Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > Member Photos and Videos
Member Photos and Videos Place to post and discuss BMW and other automotive videos and photos.
Old Fri, Jul-27-2018, 06:28:44 PM   #11
nextelbuddy1
nextelbuddy1's Avatar
Default Re: Porsche 996 BREMBO BBK Photo DIY
So for $1000 you got the front and rear calipers, CSL front and rear rotors, ss lines, caliper brackets???
There's a guy locally that is selling me a good condition full complete set already on an m3 that he's removing. Has everything front and rear for $1200.
Is that a bad deal?
2003 ZHP 332i | S54 6 Speed | M3 Conversion
2002 ZHp Touring | M54 6 Speed
Jump to top nextelbuddy1 is online now   Reply With Quote
Old Fri, Jul-27-2018, 07:54:51 PM   #12
I just did the front. Rears would be just a little cheaper, so under $2k for both or so.
The damn rotors are half the cost! There are ways to play with it though to keep costs down, you could still run cheap stock rear rotors, for example.
_
Old Fri, Jul-27-2018, 11:55:11 PM   #13
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Is that a bad deal?
Thatís a terrible deal, pm me his info. Just kidding the wife will kill me if I mention another project (she doesnít know i have a Vincebar waiting to install).
Jump to top Blaikenstein is online now   Reply With Quote
Old Mon, Jul-30-2018, 04:35:06 PM   #14
Go_diego_go
Go_diego_go's Avatar
Reputation: 0 Go_diego_go has disabled reputation
I just purchased a front set of calipers last night. What are you doing for the pad sensors? Do our stock ones work?
2006 ///M3 Imola on M-Texture Alcantara -Current Journal
2002 ///M3 Imola on Dove -Sold
1995 ///M3 Alpine White on Dove -Sold
Jump to top Go_diego_go is online now   Reply With Quote
Old Mon, Jul-30-2018, 04:44:05 PM   #15
$1200 for everything already done? Go for it- MPARTSWW or "lagunasec" is selling them for like $3250 lol
I simply secured mine (driver side) away in the little black electronic box and zip tied it.
I wasn't interested in retrofitting it as my car isn't a DD and these 1/2" thick Porsche pads could likely last me 10 years at the 3k/yr rate I'm going.
_
Old Mon, Jul-30-2018, 04:47:29 PM   #16
Go_diego_go
Nice. Iíll probably end up doing the same. I may PM you some more questions as I piece together my kit if thatís ok with you
Old Mon, Jul-30-2018, 04:55:06 PM   #17
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
just realized I have a set of these calipers I bought new for my urs6 wagon, I think I may have found a new home for them
Topo Chico
Old Mon, Jul-30-2018, 05:24:35 PM   #18
It's really cool mod and I thank all those involved over the years to make something like this possible - there would have had to have been a lot of mental/rationalizing gymnastics for me to buy a Brembo BBK, otherwise, with their normal high cost.
_
Old Tue, Jul-31-2018, 06:50:31 AM   #19
dothraki
Reputation: 0 dothraki is on a distinguished road
Thanks for sharing. You have inspired me to make the plunge.
Just a few questions which may help others as well:
*What is the part number for the pad dampers or do you have links for them?
*Where did you get the bleeder screws?
*Did you consider the front brackets from Creation Motorsport that support stock 325mm rotors?
*Did you need to shave 3mm from the knuckle using Creation brackets?
*Would you offer the shaving service to forum members for a cost?
Thanks.
Jump to top dothraki is offline   Reply With Quote
Old Tue, Jul-31-2018, 04:45:08 PM   #20
I've attached my invoice from ECStuning that has the part #s and price for the dampers, lines and brackets.
Bleeder screws are DORMAN brand, #13906 bought from Orielly's Auto, like $5 for a pair. You could probably search longer and find a bleeder that is a better choice, e.i. not as long. All that really matters, of course, is the 10mm size and 1mm pitch. These were 35mm long (1&3/8"); I would have preferred 30-31mm.
I did consider the 325mm rotors (euro drilled/floating) very much, though only for weight savings. In the end I said "eff it" go big The price difference between the euro rotor and csl rotor isn't that much anyways.
I did not have to do anything to the knuckle/kingpin whatsoever for this BBK, though it just have to bend the very tip of the heat shield slightly out of the way - very easy with any tool like pliers/vice grips.
I cannot offer the machining, sorry.
_
Discussing Porsche 996 BREMBO BBK Photo DIY in the Member Photos and Videos Forum - Place to post and discuss BMW and other automotive videos and photos. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
