Old Mon, Jan-22-2018, 07:54:18 PM   #1
nholmes
Track Junky
nholmes's Avatar
Question ABS Pump Bleeder Nipple?
So, I'm looking into trying to get all the air out of my brake system and I believe that I have air trapped in the ABS module.
Before anyone asks, I've already bled 1L of fluid through the system using the 2 person method including cycling the ABS intake/exhaust solenoids with the pump via INPA. My next step will probably be to use ISTA-D / Rheingold and try the ABS bleed sequence included with that dealership software.
While I'm waiting to get that set-up, I wanted to see if anyone on the forums has ever had any success attaching a line to the nipple on the pump and then bleeding from there with the pump actuating.
It's almost impossible to access this nipple with the M/C, reservoir and the fuse box in the way, but I'm sure someone has tried this at least once?
I'm talking about this:
Usually it has a rubber cap on it like a brake caliper bleeder:
Check out my build!
Old Thu, Jan-25-2018, 04:08:12 PM   #2
englishtom1596q
englishtom1596q's Avatar
Default Re: ABS Pump Bleeder Nipple?
You shouldn't have to touch that at all. I use a pressure bleeder that connects to the reservoir and pushes fluid through. I switch between super blue and clear ATE fluid so I can tell when it's completely flushed and have a solid pedal every time. I used to just gravity bleed brakes where I'd crack the bleeder and grab a cup of tea. Nowadays I'm too impatient and pressure bleeding takes a whole 10 minutes
Old Thu, Jan-25-2018, 04:10:25 PM   #3
nholmes
Track Junky
nholmes's Avatar
Why did ATE put a bleeder there?
Check out my build!
Old Thu, Jan-25-2018, 04:58:54 PM   #4
jayjaya29
Photographer
jayjaya29's Avatar
Could be where they filled the system from the factory.
Old Mon, Feb-26-2018, 11:36:38 PM   #5
nholmes
Track Junky
nholmes's Avatar
So, to follow-up since most people don't bother on forums...
Well, after having changed a million things on the car to eliminate variables to deal with the low pedal engagement and squishy pedal I finally fixed it. BBK was not the answer but I can see why people would say that since it helps mask the poor braking with more braking force.
Yesterday I had a friend over to help me bleed the ABS. I read a lot of stuff online about how it's not needed and the system is self bleeding, etc etc but I wasn't convinced.
We performed one final bleed of the system to confirm there was no air trapped anywhere. We then removed the cap on ABS bleeder nipple shown:
We stuck an 11mm wrench onto the hex of the ABS bleeder nipple (it's super tight in there, get a wrench with a directional switch, for real) and then my caliper bleeding tube.
I hopped into the driver's seat and pumped the brake pedal to pressurize the line.
He then cracked the bleeder and a bubble about 1.5" in tube length escaped!
We did a couple more bleeds which got us a few more bubbles and continued until it was bubble free. Fluid came out new, so this wasn't a pocket of trapped fluid, it was just air that couldn't vent itself with normal ABS use.
So, if you're having a hard time getting your pedal back to normal after you've done the, "You need to use like 1L of fluid to get the brakes right, dude" and it still doesn't work or activating your ABS on street - I recommend you try this.
Have fun out there!
Check out my build!
Old Tue, Feb-27-2018, 05:19:38 PM   #6
jayjaya29
Photographer
jayjaya29's Avatar
Interesting....will try this with my next bleed.
Old Tue, Feb-27-2018, 05:27:27 PM   #7
So you have a rock hard pedal and the car stops on a dime now. Do you give credit to the booster or the abs bleed? ABS bleed seems much easier and cheaper. I have never done one so I might give it a try.
Old Tue, Feb-27-2018, 10:54:36 PM   #8
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
With the DIS procedure, it actuates the ABS solenoids to bleed the unit.
Others use a bridge relay to activate the ABS pump.
Old Wed, Feb-28-2018, 12:25:24 AM   #9
nholmes
Track Junky
nholmes's Avatar
I don't have DIS. I was able to actuate the solenoids and pump via INPA but that did not vent the air trapped at the bleeder nipple.
Bridge relay only activates the pump as I've used this method previously, it doesn't actuate the intake and exhaust solenoids.
So the low engagement and soft torque was due to the brake booster. The first 20% of the pedal was due to air trapped in the ABS system inside the pump that was not able to vent during normal driving (including actuating the ABS on street/track).
Check out my build!
Old Wed, Feb-28-2018, 12:40:20 AM   #10
pat533i
pat533i's Avatar
Reputation: 0 pat533i is on a distinguished road
Seems like that bleeder nipple is only on 96+ cars
Dammit
@shut_up_racing
Jump to top pat533i is offline   Reply With Quote
Discussing ABS Pump Bleeder Nipple? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
