preferred a larger front/rear spring rate split as opposed to a smaller split. The latter results in a very awkward feeling car as the front and rear ends of the chassis are never in phase like they are with a larger split. This is not felt on smooth surfaces but once you encounter medium/large amplitude bumps it becomes very obvious.
Thanks, Eric. I think some slight tweaking on low speed damping is what we need to get a bit sharper feedback on your setup while still maintaining optimal grip. I do like that the faster you go, the more responsive your car feels while still developing increased / maximum grip. This ties to my general understanding of yaw rate increasing as road speed goes up.
You already nailed the importance of Flat Ride noting your experience with various setups that had too much front spring or not enough rear. Also non-optimal damping screws up the potential to maintain Flat Ride. I believe the tire's spring rate also plays an important part in the unpleasant feeling of a non-Flat Ride setup. It's like trying to balance two unevenly loaded seesaws on top of each other, with a spring as your fulcrum. Once you find your equilibrium point you *might* be okay, until someone (i.e. the road) disturbs the balance. Then, good luck! Coupled oscillations and multiple chaotic resonant frequencies galore!
It's funny, I'm pretty sure in the aerospace, airplane, bridge- and skyscraper-building worlds engineers are very concerned with resonances and do their best to minimize their creation plus use tools to damp them out. Good OE vehicle manufacturers go to similar lengths, some like VW or Audi using many different springs to get ride frequencies dialed-in. But many tuners and most enthusiasts have no idea how important that choice of spring rate is beyond lowering and stiffening their cars.
Heading to Laguna Seca on Sunday, my first event in the BMW there. Stock springs, Eibach front bar on set, stock rear bar, same damping setup as you experienced (Revision 4 KBO v1.7). I think it'll be a ton of fun and useful to see how a 'street-oriented' setup works in high-speed time trial track conditions. I'm guessing you'll be swapping the Dinan springs in pretty soon.
Jump to top ShaikhA is offline   Reply With Quote
Old Fri, Jan-08-2016, 06:12:24 PM   #83
ShaikhA
Fat Cat Motorsports
Oh, found an interesting couple dyno graphs
and this thread on Lotustalk forum
http://www.lotustalk.com/forums/f91/...results-27743/
I will do some analysis on what I believe the impact of those damper curves on the ride quality and behavior of those cars.
Old Fri, Jan-08-2016, 06:24:32 PM   #84
ThrowinShapes
ThrowinShapes's Avatar
Reputation: 0 ThrowinShapes is on a distinguished road
Shaikh, this thread has been a good read so far.
Would you be willing to show us a list or chart of spring rate combinations F/R that have your 'flat ride' balance for our chassis?
[06' AW/Cinnamon] [6MT] [Slicktop] [Manual Seats]
Journal - Update 2017-02-28
FS: Center Console | US Headers / Rear O2 | Rent: SIR B90-BMW Rear Wheel Bearing Tool
Jump to top ThrowinShapes is offline   Reply With Quote
Old Fri, Jan-08-2016, 07:15:31 PM   #85
Depends on your cars weight, weight balance, and unsprung mass per corner
Old Fri, Jan-08-2016, 08:28:28 PM   #86
ThrowinShapes
Can you explain a bit how it depends on unsprung mass? I would the ride frequency would only depend on the sprung weight and wheel rate.
For a typical street car, which doesn't have much of any weight reduction (i.e., close to stock weight +- a few options), do you think it would realistically vary enough to even move to the next spring rate increment?
Old Fri, Jan-08-2016, 10:18:39 PM   #87
BMW offers something like 4 different springs front and rear depending on equipment. So there could be enough variance... though I imagine most of us probably fit into 1 or 2 of combos.
Old Fri, Jan-08-2016, 10:28:17 PM   #88
m3 hal
The motion of unsprung mass is what the spring is controlling. A reduction in unsprung mass = less spring rate required for a given frequency.
I did a quick calc assuming a spring rate of 500 lbs/in and 50 kg of unsprung mass. Dropping 5 kg off the unsprung mass (assuming lighter wheels and brakes) gives 450 lbs/in spring rate at the same ride frequency as the 500 lbs/in + 50 kg setup.
Old Fri, Jan-08-2016, 11:00:53 PM   #89
ThrowinShapes
I would argue the spring is controlling the sprung mass (kind of in the definition, right?). The tire and wheel is supported by the road, which is effectively rigid. No need to control its up and down motion.
Here's a reference for this:
http://eibach.com/eibach/img/ers-14s...nworksheet.pdf
As shown, Suspension Frequency = sqrt(Wheel Rate/Sprung Weight). Therefore, like your example, a rough estimate: take the sunroof for instance, a ~40lbs option, so 10lbs per corner. If the car is ~3200lbs, thats 800lbs corner weight. That represents a 1% difference in sprung weight.
Old Fri, Jan-08-2016, 11:11:16 PM   #90
m3 hal
I would argue the spring is controlling the sprung mass (kind of in the definition, right?). The tire and wheel is supported by the road, which effectively rigid. No need to control its up and down motion.
You're right, I had it backwards.
Discussing Shock dynos, Fat Cat Motorsports and custom valved Bilstiens in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
