Old Tue, Nov-10-2009, 02:21:28 PM   #11
kbk_75
Reputation: 0 kbk_75 is on a distinguished road
My car needed to get a new DSC module. Morons took six weeks to get the part from Germany. The joke is, I got so used to driving with no ABS, DSC and other nannying aids that when the issue was finally fixed, the flashing light and lack of wheel spin was annoying me!
Jump to top kbk_75 is offline   Reply With Quote
Old Sun, Feb-28-2010, 04:47:39 PM   #12
1baadm3
1baadm3's Avatar
Reputation: 0 1baadm3 is on a distinguished road
Originally Posted by kbk_75 View Post
I drive a 2007 E92 M3 6 speed. I recently had the DSC, ABS and FTM failure lights and idrive error appear in my car. The next day the problem went away. Then it happened again and again the next day the errors were gone.
I took the car to the dealer (when there were no error messages showing) and they kept it for a day and gave the car back saying there was a loose contact in the wiring loom. I left the dealership and within 3 minutes of leaving the lights were back on, so I turned around and went back to them. They hooked the car up to the computer and said that the DSC module needs to be replaced. Fortunately my car's still under warranty so it's going to be done free of cost. I'll keep you guys posted on the outcome.
did the dsc module fixed your problem
SOLD - 2002 e46 M3 phoenix yellow/kiwi, Ground control 450F/550R, Tubi exaust.
Jump to top 1baadm3 is offline   Reply With Quote
Old Sun, Feb-28-2010, 11:50:50 PM   #13
schwarzen
Reputation: 0 schwarzen is on a distinguished road
This happened to me as well the week before last. Have your tech check the codes and diagnose the Throttle Position Sensor...especially if the car loses power when the lights go whack.
Jump to top schwarzen is offline   Reply With Quote
Old Fri, Oct-08-2010, 10:44:12 PM   #14
kbk_75
Yes, it did.
Old Sat, Dec-25-2010, 08:19:16 PM   #15
kbk_75
Default Re: DSC light on + Yellow 'Brake' light
Fourteen months later and I have the same problem on my car!
This time I was sitting parked when I heard the "bing" and saw all the error messages! I've handed the car in to the dealership. Let's see what they say now. Hope they get the part quicker than they did the last time!
Old Mon, Jan-30-2012, 05:44:27 AM   #16
Cowtowncowboy34
Reputation: 0 Cowtowncowboy34 is on a distinguished road
I have the same prob with my 03 325i except I jumped my wides car off with my Beamer and my dsc and yellow brake lights have been on ever since they don't go off no matter what till I turn car off but as soon as I start they come right back on
Jump to top Cowtowncowboy34 is offline   Reply With Quote
Old Mon, Jan-30-2012, 05:50:56 AM   #17
M3ANMACHINE
@natrajusa
M3ANMACHINE's Avatar
Steering angle sensor may be on its way out.
I currently have the same lights on, and my steering angle sensor needs to be replaced
2011 E90 ///M3 | Space Grey | Fox Red | DCT | ZCP | Slicktop
2008 E90 M3 | AW | 6MT | Slicktop
2004 E46 M3 | CB | SMG
Old Mon, Jan-30-2012, 12:27:42 PM   #18
njb5509
njb5509's Avatar
Reputation: 0 njb5509 is on a distinguished road
happen to me as welll i brought it in and it needed new wheel sensor system for me 2002 m3
Jump to top njb5509 is offline   Reply With Quote
Old Sat, Sep-03-2016, 12:59:49 PM   #19
kjsgadh
Reputation: 0 kjsgadh is on a distinguished road
I had those lights come on, every once in a while and as per reading this and other threads, I didn't do much about it. Generally, turning the car off and on makes the lights go off.
But lately the lights have been coming on way more frequently, especially after switching from winter to summer tires. Either set of tires is quite different than OEM spec, but close in size to front/back.
In the past hot weather made the lights come on more frequently. Anyone else have an experience where lights were temperature triggered, or diagnosed specifically to using non OEM tire sizes?
Sent from my SM-G935T using Tapatalk
Jump to top kjsgadh is offline   Reply With Quote
Old Thu, Oct-06-2016, 02:01:57 PM   #20
Turb02
Turb02's Avatar
This happened to me yesterday on the highway. Noticed it because there was no throttle input. I had to coast over to the shoulder. Shut the car off and back on, and everything was back to normal.
With my Bluetooth OBD scan tool, there were no codes, so when I got home I tried to check for any stored codes with INPA, to no avail.
Freaked me out because there was literally no response from the throttle pedal. When I came to a stop, the idle was a bit higher (maybe @1100 rpms).
Active Autowerke Stage 2.5-AA Headers-Supersprint-Meisterschaft-Vorsteiner-Brembo-AC Schnitzer-BBS-CSL
6MT swapped-RTD shifter-Amber Gang
Jump to top Turb02 is offline   Reply With Quote
brake, dsc, light, yellow
Discussing DSC light on + Yellow 'Brake' light in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
