Old Mon, Jun-19-2017, 02:48:26 AM   #1
TheDoogan
Forward Loaded
TheDoogan's Avatar
Reputation: 0 TheDoogan is on a distinguished road
Default Leaky Rear Diff - $1,100 sound fair?
Hey guys, one more question tonight:
My car was not driven very much before I bought it, for a few years. Either do to that (or because I've been rough on the rear diff as I learn the car), it began leaking at "the rear pinion seal" shortly after I got it. I now have about 11 different quarter sized drip spots on my garage floor.
After 6,000 miles, the guys at my shop said the rear diff was a little low, and that they'd recommend having them remove the rear diff and have a partner of theirs rebuild it.
They said this would cost about $900 if it was just the 'main seal', up to $1,300 if more than that needed to be rebuilt.
I ask because they've made a few mistakes lately: does this make sense to you guys? Does it sound like a fair price? I have zero problem paying it, I just don't want these guys to fudge up my car.
Is this a job any of you guys would try on your own?
Thanks all.
2006 E46 M3, 6MT, Convertible, Black/Black - 72k miles
Active Autowerke Catless Headers, Section 1 High-flow cats & Section 3, Evolve CSL Intake w/Alpha-N tune. Schrick CSL Cam - 60k mile Service II.
Jump to top TheDoogan is offline   Reply With Quote
Old Mon, Jun-19-2017, 02:51:52 AM   #2
PITT M3 RR
PA
PITT M3 RR's Avatar
Default Re: Leaky Rear Diff - $1,100 sound fair?
Way too much.
I had 4:10 installed and set up with new seals and shims for $400. I supplied R&P, seals and bearings.
There's nothing special about these diffs.
S54 E36 BUILD
Old Mon, Jun-19-2017, 03:39:09 AM   #3
bostonbruck
bostonbruck's Avatar
Reputation: 0 bostonbruck is on a distinguished road
Seems pricey. Call another shop and compare prices. Also look at reviews regarding customer service.
Jump to top bostonbruck is offline   Reply With Quote
Old Mon, Jun-19-2017, 03:39:11 AM   #4
RedM3/4
search pinion seal replacement here. I'm pretty sure that's where nearly all leaks are, and the diff isn't normally removed. I think you ought to shop for a new shop.
ADS
Old Mon, Jun-19-2017, 04:04:37 AM   #5
Also, weeping out where the halfshafts bolt up is normal - maybe the mechanics are exaggerating?
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav______________________JOURNAL
-Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop AP Headers Euro cat sect 1 Dinan sect 3 BMW Motorsport 4.10 Besian D/A pullies/fan delete WPC rod bearings
-TMS Camber & Subf plates RE Street Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines
-Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Mon, Jun-19-2017, 08:38:19 PM   #6
mercedesc63
Reputation: 0 mercedesc63 is on a distinguished road
Thanks all.
Two jobs that aren't diy if it's the diff seal/plate and oil pan gasket.
I paid like 600 for the diff seal to be replaced and while your down there you need to make sure you check the bushings and replace if necessary. No need to rebuild/replace the diff in most cases.
Jump to top mercedesc63 is offline   Reply With Quote
Old Mon, Jun-19-2017, 09:03:43 PM   #7
m3e46freak
M3 Freq
m3e46freak's Avatar
Reputation: 0 m3e46freak is on a distinguished road
Germany
Bro you can find a low mileage ENTIRE diff for 500/600 on the forums here or other, or eBay.
Rock Hard Abs Racing
KWV2!
18X10 CCW CLASSIC!
CPI Headers!
RESONATORS AND SUPERSPRINT!
DINAN!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
Jump to top m3e46freak is offline   Reply With Quote
Old Mon, Jun-19-2017, 10:32:13 PM   #8
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
No, the diff should not weep. My input weeped and I replaced all the seals. The side shafts never leaked oil. There is an o ring between the diff body and the flanges, there rod a rotating seal between the shaft and flange. There is even a special seal that goes on 2 of the 8 flange bolts because they connect with oil inside. No leakage
Jump to top schoonerm3 is offline   Reply With Quote
Old Mon, Jun-19-2017, 10:40:31 PM   #9
ThunderMoose
Mine weeped. I just lived with it but it didn't leave spots on driveway.
#67 2017 NASA TX TT3 Champion
Old Mon, Jun-19-2017, 10:57:44 PM   #10
sev
Reputation: 0 sev is on a distinguished road
getting my pinion seal and half shaft seals done for ~500 tomorrow. I bought my low mileage m3 with the pinion seal slightly leaking, now it's hemoraging.
Sev - 05 M3, Silver Grey 6 speed/Black Nappa, 01 Z3 Mcoupe, S54 Titanium Silver/Black Nappa
Jump to top sev is offline   Reply With Quote
Discussing Leaky Rear Diff - $1,100 sound fair? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
