Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > Member Photos and Videos
Member Photos and Videos Place to post and discuss BMW and other automotive videos and photos.
Old Thu, Jul-26-2018, 11:56:53 PM   #1
Smile Porsche 996 BREMBO BBK Photo DIY
I recently DIY'd a front set of BREMBOs from a Porsche for my M3 and thought it’d be cool to just paste the process in photos to give a quick idea of what’s involved (it can vary of course). No rebuild of the calipers. The prep and painting were the vast majority of the work, but of course that's why it can be done for about $2k.
EDIT - Rears added now
At the end are part numbers for all of the caliper parts to aid you should you take the same route plus other details.
Please enjoy
*REARS*
Nuts & Bolts:
Calipers can come from different Porsche models, so search by part # imo:
Front Left: 996.351.425
Front Right: 996.351.426
Rear Left: 996.352.421
Rear Right: 996.352.422
You remove 5.5mm of material front the front caliper mounting surfaces for use with 345mm CSL rotor or 12mm of material for 325mm rotor. You don't switch the bleeder valves and connector lines.
You don't need to machine the rear calipers, but you do switch the bleeders and lines.
Front 36mm seals - 95135191700 (2 per caliper)
40mm seals - 95135191701 (2 per caliper)
Left crossover line (if yours is corroded or bent) - 99635196100
Right xover line - 99635196200
Damper plates - 99635108802 (2 per caliper)
Front pin kit - 99635195901 (pair for both calipers)
Front pad - 99635294903
Rear seals 28mm - 95135291700 (2 per caliper)
30mm seals - 95135291701 (2 per caliper)
Rear pad pin kit - 996-352-959-01 (pair for both calipers)
Rear pad dampers 28mm - 996-352-086-02
Rear pad dampers 30mm - 996-352-086-00
Left crossover line - 99635296100
Right xover line - 99635296200
Rear pad shape is D738 (standard pad for that caliper) but it doesn't catch our rotor completely OR you can get the front pads from a 2000 boxster 2.7l, D737 shape, to cover the entire rotor. RR brackets will take D737 fully; CM brackets will take D737 on the outside, then you have use the D738 (originals) on the inside.
Cheap bleaders - DORMAN #13906. Cheap caps - refurbish the Brembo ones the calipers come with
Expensive bleeders - 93035191900 (pair - one pair per caliper)
Expensive bleeder caps - 93035192701 (2 per caliper)
High temp brembo decals - ebay
Brackets and lines from Creations Motorsport or Rallyroad (or maybe P0lar, but idk) - picture attached below:
Here's a great post I found on cutters:
To confirm the calipers themselves are part numbers:
Front: 996.351.425.11 & 996.351.426.11
Rear: 996.352.421.13 & 996.352.422.13
Parts for these calipers are as follows:
Dust seals
Front:
2 x 36mm Code: 95135191700
2 x 40mm Code: 95135191701
Rear:
2 x 28mm Code: 95135291700
2 x 30mm Code: 95135291701
Piston seals
Front calipers:
4 x 36mm Code:105595556
4 x 40mm Code:105595558
Rear calipers:
4 x 28mm Code: 105595552
4 x 30mm Code: 105595553
Rear anti rattle shims
Rear calipers only:
4 x 28mm Code: 99635208601
4 x 30mm Code: 96435209600
Bleed valve and dust caps
4 x Code: 93035191900 (2 x valves & caps per pack)
Spring and pin sets
Front calipers
1 x Code: 99635195901 (Per axel)
Rear calipers
1 x Code: 99635295901 (Per axel)
Caliper link pipes
Front
1 x Code: 99635196100 (Left)
1 x Code: 99635196200 (Right)
Rear
1 x Code: 99635296100 (Right)
1 x Code: 99635296200 (Left)
_
OE CSL trunk Sportline 8S 18"x8.5/9.5" + 10mm spacers MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Fri, Jul-27-2018, 12:37:18 AM   #2
Maxima SE
445 FTW
Maxima SE's Avatar
Reputation: 0 Maxima SE is on a distinguished road
Default Re: Porsche 996 BREMBO BBK Photo DIY
looks good. that rug though, you must be persian or armenian
2005 6MT Phoenix Yellow///M3
Jump to top Maxima SE is offline   Reply With Quote
Old Fri, Jul-27-2018, 01:21:26 AM   #3
Nah it just started out as a joke, but haven't gotten rid of it. Not sure whether I want some sort of mat or pad or reseal the concrete.
_
Old Fri, Jul-27-2018, 02:27:06 AM   #4
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Nice DIY Tyler.
What year of Porsche 996 Brembo's do you need to buy?
Old Fri, Jul-27-2018, 02:42:47 AM   #5
To be honest, I'm not entirely sure. They come on different models too, so I just search by part numbers
Front: 996.351.425 & 426. Rears end 352.421 & 352.422
_
Old Fri, Jul-27-2018, 02:56:38 AM   #6
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Ok Cool.
Old Fri, Jul-27-2018, 04:23:25 AM   #7
Blaikenstein
Blaikenstein's Avatar
Reputation: 0 Blaikenstein is on a distinguished road
Good god I canít afford to see this right now. I really like the 996 kit the most due to the diy nature of it. Awesome photo thread!
Jump to top Blaikenstein is offline   Reply With Quote
Old Fri, Jul-27-2018, 06:08:05 PM   #8
aznbo187
XIII
aznbo187's Avatar
Nice!!! Finally someone local with this setup! Good choice on the yellow!
no.13
Old Fri, Jul-27-2018, 06:11:47 PM   #9
Thanks Blankenstein & Mike!
It had to be yellow! Yellow would also be perfect for you car's color
_
Old Fri, Jul-27-2018, 06:28:38 PM   #10
sooch
Reputation: 0 sooch is on a distinguished road
Looks great! Nice work, I might have to order that yellow duplicolor for mine.... Would match up well to Tiag.
Any plans to do the rears? Or paint the stockers?
Jump to top sooch is offline   Reply With Quote
Discussing Porsche 996 BREMBO BBK Photo DIY in the Member Photos and Videos Forum - Place to post and discuss BMW and other automotive videos and photos. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
