Old Mon, Jan-14-2019, 08:06:55 PM   #21
cblock
cblock's Avatar
Default Re: BMW Wheels No Longer Available
I don’t recall any negatives when I ran 245 square on Kosei K1. I believe you will completely enjoy the driving feel. The only thing about 8.5” Style 24 up front is the 7.5” is better looking.
That's subjective. I think a square set up looks much better than the weak 7.5" front.
Cblock
Jump to top cblock is offline   Reply With Quote
Old Mon, Jan-14-2019, 08:33:59 PM   #22
Of course, but there are certain angles where it looks out of place... like it's obvious you used rear wheels. Similar to how ridiculously ugly front 7.5" look installed on the rear (without being so ugly).
Some wheels are just like this. Style 24 are one of them.
Old Mon, Jan-14-2019, 08:42:48 PM   #23
twentyseven
@itsmejonnyv
twentyseven's Avatar
Agreed.
Running stock 8.5J wheels up front requires the use of a spacer to clear a BBK -which IMO is a necessary upgrade on any nice M3- and that results in an absolutely awful looking package.
Further, with a good alignment you can dial out more than enough understeer for street use. And over long-term course of ownership the ability to rotate tires does not save money.
V-CSL, BBS CH, Öhlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is offline   Reply With Quote
Old Mon, Jan-14-2019, 09:45:36 PM   #24
JitteryJoe
I like the BMW 24 style, I like the period correctness, but I am not adverse to something else non-BMW. I just don't want anything flashy or where the size doesn't look right. Too many aftermarket wheels give me the "oh yuck" feeling. Spinners, maybe something with spinners ...
Old Mon, Jan-14-2019, 11:25:22 PM   #25
Nate047
Nate047's Avatar
Why don't you take one of your rears off and test fit it? If you have M Contours or something the size and offset is the same.
I would get the square rear setup. My front fenders are not rolled, I do have a lot of negative camber although I think you only need like -2.5 or maybe -2.0 to clear the wheels. I also have 12mm spacers and the coilovers are the KW Clubsport. My track wheels are 17x8.5 ET40 which is very nearly the same as the Style 24 rear. Tires are Yokohama AD08R 245/40/17
Old Tue, Jan-15-2019, 01:52:25 AM   #26
JitteryJoe
Yup, I'm going to check fitment by using the rears as test units. Have a 3 day weekend coming up so I'll be lifting the car and moving wheels around.
Old Tue, Jan-22-2019, 04:25:21 PM   #27
JitteryJoe
I moved the rear Contours wheel up front. I needed a 15mm spacer to get clearance (I run 12mm with the stock front wheel). It is really tight with my suspension setup. It might be OK but looks very large with a lot of tire. I'll probably stick with the stock size.
Old Tue, Jan-22-2019, 05:37:01 PM   #28
westopher
westopher's Avatar
Joe you can still get non stamped style 24 in both sizes brand new, can’t you?
98 m3, techno/anthrazit cloth, 107k and officially worthless. 2000 323i touring, silver/grey/sport pack, 170k and officially boring.
Old Tue, Jan-22-2019, 05:41:25 PM   #29
JitteryJoe
I believe so. I prefer the painted stamped version however
Old Tue, Jan-22-2019, 11:24:27 PM   #30
cypher448
cypher448's Avatar
Reputation: 0 cypher448 is on a distinguished road
Aren't the painted ones easier to refinish too?
Jump to top cypher448 is offline   Reply With Quote
Discussing BMW Wheels No Longer Available in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
