Old Thu, Dec-02-2010, 10:09:35 PM   #21
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
Originally Posted by Noodle555 View Post
How much ransom do you have to pay to get going?
damn it, you beat me to it, lol. but op, it seems like fuel pump, or maf.
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Fri, Dec-03-2010, 06:40:03 PM   #22
M42boy
Reputation: 0 M42boy is on a distinguished road
Okay, cleaned out the MAF sensor real good with some more brake cleaner... No issues with using that stuff as it leaves no residue. MAF cleaner is the same thing and I keep brake cleaner around all the time.
I also pulled apart all the intake tract going to the airbox and cleaned it out thoroughly, as well as cleaned out the whole air box. Put in a brand new BMW factory panel filter, new hose clamps and cleaned out the elbow. No leaks there, and everything is tight and clean.
Figured I'd see what that did... Car tried to stall on me twice last night! I cought it with my right foot, but the problem is still there. But, funny, my "Service Engine Soon" light came on as well.
Could this just be an 'oil change indicator', or does this mean I'm throwing a code?
Wish I knew someone around here with the GT1 software.
Jump to top M42boy is offline   Reply With Quote
Old Fri, Dec-03-2010, 06:53:18 PM   #23
patrickd_21
Reputation: 0 patrickd_21 is on a distinguished road
I have the exact same problem and I have a K&N typhoon CAI. When I put the OEM air box back in, all problems were solved. So no need to worry, it's just your CAI.
Either live with it like me, or switch back to OEM lol
///M3 Jet Black, 6 speed manual
Jump to top patrickd_21 is offline   Reply With Quote
Old Thu, Jan-10-2013, 01:44:51 AM   #24
LSB FTW
Fear is exciting for me
LSB FTW's Avatar
Reputation: 0 LSB FTW is on a distinguished road
Default Re: Car stalls ransomly when coming to a light...
I have the same issue. any updates on this?
Jump to top LSB FTW is offline   Reply With Quote
Old Thu, Aug-29-2013, 09:18:45 PM   #25
harut44
Reputation: 0 harut44 is on a distinguished road
Me too, changed my MAF but same issues. Happens with AC or without. It stalls only on downhill or coming to a stop at a parking garage. At lights and in traffic it dips to about 400-500RPM and stays there until the engine catches itself.
Jump to top harut44 is offline   Reply With Quote
Old Fri, Aug-30-2013, 12:25:45 AM   #26
Fastdog911
Fastdog911's Avatar
Reputation: 0 Fastdog911 has disabled reputation
start with easy stuff... bad tank of gas, fuel filter dirty, clean or find a friend and swap maff,idle control valve.. do that and see if that works, you could even look at replacing gas cap.. fuel pump either works or doesn't.. it would cut on you at any time not just at idle. And never use brake cleaner on maf starting now. Its not the same stuff.
[IMG]2002 SMG, Topaz Blue, BHS pulleys, all options. UUC Exhaust, GC Sway bars, SS lines, BHP Pads F1 paddles, GSP brake pedal, Huber Optik 20%, Iforged rims and a bunch of other things.. Sold
1970 911T Tangerine
1972 911T Albert Blue
1970 911E Ossi Blue
Jump to top Fastdog911 is offline   Reply With Quote
Old Fri, Aug-30-2013, 01:51:29 PM   #27
Yoshie
Yoshie's Avatar
Reputation: 0 Yoshie is on a distinguished road
check your battery voltage too. esp if you have an smg. might be dropping off
Posted from M3forum.net App for Android
03/2002 SMG
Tools for Rent:
Shim Kit and Tool
Timing Bridge
RTAB
Jump to top Yoshie is offline   Reply With Quote
Old Fri, Aug-30-2013, 03:46:18 PM   #28
IHatePosers
Long Live M3
IHatePosers's Avatar
Reputation: 0 IHatePosers is on a distinguished road
in order
open bonnet
check if air intake elbow and filter holder are tight and secure
clean MAF Sensor with cleaner
check/replace air filter
I had the same problem - and the reason was my air intake fell off and the MAF was exposed.
2018 Dodge Durango GT
Originally Posted by Official 2014 Formula 1 Game View Post
Ihateposers says,"ttylkthxbai"
Jump to top IHatePosers is offline   Reply With Quote
Old Fri, Aug-30-2013, 05:18:19 PM   #29
harut44
My fuel filter was changed less than 5k miles ago. Changed my MAF recently. I think I need to check my ICV.
I have a 6mt but I'll get that checked I still think I'm running on the original battery.
Originally Posted by IHatePosers View Post
in order
open bonnet
Air filter was replaced 10k miles ago and everything is secure. I need to check my ICV.
Assuming the ICV is clean or has no issue with it, what's the next priority of components to check or that could be responsible for the idle drop?
Old Fri, Aug-30-2013, 07:29:32 PM   #30
Yoshie
Yoshie's Avatar
use the on dash computer to monitor the voltage. You can get real time while you drive. I don't think this is your issue, but it's a real easy test.
03/2002 SMG
Tools for Rent:
Shim Kit and Tool
Timing Bridge
RTAB
car, coming, light, ransomly, stalls
Discussing Car stalls ransomly when coming to a light... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
