Old Fri, Feb-10-2012, 01:11:20 PM   #31
Richardsperry
95 SC M3
Richardsperry's Avatar
Default Re: DIY: E36 Cluster Dark Spot Fix - Revised - No Glue Method - More Vibrant than Bef
I've got an OBD2 cluster in the garage, the glass is fine. The glass is an easy swap. What's the going rate for a cluster?
Old Fri, Feb-10-2012, 05:44:51 PM   #32
97_4dr_5spd_m3
Old College Kid
97_4dr_5spd_m3's Avatar
Reputation: 0 97_4dr_5spd_m3 is on a distinguished road
I am assuming that you wouldn't want to sell me just the glass ah?
Originally Posted by Roland H View Post
I might have two for sale, but straight sale only and you probably won't like my price.
Send me a PM with the price.
Jump to top 97_4dr_5spd_m3 is offline   Reply With Quote
Old Fri, Feb-10-2012, 06:14:03 PM   #33
vmbray
Reputation: 0 vmbray is on a distinguished road
Originally Posted by cracky View Post
nice work. plenty of other **** I need to do on my car before iw orry about this though.
my dark spots also seem sporadic. sometimes there..sometimes not. usually in winter.
Yup just noticed it in the cold, was much better when it was warm. Thanks for the great write up!
Sent from my DROID X2 using Tapatalk
Rear End Overhaul
Jump to top vmbray is offline   Reply With Quote
Old Sat, Feb-11-2012, 12:11:23 AM   #34
Richardsperry
95 SC M3
$80? for the glass, and I'll toss in the cluster for free...lol
Old Sat, Feb-11-2012, 02:15:29 AM   #35
bmwpowere36m3
Reputation: 0 bmwpowere36m3 is on a distinguished road
Awesome Brett, awesome! Can't wait to do this to my euro cluster, which has a nice dark spot around 3-4k RPM.
Mike... aka Track Junkie
'98.5 M3 Coupe Titan Silver
Jump to top bmwpowere36m3 is offline   Reply With Quote
Old Sat, Feb-11-2012, 08:46:24 PM   #36
Please post your results.
Old Thu, Mar-01-2012, 03:05:24 AM   #37
Machtig
Reputation: 0 Machtig is on a distinguished road
I'm going to try this soon. My only question is reinstalling the needles. Its late and I've just drove over 700mi, but I don't understand how you reinstall to your marks. Stick it on loose and turn to the stops to adjust??
Cosmos Black 1998 ///M3 - Euro Six-speed and driveshaft, Euro headlamps and aim control retrofit, Euro rear fog light retrofit, Euro rear power vent window retrofit, Euro fire extinguisher and first aid kit, Euro instrument cluster, OEM LTW wheels, M50 manifold conversion w/ BavAuto software, Stromung cat back exhaust, Ground Control Coilovers (350/450), UUC Ultimate FCABs, SPC adjustable rear lower control arms, new OEM RTABs, GC shims, GC RSMs, AKG 95A rear subframe and diff bushings, Michelin PSSs, CD43 radio, Soundplicity III bluetooth/iPhone integration
Jump to top Machtig is offline   Reply With Quote
Old Thu, Mar-01-2012, 03:16:49 AM   #38
No, install completely down then push the needles past their stops to find the correct resting and end sweep points. It can be tricky getting that perfect alignment so sometimes I'll pull the needle up the shaft some, make my orientation guesstimate and then push it back down.
I show the depth to push them down to and you'll understand the "stops" thing when you watch the video I posted on removing the needles (and do it yourself).
When you make your marks don't push too hard or you might push the needle past it's original orientation on the motor shaft (past the "Stops").
Old Fri, Mar-02-2012, 03:08:27 PM   #39
tbsleeper
tbsleeper's Avatar
Reputation: 0 tbsleeper is on a distinguished road
So many dark spots on mine. Page favorited now just to go out and do it before spring!
Jump to top tbsleeper is offline   Reply With Quote
Old Fri, Mar-02-2012, 08:44:28 PM   #40
notopM3
Reputation: 0 notopM3 is on a distinguished road
Just wondering, since you've cracked open the instrument cluster and modified it, is that something you will have to declare if you later sell the vehicle?
Jump to top notopM3 is offline   Reply With Quote
Discussing DIY: E36 Cluster Dark Spot Fix - Revised - No Glue Method - More Vibrant than Before in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
