Old Thu, Oct-18-2018, 03:55:47 PM   #131
Default Re: M3 S50B30 in Japan
Ha. The body colored mesh looks so aftermarket that I always assumed it was a spray paint mod people did
Old Thu, Oct-18-2018, 06:04:55 PM   #132
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Old Sun, Oct-21-2018, 01:48:22 AM   #133
Neubauten
Reputation: 0 Neubauten is on a distinguished road
Japan
The track day previously mentioned highlighted also the need for some good alignment, so a few months later (I am busy and only use the car every now and then) I went for a change of Rear Trailing Arm Silentblocs (there were still original), in order to make a proper alignment of the drivetrain.
And a Japanese surprise happened!
I had never met the light in the right before, this is only for Japan : a temperature sensor on the catalytic converter... I don't know if this exists in the USA but it does definitely not in Europe so I scratched my head for some time tu understand what it was, before finally checking in the owner's manual.
So I asked my mechanics to check and well, wires were just cut. The guy who put the cat back did a poor job...
I was definitely time to change the rear SB too:
And alignment done!
Camber FR -2.5 RR -2.0
Toe FR 0.00 RR in 0.08
Finally we changed the brake pads, to the same Endless variant that we are using in our race car for Endurance races. They are made-to-order racing compound, and it totally transformed the brakes feeling and gives much much more confidence! And it does not compromise streetability too much because they brake reasonably well even cold. The only trade-off is noise...
Car then felt totally different and awesome, however the good alignment highlighted the fact that the steering rack was definitely worn out as there was a very perceptible play in the steering.
Jump to top Neubauten is offline   Reply With Quote
Old Sun, Oct-21-2018, 02:53:48 AM   #134
GG///M3
LOUNGE CREATOR
GG///M3's Avatar
Reputation: 0 GG///M3 is on a distinguished road
Albania
Good stuff man
Jump to top GG///M3 is online now   Reply With Quote
Old Sun, Oct-21-2018, 03:29:42 PM   #135
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
I always thought that light meant your hotdog is ready.
Old Sun, Oct-21-2018, 05:19:07 PM   #136
GG///M3
LOUNGE CREATOR
GG///M3's Avatar
Albania
Old Sun, Oct-28-2018, 02:18:24 PM   #137
Neubauten
Japan
After the new alignment and pads I went for a try in Sodegaura circuit, while training with our 318is race car.
... And basically warped the front rotors within a couple of laps...
I was still running on road tires, and did not look for any limits at all but I basically stopped quickly because of the vibration coming from the brakes. Unfortunately my old stock rotors did not like being attacked by so aggressive pads.
Apart from that, the car felt really well balanced and easy going, a real pleasure to drive it a bit harder than usual on the track!
So I quickly went back to my mechanic with a few parts:
M3 3.2L Rotors on Aluminium hubs:
New brake position sensor to solve the ABS issue:
tadaaaam!
And the drive shaft flex disc, because mine was felling its age too.
Some door contact sensor because my windows was playing strange games:
And a set of winter tires, on nice BBS I found in auction:
We also changed the fuel level sensor and a couple of hoses in the fuel system:
Basically the only issue left was the steering rack, but anyway that would be for after winter and ski season!
Because that is also why M3 are for: be used in all circumstances!
Old Mon, Dec-03-2018, 09:39:24 AM   #138
Neubauten
Japan
I will continue to catch up on the maintenance!
After last winter, I finally decided to change the last mechanical stuff which was bothering me: the steering rack! Indeed after changing all the element of the front axle, I still had some free play in the steering and I really don't like this: a good M3 must be sharp!
So I bought from Europe a "brand new" re-manufactured part for a M3 3.2L (the same as any other E36 in fact).
The old:
The new one assembled:
I also changed the CV joint as the old one was tired to say the least...
Finally, I put new tires Yokohama AD08R in 235/40.
I went for a quick run in Sodegaura circuit to test everything and the car felt really great, I am very happy with this setup!
As I had the Grip Matsuri in Ebisu circuit planned in June (2 days of open pit track day) I went for a little check-up and preparation beforehand: oil change, brake fluid, and parallelism as we did not do it after the rack change (the machine was broken...).
Beware, engine oil Gurus
Finally, a good spring clean up with AMMO NYC products, which I really love to use!
I have condensation in my lights...
And then, track action!
Old Mon, Dec-03-2018, 09:42:28 AM   #139
M3AN
321 fun...
M3AN's Avatar
New Zealand
Ouch, those pictures are huge.
And why didn't you get an E46 or Z3 rack??? Stock M3 rack is so, so sucky.
E36 M3 | Estoril | Coupe | S50B32 | 6MT | Remus | BBS | Bilstein | Eibach
Old Mon, Dec-03-2018, 01:01:56 PM   #140
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
The B30 rack is the so sucky rack. Going to the B32, while not fast as the Z3 rack, is still a good upgrade compared to the so sucky rack.
Discussing M3 S50B30 in Japan in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
