Old Sat, Jun-17-2017, 10:43:09 AM   #11
VIVAxLAxSTOOL
Reputation: 0 VIVAxLAxSTOOL is on a distinguished road
Default Re: Suspension advice at oem 100k
Has the rear subframe been reinforced? That would be the top of my list. When you take care of that you can also tackle the rear bushings and mounts easily, I have the Powerflex black bushings and the increased stiffness makes the rear of the car feel much more confident. If you can budget it, I would then replace your FCAs with OE BMW or Lemforder parts, that will significantly improve front end feel.
After all that then I would tackle the shocks and springs (unless your shocks are blown, mine were okay up to 130k). I personally recommend the B12 Pro kit as it improved the ride quality, gave the car a nice little drop (but doesn't scrape on everything), and significantly reduced the body roll that I hated. Get the Ground Control or Turner front camber plates and Rouge Engineering makes a great rear shock mount kit. If you want to see pics of my car check out my instagram, jaorugby1990.
IG: jaorugby1990
'02 BMW M3- Blk/Blk, Euro bumper, CSL style diffuser ,BMW SSK, BSW Subs, FabSpeed headers, SGT 200cell cats, SGT SCZA Muffler, Beisan Systems Oil Pump disk
Jump to top VIVAxLAxSTOOL is offline   Reply With Quote
Old Sun, Jun-18-2017, 08:44:06 PM   #12
Rabidfox
Reputation: 0 Rabidfox is on a distinguished road
Steering guibo...might be a hot climate thing but everyone I know local has needed them and it makes the front end feel 10x better. $50 "while I'm in here" insurance during all the other stuff. Prob throw some tie rods in there too if you're anal
Jump to top Rabidfox is offline   Reply With Quote
Old Thu, Jun-22-2017, 12:41:30 AM   #13
thatg
Reputation: 0 thatg is on a distinguished road
my god... this list keeps getting longer, I'm trying to accumulate all of these parts and then get the car ready for the install. I was speaking with someone with an e46 m3 yesterday who seemed pretty knowledgable about these cars. He also mentioned rear subframe reinforcement. I believe this car has had the subframe done under warranty, along with Vanos, and rod bearing. I had the car into a bmw independent shop and they looked over the car very thoroughly and didn't mention finding any cracks. They did find broken rear springs however. The cars suspension feels completely shot, it has 108k miles and approx 70k of those were over NYC roads. The rear end seems to nearly collapse on bumps and make a huge thudding noise. I'm hoping Koni/Eibach setup will eliminate that issue and it isnt infact somehow related to subframe cracks.
Heres my current to-do list as it stands.
Springs/Shocks/struts($930?)
Spring Pads? ($50?)
Shock Mounts? anyone know a part number here?
Strut Mounts? (200 for pair?)
front control arm bushings($100?)
Rear trailing arm bushings($70?)
Flex Disc(the shop found a crack in my current one)($50?)
Steering coupler ($50?)
Is there something else imperative I should be adding to this list. (I'm not anal, but would like the car to be enjoyable to drive. Currently steering does not feel tight the car has a lot of vibration from the suspension, does not feel as fast as it once did. Considering changing out the sparks and coils.) Thanks everyone
Jump to top thatg is offline   Reply With Quote
Old Thu, Jun-22-2017, 04:06:24 AM   #14
https://www.ecstuning.com/BMW-E46-M3...r/Shock_Mount/
Check that page for RSMs. For your needs, stock style are more than adequate despite people probably suggesting aftermarket (yes, I have aftermarket).
I think a lot of people let their suspension go 100k and then are upset the stock rubber parts are dry, cracked and/or torn, but they're actually very good for 40-60k.
Lemforder, febi/bilstein are good brands. Reinforcement plates are a good idea as are new paper gaskets.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav______________________JOURNAL
-Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped SS V1 S pipe + 200 cell HFC OE sect 2 Supersprint Sport BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings
-TMS Camber & Subf plates RE Street Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines
-Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Thu, Jun-22-2017, 01:21:17 PM   #15
Rabidfox
If you're gonna go through the trouble of doing the flex disk on the drive shaft I'd do the center bearing while you're in there...chances are its seen better days and you gotta do the same shit to replace it as the flex disk.
ECS has steering coupler for $50 and I bought new bolts because I'm anal and have a bad habit of breaking shit (another like $15)
They also have a kit for guibo/center support bearing for like $200 iirc
Old Thu, Jun-22-2017, 02:15:27 PM   #16
m3nt0s
Reputation: 0 m3nt0s is on a distinguished road
Having a new subframe installed is not the same as reinforcement. Make sure to add reinforcement to your list of things to do, and inspect it one more time right before any work is done.
Jump to top m3nt0s is offline   Reply With Quote
Old Thu, Jun-22-2017, 02:38:20 PM   #17
thatg
Is reinforcement something I can DIY? I've done some reading up/ youtube clip watching and I see some kits out there. If there are no cracks does it still make sense to do reinforcement?
Old Thu, Jun-22-2017, 02:40:30 PM   #18
I didn't take cold climates into consideration, so that's possible.
But I don't agree about driving and roads as I beat on my car and roads are not that smooth here.
People who don't live with a freeze/thaw cycle don't know what rough roads are
We have pot holes large enough that your cars body will bottom out if you hit them (fall into them) in the late winter/early spring.
Old Thu, Jun-22-2017, 03:38:25 PM   #19
But we have millions of cars and heavy trucks. It's probably worse up there, but you should see what 30+ million people living in 40 square miles can do to infrastructure!
Old Thu, Jun-22-2017, 04:39:26 PM   #20
///M3 NA
Reputation: 0 ///M3 NA is on a distinguished road
Just installed Bilstein B12 Sport Kit, love it.
- For rear shocks bought Ground Control mounts.
- Purchase front/rear sway bar links, one of my rear ones broke.
- for fronts buy axial bearings, they will be shot
- while installing fronts be careful not to snap xenon leveling sensor attached to the front control arm.
Evolve
Evolve Eventuri
AutoSolutions SSK 30%
RE Transmission Mounts
CDV Delete
Intravee II
Jump to top ///M3 NA is offline   Reply With Quote
Discussing Suspension advice at oem 100k in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
