Old Mon, Jun-25-2018, 09:11:22 PM   #21
nholmes
Track Junky
nholmes's Avatar
Default Re: ABS Pump Bleeder Nipple?
Finished the hardline in my car yesterday.
This is basically the kit we're going to offer to the community. This is version 1.0 with some changes to the final hard line layout before we start mass production.
When it's complete it will include instructions with pictures and all necessary hardware for a seamless install.
Check out my build!
Old Mon, Jun-25-2018, 09:12:40 PM   #22
Nice!
Old Tue, Jun-26-2018, 03:07:44 AM   #23
NolliM3
NolliM3's Avatar
Definitely Interesting!
Old Tue, Jun-26-2018, 08:54:33 AM   #24
VLT
Reputation: 0 VLT is on a distinguished road
I am currently in the process of rebuilding my calipers/ECS SS brake lines/flush. Is bleeding the ABS unit recommended? Pedal was squishy prior to the overhaul I'm doing on the car. Is INPA needed to do this? It's loaded on my computer but I do not have the E36 adapter. Power bleeder good enough?
04/98 Techno/Dove.... 200k (RIP)
04/98 Techno/Dove.... 115k (SOLD)
10/03 LSB/Black.......... 70k (SOLD)
11/12 LRP E92............. 49k
02/99 Alpine/Dove ...... 150k
Jump to top VLT is offline   Reply With Quote
Old Tue, Jun-26-2018, 06:17:40 PM   #25
nholmes
Track Junky
nholmes's Avatar
INPA is not needed, you can bleed it the same way you would bleed a caliper.
Attach a bleed hose/tube, crack the bleeder 1/4 turn and then close.
If you believe you have air in your system after you have tried everything else, try the ABS bleeder IMO.
Check out my build!
Old Wed, Jun-27-2018, 04:57:34 PM   #26
drtwofish
Reputation: 0 drtwofish is on a distinguished road
Very interesting. I've never bled the ABS pump either and don't have access to the software. Would be interested in a relocation kit if it's as easy as bleeding a caliper. In theory, does activating ABS after a bleed and re-bleeding via the calipers flush out most fluid trapped in the pump? Barring a stuck air bubble of course.
-Justin
'98 Dakar M3/4/5
'98 Boston Green 323ic 5MT
Jump to top drtwofish is offline   Reply With Quote
Old Tue, Jul-31-2018, 06:26:15 PM   #27
nholmes
Track Junky
nholmes's Avatar
Haven't forgotten about this, it's just on hold as I'm currently between jobs.
Check out my build!
Old Thu, Sep-20-2018, 10:43:19 PM   #28
nholmes
Track Junky
nholmes's Avatar
Alright, now that I'm working again I'm going to look into getting this project back off the ground.
Took the car to the track a couple weeks ago and the bleeder had zero issues, which is great. I wasn't expecting any problems but you never know once you start messing with things that aren't OEM spec.
Check out my build!
Old Thu, Oct-04-2018, 06:36:55 PM   #29
nholmes
Track Junky
nholmes's Avatar
Wanted to take a moment and share some of the work on the adapter piece.
Values have been scrubbed from the spec sheet for intellectual property reasons.
We're reaching out to machine shops this week for quotes. Making some progress for sure. Going to place an order for materials soon.
Still trying to decide on a reasonable price point for this kit, not really sure what's fair. We're not looking to gouge the community, but the two of us have spent quite a bit of time and our own money on this.
Check out my build!
Old Mon, Oct-15-2018, 09:43:04 PM   #30
nholmes
Track Junky
nholmes's Avatar
Hard lines and flare nuts came in last weekend.
Check out my build!
Discussing ABS Pump Bleeder Nipple? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
