Old Thu, Jan-24-2019, 07:33:29 AM   #1
bigern79
Wannabe e46 M3 Owner
bigern79's Avatar
Reputation: 0 bigern79 is on a distinguished road
Default Sunroof switch, reading lights died on me
I recently picked up an auto dimming mirror and wanted to install it in my 1998 M3 Sedan. I have been doing my best to follow the instructions here:
http://www.m3forum.net/m3forum/showthread.php?t=256958
Unfortunately, the harness that was provided to me did not have the same wiring colors as the kit referenced in the post. This led me to have to use some trial and error to confirm the correct wiring setup with what I had. I cut away a bit of the sheath from the brown wire (ground) and the violet/white wire to expose the copper. From there, I was able to temporarily attach the wires from my mirror and confirm the mirror was working with the ignition in the ON position (I could see the orange led on the mirror lighting up when I pressed a Homelink button).
The weird part is that this only worked for me for a minute or two, then nothing. After that, not only does the mirror not work, but the sunroof switch and reading lights no longer work either (the center map light still works though). I checked all the fuses and they all seem to be fine.
It's late and I'm frustrated, does anyone have any ideas? I'm not sure how clear I'm being on what happened, so I made a short video to help illustrate:
Thanks!
1998 Estoril Blue E36 M3 | 2000 Avus Blue E39 M5
IG: @miata_at_midlife
Jump to top bigern79 is offline   Reply With Quote
Old Thu, Jan-24-2019, 08:22:59 AM   #2
M3AN
321 fun...
M3AN's Avatar
New Zealand
Default Re: Sunroof switch, reading lights died on me
I've never seen a mirror like that in an E36, mine is auto-dipping (dimming?) but doesn't have the buttons or the clown nose.
Anyway, your symptoms sound suspiciously like a fuse, even though you've looked at those...
Do you get any volts or current at the light sockets? If not, what about the fuse socket?
Is the same fuse used for front and rear reading lights? If so then replace the fuse, even if it looks good and try again.
E36 M3 Coupe | S50B32 | 6MT | Estoril | Simota | Remus | Bilstein | Eibach | BBS | Goodyear
Old Thu, Jan-24-2019, 04:32:36 PM   #3
bigern79
bigern79's Avatar
I agree, definitely seems like a fuse thing. I'll try changing a couple that may be related and see what happens.
Old Sun, Jan-27-2019, 03:30:54 PM   #4
bigern79
bigern79's Avatar
Quick update: I'm a moron. Fuse was indeed blown. All is well, carry on...
Discussing Sunroof switch, reading lights died on me in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
