Old Wed, Oct-18-2017, 11:39:50 PM   #21
arkow
Reputation: 0 arkow is on a distinguished road
Default Re: Installed Spacers, now ticking noise
Originally Posted by daytonaviolet View Post
spacers can be used with any wheel applications. as long as the new lugs are long enough to accommodate the depth of the spacer. too long is as bad as too short.
I was told that the spacers with extended bolts are only for stock application, meaning they are meant for wheels that came stock with the car...so no i'm confused..
Jump to top arkow is offline   Reply With Quote
Old Thu, Oct-19-2017, 12:09:31 AM   #22
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
you've been misinformed as spacers can be used in many applications stock or non stock wheels.
Tischer aka GetBmwParts
Old Thu, Oct-19-2017, 12:25:30 AM   #23
arkow
That's what i was thinking, but was told that they are for stock applications, so basically i need to grind them down a bit as they are too long and hitting something inside the hub...
Old Thu, Oct-19-2017, 12:43:42 AM   #24
daytonaviolet
OEM CSL Whoore
Or get shorter lugnuts
Old Thu, Oct-19-2017, 12:59:02 AM   #25
ScottManUGA
Reputation: 0 ScottManUGA is on a distinguished road
Just to reinforce what everyone is already saying. I had the exact same issue, and it would decrease if I lifted the e-brake lever a little while rolling slowly. That confirmed for me it was a bolt or bolts hitting an e-brake component. Replaced those bolts with slightly shorter bolts and it never happened again.
2005 TiAg/Imola 6MT M3
Jump to top ScottManUGA is offline   Reply With Quote
Old Thu, Oct-19-2017, 05:02:51 PM   #26
arkow
I was thinking of doing that, stock bolts were 28MM and the extended ones i got are 43MM (15MM spacers) so they should fit, but now i am stuck with bolts that i paid for and have to get new ones. Speaking to customer service they suggested to buy 39MM bolts as thats what they have, which to me is a big difference between 43MM and 39MM. Where do you guys get bolts and what size i should get so the wheels don't fall off ? or should i just grind down the ones i have?
Old Thu, Oct-19-2017, 05:33:51 PM   #27
Paulo M
Pretty sure you can just have them cut slightly. Or order the 39mm on eBay. They're cheap enough, just make sure to buy black if the rest of your bolts are black
BREMBO BBS DIXIS
Old Thu, Oct-19-2017, 05:44:48 PM   #28
arkow
Got you, but isn't 39MM a bit too short? thats a 4MM difference, i don't want me wheels to fall off..
Old Thu, Oct-19-2017, 06:37:10 PM   #29
Paulo M
It's fine, as long as it's not more than 5mm too long it should be safe. Just make sure to use torque wrench.
BREMBO BBS DIXIS
Old Thu, Oct-19-2017, 06:58:57 PM   #30
arkow
got you, will look into getting shorter bolts. I got a torque wrench and i do 88lbs tq on the bolts..
Discussing Installed Spacers, now ticking noise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
