Old Tue, Jan-30-2018, 11:36:11 AM   #11
omairtheman1
Default Re: SuperSprint Euro exhaust system install grief
This is giving me anxiety considering I am installing the US headers and mid pipe system in about a week
Old Tue, Jan-30-2018, 04:04:46 PM   #12
JitteryJoe
Mine is the euro setup. Hopefully the US version has better fitment.
I'd definitely leave the headers loosely bolted until the mid pipe is firmly bolted up.
Old Tue, Jan-30-2018, 04:21:33 PM   #13
ECSTuning
ECSTuning's Avatar
Reputation: 0 ECSTuning is on a distinguished road
On the E36 SS I usually suggest "soft" installing everything (hardware just installed enough to hold things in place), then going back over it all and cranking it down. It's the only way I've found to make lining the system up possible. Fitment is very tight, it's one of those the system fits one way and one way only deals.... unless you start opening up the holes.
-James
ECS Tuning your #1 source for all things German automotive
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
sales@ecstuning.com | customerservice@ecstuning.com
Jump to top ECSTuning is offline   Reply With Quote
Old Wed, Jan-31-2018, 07:52:34 AM   #14
omairtheman1
Thanks James... And yes I think the US system might be easier considering the mid pipe connection is the slip on type. I am paying someone to have this installed and it easily becomes and issue and prices start going up when things don't line up.
Old Wed, Jan-31-2018, 04:58:38 PM   #15
JitteryJoe
The Euro version has a slip on connection at the muffler (at least one pipe is slip on). The issue is at the mid pipe to header. That is not slip on is it on the US version?
Old Sun, Feb-04-2018, 04:06:04 AM   #16
JitteryJoe
So I finally got the mid pipe connected. I ended up drilling out the mid pipe flange bolt holes in order to get enough clearance to bolt to the headers (the SS euro headers have threaded holes to receive the bolts). Loosening the headers really didn't help as the additional movement was not in the direction that helped alignment. All it did was give me the addition job of re-torqueing a bunch of hard to reach nuts. What I now know for sure is that the SS fitment is off. It is really, really annoying. You would think that an end-to-end setup, and not inexpensive setup, would properly fit. There is not a ton of material around the flange to remove. Too much an the gasket won't seal. Too little and the bolts won't line up. Drill out a little, try it, drill a little more, until you get the needed clearance. The right to do this would have been to grind off one of the flange welds, get everything lined up and re-weld the flange. That would have involved a lot of work and cost. Maybe I could have ground off the weld myself, not sure. Anyway, I opted for the drill out method.
Hopefully the muffler fits without any further headaches.
Old Sun, Feb-11-2018, 11:17:22 PM   #17
JitteryJoe
Went back under the car and noticed that the forward header, just past the collector, is pressing against a high spot where the transmission mates to the engine block. I would say it is just barely pressing but enough where I cannot fit a sheet of paper between the two. I can try to adjust everything again but I am wondering if it is worth it. Likely I'd have to loosen the manifold from the head. The spot is so small that, had I known, I could have easily ground a bit of material off the trans case.
Thoughts?
Old Mon, Feb-12-2018, 05:13:24 AM   #18
omairtheman1
OMG I am debating returning my headers. Joe, my heart truly feels for you.
Old Mon, Feb-12-2018, 05:26:10 AM   #19
westopher
westopher's Avatar
Lol you make it sound like he died.
It really does suck though. Parts like this should not require such extensive modification.
98 m3, techno/anthrazit cloth, 107k and officially worthless. 2000 323i touring, silver/grey/sport pack, 170k and officially boring.
Old Mon, Feb-12-2018, 02:11:34 PM   #20
JitteryJoe
No, I am not near death. But I sometimes feel that someone at Supersprint should be called to Judgement.
Discussing SuperSprint Euro exhaust system install grief in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
