Old Tue, Feb-12-2019, 12:43:54 AM   #381
betrezra
Default Re: My $8.8K 176K mile Craigslist E36M3 Journey Begins
The last of the welding on this project.... until I get to the exhaust Is DONE!
It was soooooo nice to not be welding these control arm reinforcement plates on my back under the rear of the car......... so much more relaxing!
1999 E36M3 5spd - ls swap in progress (project pasta muncher)
2001 360Modena 6spd
2018 M2 DCT
Old Tue, Feb-12-2019, 01:26:40 AM   #382
Nate047
Nate047's Avatar
Nice progress man!! Hell yea. So lemme ask you, those control arm reinforcements. Is that a weak point on these cars with increased power? I don't think I've ever seen those, but admittedly I haven't looked into the V8 swap rabbit hole at all. Is there a reason you didn't go with a Powerflex or other type of adjustable rear LCA?
Old Tue, Feb-12-2019, 02:16:45 AM   #383
betrezra
thx Nate....
at this stage of the build, I'm just reinforcing the stock bits to holdup to 515 hp....... these plates are very in expensive...... so for $40 and welding rod I've beefed them up .
eventually will save up for top of the line coil overs, wide body fenders, bbk, and nice big racing wheels/tires..........
right now just want to get this junk running.... reliably.....
I really enjoy welding..... can't wait to do the exhaust.
2001 360Modena 6spd
2018 M2 DCT
Old Thu, Feb-14-2019, 12:34:21 AM   #384
betrezra
more progress:
fuel tanks cleaned, new dual fuel pump set-up wired in and installed.....
waiting on new fuel pump connectors.... old ones cracked...
2001 360Modena 6spd
2018 M2 DCT
Old Fri, Feb-15-2019, 10:51:41 PM   #385
betrezra
1.15.19 update....
1. rogue engineering diff cover installed. add more capacity, has provisions for a temp gage, and a diff cooler later (if) needed.
https://www.bimmerworld.com/Drivelin...SABEgI9z_D_BwE
2. diff reinforcement mount installed.
3. waiting on some syn diff oil and will fin install.
4. waiting on submersible fuel hose then will pop in the fuel tank, and fuel system will be done. waiting on fancy cloth elec tape to tidy up the under seat dual fuel pump wiring.
2001 360Modena 6spd
2018 M2 DCT
Old Sat, Feb-16-2019, 02:36:23 AM   #386
Texaz3
Cool diff cover!
Old Sat, Feb-16-2019, 02:42:48 AM   #387
betrezra
Junk in the trunk!
service notice... if you ever plan to service your fuel pump or gage sender..... be prepared to buy new fuel pump connectors....... they just fall apart when you pull them off the old pump connection.....
2001 360Modena 6spd
2018 M2 DCT
Old Tue, Feb-19-2019, 01:19:59 AM   #388
betrezra
took a break from building on sat for a club drive with my other car....
the gated shifter is not as smooth as the m3..... but rewarding.
the sounds of 8500 revs is satisfying...... the 360 could use another 100hp....... though.
can't wait for this m3 to hit the track again!
2001 360Modena 6spd
2018 M2 DCT
Old Tue, Feb-19-2019, 01:40:25 AM   #389
Nate047
Nate047's Avatar
See, this is why I'm surprised when I read something like "eventually will save up for..."
Old Tue, Feb-19-2019, 03:32:58 PM   #390
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
Those RE covers are nice but $$$ however you should hopefully need it with all that extra power
Sent from my iPad using Tapatalk Pro
Topo Chico
Discussing My $8.8K 176K mile Craigslist E36M3 Journey Begins in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
