Old Sun, Jun-18-2017, 05:39:45 PM   #1
aznniche
aznniche's Avatar
Default Brake Pad Positioning
The out brake pad fits flush on the caliper mount, but the inner pad that clips into the piston does not. There's a gap between the pad and mount. Is this normal? I have Akebono pads and noticed this since I bought it years ago.
Trying to diagnose if this is causing brake drag..
Jump to top aznniche is online now   Reply With Quote
Old Sun, Jun-18-2017, 05:57:41 PM   #2
EricSMG
40 something
Default Re: Brake Pad Positioning
I'm not sure what you're describing - perhaps a pic would be helpful here.
That said - the back of the outer pad should sit flush against the caliper and the back of the inner pad should sit flush against the piston - no gaps anywhere.
Discussing Brake Pad Positioning in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
