Old Fri, Jan-25-2019, 08:47:20 PM   #11
Default Re: Power Steering Flow Restrictor
Like you, I ran without the restrictor for a while with no ill effects. Sometime when you salvage one, add it back.
Old Fri, Jan-25-2019, 09:02:45 PM   #12
Originally Posted by Frost12850 View Post
I thought that may have been a possibility too. The return hose had the original clamp on it though to the trombone (not a worm clamp).
Not many people opt for the hydraulic hose only work. Most just buy the whole part and many do not include the restrictor.
Old Fri, Jan-25-2019, 10:41:19 PM   #13
M3AN
321 fun...
M3AN's Avatar
New Zealand
FWIW, if you buy a new cooler and return line (one piece) from FCP they come with a restrictor, I recently received mine for the 328.
My 09/96 M3 didn't have a restrictor, I've not added one, no problems.
The return line has an ID of 10mm, I imagine that if you buy transmission hose in the USA it will be imperial 3/8" that already offers a small restriction (because it's ~9.5mm). Now, if you just add a hose clamp to the outside of that hose somewhere in the middle and tighten it it will compress enough to act the same as an internal restrictor.
All said and done, I've only heard of them being required if your power steering fluid gets too hot and froths up.
/// E36 M3 Coupe / Estoril Blue / Lotus White
/// S50B32 / 6MT / Slick Top / Alu Doors / Z3 Rack / Simota / Remus / Bilstein B6 / Eibach Pro+ / BBS RC / Goodyear F1 / Rally Road Bits / 3.62 CWP (TBI)
Old Fri, Jan-25-2019, 11:14:44 PM   #14
Frost12850
Reputation: 0 Frost12850 is on a distinguished road
Yup I buy just about everything from FCP. Great prices and a lifetime guarantee. I thought about buying the whole piece but itís much cheaper to just buy the hose and supposively better because you can correct the design flaws of the original hose being too short/ poor clamp, etc.
Jump to top Frost12850 is offline   Reply With Quote
Old Mon, Jan-28-2019, 11:53:01 AM   #15
Eric M3
shogun
Eric M3's Avatar
Reputation: 0 Eric M3 is on a distinguished road
Japan
On my 02/98 M3 I had the restrictor installed before and it is in now in the new hose, not fixed with as clamp. Did replace the originally crimped hoses with hose clamps, hoses for feed and return lines are not high pressure lines, the hoses I use now are for 20 bar. Installed since 2 years. A slight difference is a slightly more power steering support than before with the old hoses. Before the steering wheel support was not that much. This is probably caused by the new hoses. Old hydraulic hoses can suffer from internal deterioration and swell inside = less flow. I have discovered this on older brake hoses also, the original hoses had swelled internally to the extent that the fluid was blocked or limited in flow. Nothing visible externally.
The internal coating of the rubber lines most likely deteriorates and allowes the fluid to saturate/permeate the rubber and swell. The surface of the rubber breaks down over time allowing the fluid to contact the softer rubber compound and swelling occurs.
Pics + dimensions of the flow restrictor from the net
http://photobucket.com/gallery/user/...MzQwMDE=/?ref=
http://photobucket.com/gallery/user/...MzQwMzU=/?ref=
My 7 series DIY site: http://twrite.org/shogunnew/topmenu.html
Jump to top Eric M3 is offline   Reply With Quote
Discussing Power Steering Flow Restrictor in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
