Old Thu, Feb-22-2018, 01:42:40 PM   #41
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: OEM Grade Bi-LED Projector Retrofit into Bosch Euro Headlights
Both places are common to mount the ballasts.
Where one puts them in eye's sight, other nicely hidden away.
I stumbled on some Hakiri led conversion on the 8 series section of the other board. Look nice as well, but too big to have them completely inside the unit. Big heatsink and cooling fan on the back.
Then there's the 'Ebay specil' drop-in led bulbs. No heatsink, no nohing. Probably not worth a try.
Old Thu, Feb-22-2018, 02:05:22 PM   #42
eBay special...
Old Fri, Feb-23-2018, 02:42:40 AM   #43
Earthwormjlm
Imolarot M3
Where did you mount them? I often see these fitted to the strut towers, while there is a nice spot on top of the bumper carrier to mount them out of sight.
I mounted mine next to the horns, so underneath the headlights essentially, pretty much out of the way.
Jump to top Earthwormjlm is online now   Reply With Quote
Old Fri, Feb-23-2018, 06:06:58 AM   #44
westopher
westopher's Avatar
Brett any OBC error codes or flickering due to electrical load? I'd love to go this route to clear up the minor annoyances of my fx-r fitted lights, which are great, but not perfect.
98 m3, techno/anthrazit cloth, 109k and officially worthless. 2000 323i touring, silver/grey/sport pack, 175k and officially boring.
Jump to top westopher is online now   Reply With Quote
Old Fri, Feb-23-2018, 06:25:50 AM   #45
OBC error, yes. No flickering, but radio reception is halved when they are on. I'm looking into resolving those issues.
Old Fri, Feb-23-2018, 02:21:22 PM   #46
I M Legend
That's interesting about the radio reception. It's probably something to do with PWM causing interference. It's common for some home LED bulbs to cause interference with garage door remotes.
Old Fri, Feb-23-2018, 04:00:19 PM   #47
Earthwormjlm
Imolarot M3
OBC error shouldn't be too bad, isn't there a sense resistor that the check control uses to measure current? Your LEDs are using half the power of a Hallogen bulb.
You might be able to resolve your EMI issue with a choke on the input wires to the boost converter. A high perm torroid, large enough so you can get 1-4 turns with the input wires might do the trick. You can try wiring common mode, so black and red wires going through, or differential, just the red or just the black going through the core. Wires going straight through a toroid is equal to 1 turn, 1 loop around a toroid is equal to 2 turns.
Laird (formerly Steward) type 28 or LF material would probably work, just pick the size you think would fit:
https://www.digikey.com/products/en/...=1&pageSize=25
That's disappointing that Morimoto uses noisy hardware, I'm curious what kind of FCC certification is on that product. Although removing it from its aluminum case, and removing the cable shielding could be part of the issue here.
Old Fri, Feb-23-2018, 07:33:16 PM   #48
Yep. I plan to look into modding the check module shunt resistor unless there are software tweaks you can do and add some chokes to the wiring.
Old Sat, Feb-24-2018, 12:46:02 AM   #49
DaytonaM3
DaytonaM3's Avatar
Reputation: 0 DaytonaM3 is on a distinguished road
Nice work Brett! Always thinking of great stuff.
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=178703&dateline=14388  99332
Jump to top DaytonaM3 is offline   Reply With Quote
Old Sat, Feb-24-2018, 12:55:25 AM   #50
DaytonaM3
DaytonaM3's Avatar
Originally Posted by SQ13 View Post
Ugh. I just bought new headlights with FXR HID retrofit.
I hope you don't feel this way when you receive the headlights from me. Altho your ballasts will be outside of the headlight you won't have any more wiring to show than the factory highs and low plugs and one wire that is ran for city lights.
Nothing against LED bulbs but they don't compare agains the D2S bulbs output.
image1 by Kevin Love, on Flickr
image2 by Kevin Love, on Flickr
Discussing OEM Grade Bi-LED Projector Retrofit into Bosch Euro Headlights in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
