Old Fri, Mar-02-2012, 09:57:30 PM   #41
hcaleman
Reputation: 0 hcaleman is on a distinguished road
Default Re: DIY: E36 Cluster Dark Spot Fix - Revised - No Glue Method - More Vibrant than Bef
He didn't modify his odometer.
Jump to top hcaleman is offline   Reply With Quote
Old Sat, Mar-03-2012, 12:54:34 AM   #42
Originally Posted by notopM3 View Post
Just wondering, since you've cracked open the instrument cluster and modified it, is that something you will have to declare if you later sell the vehicle?
Lol...
Old Sat, Mar-03-2012, 01:10:29 AM   #43
bmwpowere36m3
Reputation: 0 bmwpowere36m3 is on a distinguished road
Only if you roll back the odometer
Mike... aka Track Junkie
'98.5 M3 Coupe Titan Silver
Jump to top bmwpowere36m3 is offline   Reply With Quote
Old Sat, Mar-03-2012, 05:28:29 AM   #44
notopM3
Reputation: 0 notopM3 is on a distinguished road
I don't think the cluster is designed to be disassembled. I've heard about a "tamper dot" that will pop if you mess with them. Just wondering.
Jump to top notopM3 is offline   Reply With Quote
Old Sat, Mar-03-2012, 08:19:45 AM   #45
No, that is not true.
The tamper dot is related to changing the coding plug or circuit board side of the cluster, not opening. The gauges have absolutely NOTHING to do with that. Opening the cluster and fixing manufacturing design flaws will not trigger a single thing.
The cluster is absolutely 100% designed be disassembled. All are.
Old Sat, Mar-03-2012, 06:06:34 PM   #46
notopM3
Cool. Thanks.
Old Tue, Mar-06-2012, 01:18:41 AM   #47
tbsleeper
tbsleeper's Avatar
Reputation: 0 tbsleeper is on a distinguished road
So did this and it works great! All 5+ spots I had are gone and the dash looks great exceppttttt now the Miles/odometer is so dim you cant see it unless the dash is turned on full bright. The maintence thign is also a little dim. What causes this? Isn't it a sealed unit? Should I check that little black plug is that the one that powers this?
Jump to top tbsleeper is offline   Reply With Quote
Old Tue, Mar-06-2012, 02:34:16 AM   #48
You probably disturbed the little lights that illuminate that section. They are 1.5w brown tops. Wiggle them or replace them. Common failure.
Old Wed, Mar-07-2012, 02:38:30 AM   #49
crisscross
Reputation: 0 crisscross is on a distinguished road
I did this also with great results, however I have a question for you Brett. Have you noticed any expansion or flexing of the gauge face? About a ten days ago when my car sat in the sun for a few hours (maybe 80* in the car) one of the needles started to stick. After the car cooled down the needle worked fine again. Is the needle just too close to the gauge face?
Great writeup though, thanks!
____________________________
-Alan
Jump to top crisscross is offline   Reply With Quote
Old Wed, Mar-07-2012, 03:49:26 AM   #50
Nope. Mine has been like this for a long time now.
You probably have your needle just a tad too tight.
Discussing DIY: E36 Cluster Dark Spot Fix - Revised - No Glue Method - More Vibrant than Before in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
