Old Wed, Mar-22-2017, 06:40:19 PM   #61
Flow
Flow's Avatar
France
Default Re: Car stalls ransomly when coming to a light...
Originally Posted by zippity View Post
I have about $25k in receipts for maintenance and other miscellaneous over the past 3 years, so I'm on the verge...
Same here
2004 M3 TiAg / LSB SMG
Old Wed, Mar-22-2017, 08:29:35 PM   #62
zippity
Reputation: 0 zippity is on a distinguished road
Originally Posted by Flow View Post
Same here
But your car looks awesome compared to mine haha, I love that rear end shot...
Back to topic...I need some more affirmation from Fuel Pressure Regulator believers to be the resolution of this terrible plague....
Jump to top zippity is online now   Reply With Quote
Old Wed, Mar-22-2017, 08:56:48 PM   #63
Jovica
Reputation: 0 Jovica is on a distinguished road
I had this exact same issue and in the end, it ended up being this:
I had cut a hole in the intake connection tube (P/N 13717830101) to increase the induction sound - I know, lame. After reading many posts about the issue I was having (same as you), I realized that most of the time, it was associated with an aftermarket intake or vacuum issues.
I installed a new intake connection tube without the 'opening' and my car hasn't stalled once over the last few hundred kilometers.
I would advise you to check your intake one more time. Ensure that all of your hoses are attached properly (and not clogged) and that every component of the OEM intake is in good shape.
Good luck!
Jump to top Jovica is online now   Reply With Quote
Old Wed, Mar-22-2017, 09:14:36 PM   #64
zippity
Good luck!
What tubes are you referring tube?
Old Wed, Mar-22-2017, 09:23:28 PM   #65
Jovica
Look up the P/N I mentioned on RealOEM or ECS website.
car, coming, light, ransomly, stalls
Discussing Car stalls ransomly when coming to a light... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
