Old Sun, Oct-22-2017, 04:57:58 PM   #1
BMW>Everything
Reputation: 0 BMW>Everything is on a distinguished road
Default Full 3.5in exhuast
So I plan to get ARH headers with its 3.5in design and want to do a straight pipe system up to section 2 with an EVC, then a quiet street type muffler.
My question is, ARH section 1 has a merger that goes from 3.5 to 2, 2.5in pipes that connect with the stock section 2. Would it make sense to have a Y-pipe with a 3.5in bimmerworld section 2 straight pipe with an evc at the end before section 3 muffler.
Basically going from 3.5 -> Dual 2.5 -> Single 3.5in
Or should I cut the merger in the section 1 before it splits into 2, and make a FULL 3.5in all the way before the muffler?
Which would give more performance?
Jump to top BMW>Everything is offline   Reply With Quote
Old Sun, Oct-22-2017, 05:03:51 PM   #2
Drewster
Drewster's Avatar
Default Re: Full 3.5in exhuast
Probably the full 3.5
Old Sun, Oct-22-2017, 05:11:44 PM   #3
stash1
PM me
'04 AW/IR...some mods
Old Sun, Oct-22-2017, 05:37:09 PM   #4
BMW>Everything
Would the TTFS tune be worth it for the headers, or just getting custom dyno tune. Can't justify $700 for software....
Old Sun, Oct-22-2017, 05:39:37 PM   #5
m3nt0s
Registered Detailer
Reputation: 0 m3nt0s is on a distinguished road
Are you still planning on FI? http://www.m3forum.net/m3forum/showthread.php?t=592966
Worth reading through the entire ARH drama thread before making a decision here. http://www.m3forum.net/m3forum/showthread.php?t=582564
05 E46 M3 Coupe - Jet Black/Black, SMG, Karbonius Airbox, 18" RG-R, AS3 235/265, Koni Yellow, Beisan, Structural Foam, CSL/full SMG coding, SAP Delete, Xtrons
03 E39 530i - Black Sapphire/Black, Sport Package, 5MT Swapped (DD)
Previous:
09 E91 328i Space Gray/Chestnut, N52, Auto, xDrive, Xenons, no iDrive, TPMS Module Delete
11 Mustang GT Premium
09 N51 128i
04 S60R GT S2+
95 854 Turbo
Jump to top m3nt0s is offline   Reply With Quote
Old Sun, Oct-22-2017, 05:43:33 PM   #6
BMW>Everything
The new testament isn't even that long.....All I really want is a dyno chart to convince me lol
Old Sun, Oct-22-2017, 05:55:44 PM   #7
T3AMFiSh
Your mom goes to college
T3AMFiSh's Avatar
you would spend more than that on a custom dyno tune.. you pay for the Dyno time plus the tuners time..
Old Sun, Oct-22-2017, 06:41:43 PM   #8
stash1
Also worth mentioning, w/this set up, your power curve will move to the right a little more...
Old Sun, Oct-22-2017, 11:28:59 PM   #9
C///M
There is zero performance benefit to keeping the 1->2->1 in place. The only benefit is it bolts up as is vs time/cost to convert to 3.5" all the way.
Since the dual pipes are roughly the same cross-area as the single, the velocity shouldn't change much so honestly I wouldn't think there'd be a performance difference either way you do it.
The only possible benefit I can think of for going to 3.5" all the way is friction losses from the dual pipes would be higher vs the single pipe.
Jump to top C///M is online now   Reply With Quote
Old Mon, Oct-23-2017, 12:53:31 AM   #10
AR Headers
American Racing Headers
AR Headers's Avatar
Reputation: 0 AR Headers is on a distinguished road
BMW Everything,
There's absolutely nothing wrong with the 2-1/2" Y that joins back to a single 3-1/2" in section 2. This will have Zero negative effect on performance I assure you. Run it with confidence.
Nick
Jump to top AR Headers is offline   Reply With Quote
Discussing Full 3.5in exhuast in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
