Old Sun, Jun-18-2017, 06:37:17 PM   #1
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
Default Vac rod bearings, are the coated stock or not?
I always thought they were coated stock bearings but it has come to my attention that they non lower/ upper designated.. So surely that means they cannot be coated stock.
I avoided these bearings because I thought they were stock and coated so therefore had reduced clearance. Anyone's input out of interest?
I have bought OEM and will use them
Jump to top schoonerm3 is offline   Reply With Quote
Old Sun, Jun-18-2017, 06:42:34 PM   #2
ZiMMie
Reputation: 0 ZiMMie is on a distinguished road
Germany
Default Re: Vac rod bearings, are the coated stock or not?
I've always used OEM. Just change them every 100k
Sent from my Robin using Tapatalk
#E36S54 #CSLWannabe #TTFS @Mykesf
Jump to top ZiMMie is offline   Reply With Quote
Old Fri, Jun-23-2017, 09:58:35 PM   #3
schoonerm3
Ireland
No-one any more information?
Old Fri, Jun-23-2017, 10:41:05 PM   #4
E46Hoonigan
Reputation: 0 E46Hoonigan is on a distinguished road
The VAC bearings do have a coating but I am not sure if the compensated for the added thickness....
Personally, I think the WPC rod bearings are the best route.
Jump to top E46Hoonigan is offline   Reply With Quote
Discussing Vac rod bearings, are the coated stock or not? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
