Old Sat, May-04-2013, 05:37:52 PM   #1
psangabriel
Reputation: 0 psangabriel is on a distinguished road
Default Leaking Clutch Fluid under transmission
Hello all,
I've looked around regarding leaking fluid from the clutch and initially thought it was the clutch slave cylinder. Finally I got under the car and saw something different. The fluid seems to be leaking from directly under the transmission from these two holes.
Anyone seen this before? The video/picture was taken with 10 PSI pressure from a Motive Pressure Bleeder. I don't want to replace the clutch master or slave before I figure this out.
At 25 seconds is when the pressure is built up to 10psi
Thanks for your help.
Jump to top psangabriel is offline   Reply With Quote
Old Sat, May-04-2013, 06:41:16 PM   #2
Nipps
Noob
Reputation: 0 Nipps is on a distinguished road
Default Re: Leaking Clutch Fluid under transmission
FYI, video is private and will not play.
-Nick
BMW CCA #449254 | SCCA #416632
1999 BMW M3
Jump to top Nipps is offline   Reply With Quote
Old Sat, May-04-2013, 07:14:42 PM   #3
Jrrrrrrr
Unregistered User
Jrrrrrrr's Avatar
Just seeing the fresh brake fluid seeping in your pic, and not being able to view the video you posted, and that you didn't go above the recommended 15 PSI on the pressure bleeder and blow out the slave seals, I'd say fluid is getting past a worn slave cylinder diaphragm and exiting through the vent hole in the bellhousing.
Old Sat, May-04-2013, 07:25:22 PM   #4
psangabriel
Sorry... I just made the video public.
Old Sat, May-04-2013, 07:46:43 PM   #5
jayjaya29
Photographer
jayjaya29's Avatar
This.
Your slave cylinder is shot.
Two 13mm nuts to remove it from the bellhousing.
Old Sun, May-05-2013, 08:36:42 AM   #6
Herbert
I ///M Faster
Reputation: 0 Herbert is on a distinguished road
Well I am number two for this, noticed it yesterday... bad things come in three's, so who's next?
Bumper Sticker: "Real Racers Go Left AND Right" - So True
Last performance car - e30s52
Jump to top Herbert is offline   Reply With Quote
Old Fri, Aug-31-2018, 11:55:47 PM   #7
M3jv909
Reputation: 0 M3jv909 is on a distinguished road
I came across this problem as well, could it be the slave cylinder? There seems to be some pentosin on it and massive leak under the car, here are some pics
Sent from my SM-G935T using Tapatalk
Jump to top M3jv909 is offline   Reply With Quote
Old Sat, Sep-01-2018, 12:33:19 AM   #8
You have an E46 M3 with SMG. This is the E36 section. You could have a slave leak, but that mess looks like oil leaks from CPV, rear main seal, oil pan, etc.
Old Sat, Sep-01-2018, 12:42:21 AM   #9
M3jv909
I checked the CPV and there's no leak around it at all,
Old Sat, Sep-01-2018, 01:17:32 AM   #10
mossyoaks
mossyoaks's Avatar
Reputation: 0 mossyoaks is on a distinguished road
This ^^
Just replaced the slave & master on my e36/7 Z3 and will install new s/m in my 95 M3 this weekend.
Jump to top mossyoaks is offline   Reply With Quote
Discussing Leaking Clutch Fluid under transmission in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
