Old Thu, Jun-23-2016, 01:27:02 AM   #11
angelr
angelr's Avatar
Reputation: 0 angelr is on a distinguished road
Default Re: Drivetrain Vibration - Speed Related, Help!
In my case what revealed the true issue was running it in gear going from 1st to reverse with the wheels elevated on the alignment rack while Mike watched.
07 z4 m coupe aw over ir
04 IR smg coupe- Dead
Jump to top angelr is offline   Reply With Quote
Old Thu, Jun-23-2016, 02:46:13 AM   #12
bigjae1976
Are you sure the CV joint on the driveshaft is good? That's something you can check...just need to clean the grease off and then regrease.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, Jun-23-2016, 03:26:40 AM   #13
F1Dryvr
Reputation: 0 F1Dryvr is on a distinguished road
This sounds alot like the driveshaft cv joint. I had same vibration corrected after repacking. But might need to replace if its been doing it a while. There are diys available. Search bmtroubleu or something like that. Not tok difficult to repack. Get some molybdenum grease and a new gasket, and make sjre to be meticulous about the orientation of the parts.
Jump to top F1Dryvr is offline   Reply With Quote
Old Thu, Jun-23-2016, 08:37:16 PM   #14
Dirty Elf
BSME
Dirty Elf's Avatar
Reputation: 0 Dirty Elf is on a distinguished road
The CV is seeming more and more plausible. I think before I shell out $$ for axles I'll replace the centering bearing and inspect the CV while I repack it with moly grease.
Thanks for the insight guys I'll keep you updated.
First Road Trip
2004 Silver-Grey ///M3 Coupe
Jump to top Dirty Elf is offline   Reply With Quote
Old Thu, Jun-23-2016, 08:43:59 PM   #15
young_pong
Reputation: 0 young_pong is on a distinguished road
Hi all,
Had the same issue with my car last month, had the driveshaft recalibrate and change the driveshaft front bearing.
It's smooth now.
Jump to top young_pong is offline   Reply With Quote
Old Thu, Jun-23-2016, 08:47:31 PM   #16
young_pong
" the centering bearing "
That's what my mechanic replaced.
Old Mon, Oct-23-2017, 11:26:08 PM   #17
Dirty Elf
BSME
Dirty Elf's Avatar
just realized I never updated this thread... i must have updated another thread because i remember posting when i fixed this issue
turned out to be the driveshaft itself. replaced it with a re-balanced one and problem went away
First Road Trip
Discussing Drivetrain Vibration - Speed Related, Help! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
