Old Thu, Oct-12-2017, 02:42:38 PM   #31
Default Re: 13.5F/13R & 19's - most comfortable suspension avail?
Originally Posted by whips333 View Post
Yup, you definitely found the FCM video that I saw. Exactly how you explained it is how he explained it as well. I also saw a video when he talked about meeting up with you to set your car up for you as well. I love my TCKs SA but I want a sharper more racecar feel even though my car is my daily.
I had them set on half a turn from full soft and on 450/500 springs but it is way to comfortable for my driving style. I now have it set at half a turn from full hard and it feels a little more sharper to me although FCMs dyno shows otherwise. It's only been a week tho so I need more time behind the wheel with the new settings.
I plan on getting PSS10s when my TCK's finally give out but that might be a long time from now because like Obioban mentioned I have between 60-70,000 miles on them and they don't feel like they will need a rebuild anytime soon.
You'd hate driving McLarens-- too comfortable
Old Thu, Oct-12-2017, 02:53:30 PM   #32
mr.euro
mr.euro's Avatar
Reputation: 0 mr.euro is on a distinguished road
I had ohlins r&t on my old e90 m3 and they were awesome. The design allowed for tons of ride height adjustability (from higher than stock to super slammed) and rode nicer than stock.
On my current e46m I have TCK DA front and SA rear. Im not sure what springs they have as the PO installed them, but the ride is very nice even with the stiff sidewalls that the star specs have.
The coils have around 30k on them and although they may not look like new, they ride like new.
I wouldn't hesitate with TCK
Jump to top mr.euro is offline   Reply With Quote
Old Thu, Oct-12-2017, 03:23:47 PM   #33
EricSMG
40 something
Originally Posted by AW///M3 View Post
very informative thread! thanks!
TCK seems like the best option for a street car, but not being able to run stock front strut mounts makes it a deal breaker IMO. From my research all camber plates add NVH
Will stock front strut mounts and RE RSMs work with Bilstein Pss10's?
Yes, but you'll need stock diameter RSMs as the bigger 12mm units normally used on coilover rear shocks won't work with PSS10s. You need the same size that will fit stock rear stocks.
If you want razor sharp without almost no roll then the PSS10s will do the trick. They are much more stout than TCKs.
2004 E46 M3 6MT SG/Black
Old Thu, Oct-12-2017, 06:07:21 PM   #34
whips333
whips333's Avatar
Haha...if it's a McLaren I will force myself to love the ride. I think the way I used "way too comfortable" on my part was an exaggeration a little bit but what I mean is i want more control on ripples in the road at speed rather than the soft comfortable ride that slightly feels like it's floating to me. I think it's the whole hysteresis effect thingy right EricSMG lol. Going stiffer feels like it's helped quite a bit. Comfortableness lol is all relative because even though it's stiffer now it still feels comfortable to me which is a good thing actually.
Old Thu, Oct-12-2017, 06:42:04 PM   #35
twentyseven
twentyseven's Avatar
Ride quality yes, but very cramped interior. 570/720 supposed to be improved though
V-CSL, BBS CH, Öhlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is offline   Reply With Quote
Old Thu, Oct-12-2017, 06:58:40 PM   #36
I just meant the ride quality
Old Thu, Oct-12-2017, 07:24:48 PM   #37
ultimatemj
Seems like 'smooth road' daily drivers might as well use a track setup, but what about 'city street' drivability...you know potholes, grooves and such. I replaced my worn out stock with Koni yellows and they are strangely 'harsh'. Would TCKs improve my ride comfort?
2004 JB/Blk SMG | 2nd owner | Purchased Dec 2008 w/24k miles | Crossed over 100k mile Apr 2019
Key maintenance done @90k: Subframe reinforced | WPC Rod bearings | Beisan Vanos lockdown + chainguide
Refesh maintenance done: Suspension & Driveline rubber replaced | CSB | viton CPV | Coils + plugs+ O2s | Waterpump + Thermostat | Belts & pulleys
OE+ : Evolve airbox | Supersprint Exhaust | PE tune | CSL trunk | 18” VMR 710 w/PSS | EU OE 2pc Rotors | Koni+Dinan springs| Valentine1 w/StealthOne | Stereo build log
Old Thu, Oct-12-2017, 07:27:21 PM   #38
Are you on stock springs? What do you have the shocks set to?
Stock springs with reasonably set Koni yellows should be one of the best riding setups on the car.
Old Thu, Oct-12-2017, 07:34:01 PM   #39
ultimatemj
Yes, stock springs. I also updated FCAB and RTABs at the same time.
I believe they are 'out of the box' on full soft, but I need to check to see if the shop 'tweaked the settings'.
Old Thu, Oct-12-2017, 08:51:57 PM   #40
EricSMG
40 something
Yes, brand new Konis are going to feel very firm relative to worn out stock shocks, big difference. Over time they'll loosen up a bit but I think mostly what you're feeling is having new vs old shocks.
And let's be realistic here - this car is never even remotely comfortable over rough surfaces and anyone who says it is is high. There're only various levels of pain and in general, Konis + stock springs is the least painful
Do be sure they are set to full soft, though.
Discussing 13.5F/13R & 19's - most comfortable suspension avail? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
