Old Sat, May-26-2018, 12:14:03 AM   #31
bimmerteknik
Reputation: 0 bimmerteknik is on a distinguished road
Default Re: 500k+ Mile E36 M3
Got it all back today. Spent a bit of time at the shop after work getting the super tech springs in.
Jump to top bimmerteknik is offline   Reply With Quote
Old Sun, May-27-2018, 02:03:06 AM   #32
bimmerteknik
Got the block painted
Rotating assembly is together.
Piston and rod install was a breeze with the 87MM Wiseco tool.
The arp studs are a bit short to utilize the provided washers. A quick search yielded that others have ran into this issue as well. Some backed out enough to get the washer on and some just installed without the washers. I chose the latter. But the #5 main has the oil pickup bracket. So I backed it out about 4mm for aesthetic purposes.
I had seen someone mention dropping a 5-7mm ball bearing into each bore. If I had any available i would have went this route.
Planning on having the timing cover on Monday morning before work.
Old Tue, May-29-2018, 01:55:07 AM   #33
bimmerteknik
Installed the timing cover, oil pump and water pump before work today.
Old Wed, May-30-2018, 05:08:42 AM   #34
Texaz3
Awesome progress.
Old Fri, Jun-01-2018, 11:45:46 PM   #35
bimmerteknik
The eBay headers showed up this week. I was not impressed. Ordered Raceland and will hopefully be happier with those quality wise. Should be here Tuesday/Wednesday.
But things are moving along nicely.
Riot racing cams are in
Everythingís timed off the damper markings. I will be leaving the valve cover loose to verify on flywheel before startup.
Flipped over to install the oil pan
Old Fri, Jun-01-2018, 11:54:39 PM   #36
Texaz3
Looks great.
Old Sat, Jun-02-2018, 01:28:19 AM   #37
Nate047
Nate047's Avatar
Nice progress man, thing should rip pretty good with the cams etc...!
Old Sat, Jun-02-2018, 06:10:52 PM   #38
englishtom1596q
englishtom1596q's Avatar
You didn’t want to get the block skimmed since it was out of the car?
Old Sun, Jun-03-2018, 08:04:31 PM   #39
bimmerteknik
Originally Posted by englishtom1596q View Post
You didnít want to get the block skimmed since it was out of the car?
The guys at Axis Speed/ T-Hoff assured me it wasnít necessary, so I left it alone.
Old Wed, Jun-06-2018, 02:18:01 AM   #40
bimmerteknik
Raceland Headers arrived today. I sent them home with a co worker to weld up the threaded ports.
What are those for anyhow? Euro SAI?
Planning on having the engine back in the car this weekend.
Discussing 500k+ Mile E36 M3 in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
