Old Sun, Sep-23-2018, 08:28:41 PM   #41
Contracheatcode
Reputation: 0 Contracheatcode is on a distinguished road
Default Re: E36 M3 4-Door: Contracheatcode Build Journal
That's looks a lot safer than mine that turns into a 2lb death wheel if the threaded rod is damaged while using the impact. http://mistools.net/WebRoot/Store4/S...616_141138.jpg
I'd let you borrow mine if you were local Mike. I'll be in Sac 10/1 if you want to wait it out.
Thanks for the offer. Not sure I will be around on that date so I picked up one from ECS.
Look forward to starting on the rear suspension once I get back from vacation. Until then more fun in my the sun.
Jump to top Contracheatcode is offline   Reply With Quote
Old Sun, Sep-23-2018, 08:33:30 PM   #42
Contracheatcode
Ohh. I forgot. After the suspension and bushing overhaul. It will be time to remove the automatic in favor of the manual. So Iíll have to start doing some research on what is needed. Sounds like I should be favoring the E46 manual transmission. Any advice is welcomed.
Old Mon, Sep-24-2018, 02:36:24 PM   #43
englishtom1596q
englishtom1596q's Avatar
good luck finding one for a decent price. People are asking stupid money for the Getrag 420's lately, especially true manuals (not SMG's)
Old Fri, Sep-28-2018, 11:35:32 PM   #44
Contracheatcode
Valve Cover Gasket Questions:
1) Can I get confirmation that I am missing the front wire and the bolt is wrong?
Below is the rear with the correct wiring:
Below is the front with just a bolt and no wiring. Worth noting that the front cylinder ignition coil was replaced. So maybe the technician forgot to install that added wiring back and instead replaced with a standard valve cover bolt?
2) What does this front wire do? Would I see positive effects once I put back on?
Old Sat, Sep-29-2018, 12:10:30 AM   #45
I M Legend
There is only one wire in the back. Your set up looks good.
Sent from my R1 HD using Tapatalk
Old Sat, Sep-29-2018, 12:16:20 AM   #46
Contracheatcode
Gotcha. It looks like this is a grounding wire. Given the metal harness, that all 6 ignition coils touch, I could see only 1 wire making sense. Thanks for confirming.
Old Sat, Sep-29-2018, 02:49:40 AM   #47
There are supposed to be two ground straps, front and rear. Your suspicion was correct, Mike.
Old Sat, Sep-29-2018, 03:03:36 AM   #48
You can see this on RealOEM.
https://www.realoem.com/bmw/enUS/sho...diagId=11_6149
Qty 2 grounding straps
Qty 3 grounding studs
Old Sat, Sep-29-2018, 03:18:23 AM   #49
I M Legend
My bad, my car is a 95 and it only comes with one.
Bray is correct. For your 97, you should have two. Strange that someone would take the time to replace the nut as well.
Old Sat, Sep-29-2018, 01:49:55 PM   #50
NolliM3
NolliM3's Avatar
My 95M3 had one also; however, I bought and placed a second ground strap up front.
Discussing E36 M3 4-Door: Contracheatcode Build Journal in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
