Old Mon, Sep-01-2014, 09:02:35 AM   #61
dih5020q
dih5020q's Avatar
Reputation: 0 dih5020q is on a distinguished road
Taiwan
Default Re: DIY e46 M3 Engine Mounts
Thanks to this DIY, did this the past weekend, wasn't too difficult. Noticed the old passenger mount was more compressed than the driver, is this normal from regular wear?
Jump to top dih5020q is offline   Reply With Quote
Old Mon, Sep-08-2014, 02:31:39 PM   #62
Smoked M3
Reputation: 0 Smoked M3 is on a distinguished road
Did this DIY a few days ago. When jacking up the passenger side, watch for the fuel rail hitting the firewall. On the driver's side, watch for the intake manifold hitting the firewall.
2004 Silver Grey / Imola Red - 139k Daily Driver
ENGINE: AVT air scoop, MS air filter, Mishimoto elbow, EvoSport pulleys, ESS tune, fan clutch delete, SAP delete
EXHAUST: AP headers, AP rasp sec. 1, SGT res. x-pipe, TopSpeed muffler
SUSPENSION: BC coilovers, RE RSMs, Powerflex RTABs, AKG rear subframe reinforcement
BRAKES: Rallyroad BBK F/R, CSL/ZCP rotors, Hawk PC pads
WHEELS/TIRES: Hamann PG1, 19x9.5 +25, 19x10.5 +25, Hankook V12 225/35 and 245/35
DRIVETRAIN: 4.10 gear ratio
LIGHTING: Orion V2, 3000k fogs
INTERIOR: Recaro SPG reps, Cobywheel, CF trim, CF RE SMG knob, rear seat delete, Dynavin clone, JL Stealthboxes
Jump to top Smoked M3 is offline   Reply With Quote
Old Mon, Oct-06-2014, 01:22:30 AM   #63
MarqE46
Wolverinium
MarqE46's Avatar
Reputation: 0 MarqE46 is on a distinguished road
Going to be ordering new motor mounts to finally replace the old factory ones and will be using this DIY. Still debating if I should do the transmission mounts at the same time or hold off for later. Excellent stuff! Thanks.
Jump to top MarqE46 is offline   Reply With Quote
Old Mon, Oct-06-2014, 01:29:18 AM   #64
ThunderMoose
Transmission mounts are super easy. Go for it!
#67 2014, 2015, 2016 NASA TX TT3 Runner-up,
FLMS Half Cage, RaceTech 4009HR drivers seat, Schroth 6-Pt Harness, E.S.S. Fire System, AIM SOLO DL with ECU Harness, SmartyCam, Angle Aluminum with VAC dead pedal, Sparco Steering Wheel on MOMO hub, MCS Suspension, Hyperco 800F 900R springs, Hotchkis Front and Rear Sway bars, Vorshlag Camber Plates, Turner ARCA, AJ Hartman Front Splitter, BW V2 Wing, BW CF Rear Diffuser, APEX ARC-8 wheels, Brembo BBK Front, Carbon Fiber Roof, CF Headlight Blanks, Door Windows and Cards Delete, TMS rear and front subframe reinforcement, Zionsville Competition Cooler, BW Oil Cooler, Oil Diverter Valve, Motorsports Thermostat, Evolve CF Intake, Epic Stepped Headers, Turner Pulleys, BW 3.5" Race Exhaust, EPIC Alpha N Tune, 288/280 Cat Cams, Beisan Oil Disk and Vanos Seals, ZF 5MT, CAE Ultra Shifter
Jump to top ThunderMoose is online now   Reply With Quote
Old Mon, Oct-06-2014, 01:39:54 AM   #65
MarqE46
Wolverinium
MarqE46's Avatar
Great!
Old Sun, Aug-23-2015, 03:05:05 PM   #66
Kieffer87
Reputation: 0 Kieffer87 is on a distinguished road
Just did this while I was swapping out my shifter bushings and trans mounts. I loosened the subframe and jacked up the engine which made it really easy to get the new ones in. Old ones came out quite easily as you can see from the picture how compressed they were.
2003 M3 Alpine/Cinnamon Loaded
APEX ARC-8 18x9.5 ET35 wrapped in 265/35 PSS
TCKline D/A Coilovers (550F/600R) W/Monoball RSM, H&R Adjustable Sway Bars
Fabspeed Headers, UUC Corsa Exhuast, CPI RASP-X
Rogue Power Pullies, AA Tune, SS Lines, ZHP Steering Rack
Jump to top Kieffer87 is offline   Reply With Quote
Old Fri, Oct-16-2015, 05:13:52 PM   #67
Toxic0n
Reputation: 0 Toxic0n is on a distinguished road
Just did mine, great DIY. The passenger side mount was completely gone, it was cracked and was about half an inch flatter than the driver's side. I had to jack up my engine quite high to get the new mounts to fit, was worried about breaking something but it seemed to work fine. Did not want to drop the subframe and pay for an alignment. I ended up jacking the engine up by the oil pan, however for the passenger side, I used another jack around the AC compressor area.
Idle is so much smoother now and it alleviated my "M-clunk" quite a bit. I'm happy.
Ground Control Street/School coilovers, 19" HRE 441R wheels, ACS exhaust
Bimmian CF E-brake handle, Titanium CF Trim, Illuminated ZHP knob, BMW Performance SSK
Clear turn signals, LED license plate lights, LED tails, 3000k HID fogs, angel eyes, matte grills, CF Emblems etc
Jump to top Toxic0n is offline   Reply With Quote
Old Tue, Jan-17-2017, 12:59:36 AM   #68
Dxj
Reputation: 0 Dxj is on a distinguished road
Great DIY. Just did this today and wanted to contribute in case it helps someone. Some notes: for passenger side, had to jack up the engine until the fuel rail was hitting the firewall. Still didn't have enough space so had to use a hacksaw to cut off the cone portion of the bottom bolt. For the driver side, had to lift the engine until the top coolant hose started to stretch to fit the mount in there but didn't need to shorten the bolts. Didn't want to drop the subframe as I would have been tempted to do bunch of other items down there...
Jump to top Dxj is offline   Reply With Quote
Old Sat, Jan-28-2017, 08:06:54 AM   #69
E30toF30
E30toF30's Avatar
Reputation: 0 E30toF30 is on a distinguished road
I just got my engine and Tranny Mounts in this week. I'm hoping to tackle both of these at the same time next week. I'm a little worried but from everyone's comments maybe it's not too difficult?
I can't decide which method to go with. Jacking the motor up higher, or using one of those engine bars from HF and dropping the subframe.
Sounds like if I drop the subframe, I don't have to remove any other parts of the car (intake, cabin filter parts, fan related items etc...). . Is that correct?
Wish me luck guys! Hopefully this turns out easier than anticipated (much like the fcab and Rtab diys).
Sent from my ONEPLUS A3000 using Tapatalk
Jump to top E30toF30 is online now   Reply With Quote
Old Sun, Feb-12-2017, 03:51:07 AM   #70
E30toF30
E30toF30's Avatar
Didnt' get any responses on my last post, but I wanted to add another question.
Would doing one way over the other (jacking up vs. dropping subframe) be better if I were planning on doing motor AND tranny mounts?
I read above someone did the motor mounts first, then did the tranny mounts so I'll go that route.
Thanks!
Discussing DIY e46 M3 Engine Mounts in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
