Old Thu, Jan-03-2019, 12:45:01 AM   #1
JitteryJoe
Default BMW Wheels No Longer Available
I was looking to buy a new set of wheels and I've been leaning toward the 5 spoke painted and stamped wheels. I see the rears are still available (36112227360) but the fronts are not (36112227350). This must have happened recently.
Does anyone know if this is temporary? If not, I'll send an email to Tischer or something.
Thanks,
--Joe
Old Thu, Jan-03-2019, 01:19:49 AM   #2
westopher
westopher's Avatar
Default Re: BMW Wheels No Longer Available
The rears were also not available for a while until recently (last 3 months or so)
Hopefully the fronts go back into production.
98 m3, techno/anthrazit cloth, 109k and officially worthless. 2000 323i touring, silver/grey/sport pack, 175k and officially boring.
Old Thu, Jan-03-2019, 01:42:05 AM   #3
cblock
cblock's Avatar
The square setups look great, maybe it’s fate?
Cblock
Jump to top cblock is offline   Reply With Quote
Old Thu, Jan-03-2019, 01:55:38 AM   #4
The rears they just completed a large batch on a few months ago. There are ~200 iirc... I posted it here a month ago.
The fronts have no production date set... which is not a good thing if you expect to get fronts anytime soon (if ever).
Old Thu, Jan-03-2019, 12:48:21 PM   #5
Richardsperry
95 SC M3
Richardsperry's Avatar
Why wouldn't you just get 4 rears and call it a day?
Old Thu, Jan-03-2019, 01:31:45 PM   #6
JitteryJoe
Yes, that is a possibility but I had not really considered going to a square setup. It may just be a lack of education on my part as to the benefit vs. downside of doing so. I know the look and feel of the stock setup so that was a safe choice.
Of course a another option is to go with non-oem wheels (although finding the right wheel design could be painful). What to do, what to do ...
Old Thu, Jan-03-2019, 03:17:56 PM   #7
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
I'm really surprised they still produce (some) of these. I thought all was all stock from back in the days.
I have doubted so many times ordering a new set for the M3 just to have a set of correct wheels for it. But I would want a set from 1997-99, not some newer produced version.
Is it even made by the same supplier to the same standard? I've read more than once that the finish was not what it was 20 years ago.
Old Thu, Jan-03-2019, 03:29:04 PM   #8
lcrain
lcrain's Avatar
Reputation: 0 lcrain is on a distinguished road
IMO, there are only benefits from going to a square setup. Look better (to me), reduce understeer, allows for tire rotation front to rear. If you like the look, I would not hesitate to go square. I am running square ds2 on my street car and run 17x9 apex arc-8 on the race car.
Jump to top lcrain is offline   Reply With Quote
Old Thu, Jan-03-2019, 03:44:50 PM   #9
westopher
westopher's Avatar
Keep in mind fitment isn’t straight bolt up depending on your suspension setup.
KWs would need a 12mm spacer, then you are looking at 17x8.5et29 up front. You would need rolled fenders and/or camber plates at that setup.
Old Thu, Jan-03-2019, 05:15:29 PM   #10
JitteryJoe
Yeah, not really interested in rolling the fenders. I have camber plates and running Motion Control struts with 6 inch springs and 12 mm spacers in the front. I don't want to end up in fitment hell here. The other thing is with the current MCS struts and rear dampers, and the spring setup, the car sits quite low. Not sure how that plays into it.
I guess I can lift the car, swap positions on the front and rear contours, and see how the larger rears fit on the front.
Discussing BMW Wheels No Longer Available in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
