Old Sat, Aug-18-2018, 10:47:56 AM   #11
frbz
Default Re: Plan to convert an E36 3 series to an M3
The later model E36 has the rear subframe reinforcement plates. i do not know what year they got them.
Jump to top frbz is offline   Reply With Quote
Old Sat, Aug-18-2018, 10:51:44 AM   #12
frbz
The reinforcement plates are available as a kit to be welded in if required. I bought a set as I redid my suspension on my 94 M3. Internet gossip said my car should not have them as it was a Jan 1994 build, but they were there already from the factory when the rear subframe was removed.
Old Sat, Aug-18-2018, 04:39:03 PM   #13
Hallatauer
Track Rat
Hallatauer's Avatar
Reputation: 0 Hallatauer is on a distinguished road
This what I did when my 99 M3 went into the guard rail at the track. I found a 328is that had a solid chassis but numerous mechanical issues that I got for $800.
I fixed all the issues and sold the 2.8l engine for $500. Then swapped over all the M3 parts.. front and rear sub frames, engine, trans, drive shaft and diff.
Selling off other parts pretty much paid for anything else I needed. But the only thing that made this work was I did all the work myself. To pay someone to do it doesn't make sense economically.
Sent from my SM-G930V using Tapatalk
Jump to top Hallatauer is offline   Reply With Quote
Old Thu, Aug-23-2018, 03:11:19 AM   #14
Majdnoon
Majdnoon's Avatar
Reputation: 0 Majdnoon is on a distinguished road
Thanks for all the info. I'm still going for a nice, clean 3er. Although swapping in the S52 seems like way to much time/money for a 40ish horsepower gain. I'll prolly sell the engine and put that money towards maintenance/mods.
A big question I've got though - how different is the suspension/subframe? Obviously the springs and shocks are different. But what about things like trailing arms, control arms, etc? Are those the same between the 3er and M3? Or would I have to swap those out? If so, what's the best way to do that? Drop the entire subframe out? Piece by piece? If I do it myself, is it a very involved job? Any welding involved? Or just kinda plug-and-play?
Jump to top Majdnoon is offline   Reply With Quote
Old Fri, Aug-24-2018, 06:52:57 PM   #15
NolliM3
NolliM3's Avatar
Do not discount your ability to do most of the work yourself...you'll gain so much confidence and surprised yourself. Also, don't discount moving up to the E46 M3...the prices are very good. Also, don't discount even an E90 M3...especially if time to do all the work becomes an issue.
Old Sat, Aug-25-2018, 12:05:12 PM   #16
JJCTHE1
JJCTHE1's Avatar
Reputation: 0 JJCTHE1 is on a distinguished road
Unless you will get personal satisfaction (some do) of doing all this work yourself, just buy an M3. The 3er idea is terrible IMO. As long as you aren’t picky w color you can find a nice one for 13k range. I can’t see this swap job costing much less than that in total.
Jump to top JJCTHE1 is offline   Reply With Quote
Old Sat, Aug-25-2018, 01:15:07 PM   #17
Majdnoon
Majdnoon's Avatar
Honestly doing the work would give me a lot of satisfaction yes. Plus it'd help me improve my skills!
Old Tue, Aug-28-2018, 02:43:40 PM   #18
tripitz
Reputation: 0 tripitz is on a distinguished road
I actually did this last year for my track car after wrecking my M3.
Do you have tools and space to do this? Taking apart 2 cars ends up with a TON of parts everywhere.
Do you have the tools to do this work? Even buying Harbor Freight starts to add up. Do you have an engine crane? Transmission jack? Do you have the right torque wrenches for the various torque ranges? Do you have the tools to clean and weld in the reinforcements Remember, once you have the suspension out to do the prep work, the car is not moving... I had to run a 50 amp line to my garage...
The tools add up to a significant cost. Also, do not underestimate all of the other things that drive cost. The use-once parts you probably want to change start to add up after a while. $1-2 parts x a lot of parts = significant money. Don't forget to estimate/plan for the "while you are in there parts"... full transmission service? Short shifter upgrade? New clutch/flywheel? Rear main seal? Headers? While the engine is out, that's the best time to do it....
If I wasn't building a race car with a full gut job and an intense level of focus on safety and detail, I would just buy a done M3 and sell your take-offs from the wreck...
It took a LOT of hours too, even with me having done many of the jobs before on the first car that did not need to be redone.
Jump to top tripitz is offline   Reply With Quote
Old Tue, Aug-28-2018, 04:46:18 PM   #19
Texaz3
This guy is telling the truth!
Old Tue, Aug-28-2018, 05:50:20 PM   #20
Majdnoon
Majdnoon's Avatar
Thanks for the info on that. I decided against the engine swap for now. Even if I had all those tools, the time/labor commitment is too much for such a little horsepower gain. Not worth it to me.
Plus I found a 328i w/Turner bolt-ons (power pulleys, tune, intake, etc). I drove it and honestly, hard to tell the power difference between that and my M. This 3er has been lovingly maintained, has an M3 diff, and BC coilovers. Still half the price of an equivalent M3. Makes my work much easier.
My plan thus far is to swap the brakes, shifter (M3 has Z3 short shifter), steering rack (M3's got a Z3 1.9 rack), X-brace, and suspension bits like the trailing arms, control arms, etc. All those components that are beefed up for the M3. Part out the rest of the M3. I don't think that should be too bad. Thoughts?
Discussing Plan to convert an E36 3 series to an M3 in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
