Old Fri, Jun-16-2017, 08:27:13 PM   #1
thatg
Reputation: 0 thatg is on a distinguished road
Default Suspension advice at oem 100k
Hey all,
Picked up my car a couple of months ago from a friend. It's in a state and needs some work. The suspension is completely shot and I plan to go for the Koni/Eibach setup. The back has a huge thud on medium to larger bumps, the front feels very loose and not what I've come to know on an M car.
I was wondering while I have the car in the shop on the lift if there are any other refreshes you would recommend at the 100 mile mark on a largely all original parts car at 100k miles.
I think I will also be doing the control arm bushings. Are there any parts I should consider to go along with the Koni/Eibach setup like mounts, and which would you guys suggest?
Sway bars? its an 02 should i consider a front strut brace? Any advice appreciated. Thanks.
Jump to top thatg is offline   Reply With Quote
Old Fri, Jun-16-2017, 08:32:22 PM   #2
PITT M3 RR
PA
PITT M3 RR's Avatar
Default Re: Suspension advice at oem 100k
Front control arm bushings, rear trailing arm bushings and check ball joints for play!
Is this a budget fix or a replace it all thing?
S54 E36 BUILD
Old Fri, Jun-16-2017, 08:42:27 PM   #3
Keiser
Reputation: 0 Keiser is on a distinguished road
I'd do Koni Yellows and stock everything else including Springs.
My Cars:
2003.5 e46 Steel Gray/Black SMG Coupe SOLD
2003.5 e46 Jet Black/Imola SMG Coupe SOLD
2008 e90 Interlagos/Beige 6mt Sedan SOLD
2005 e46 Mystic/Black 6mt Coupe SOLD
2015 f80 Sakhir/Black 6mt Sedan SOLD
2002 e46 Tiag/Black SMG Coupe Converted to Estoril/Cinnamon
Jump to top Keiser is offline   Reply With Quote
Old Fri, Jun-16-2017, 08:54:32 PM   #4
PITT M3 RR
PA
PITT M3 RR's Avatar
A pro kit would give a subtle aggressive look. I would def drop a tiny bit atleast. No 4x4!
S54 E36 BUILD
Old Fri, Jun-16-2017, 09:07:26 PM   #5
delvin
Water Champion
Reputation: 0 delvin is on a distinguished road
ECS has kits for front and rear, BMW or one of their pieced together kits. I've heard you can call and sub for different brands with the kits ECS puts together
Jump to top delvin is offline   Reply With Quote
Old Fri, Jun-16-2017, 09:18:37 PM   #6
I don't think you need to do the ball joints unless this is a hobby and $ is not an issue AND you enjoy torturing yourself (fun with the picklefork on the fcas). These ball joints go a long time - mine were fine at 140k but I changed them cause I'm anal.
I'd simply do the fcabs/rtabs, RSMs, spring pads, top hat bearings, shocks, springs. Pull the strut mount pins.
All stock mounts are very good, maybe do limiters on the rtabs. I also would suggest CSL, Dinan or Eibach lowering springs.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav______________________JOURNAL
-Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped SS V1 S pipe + 200 cell HFC OE sect 2 Supersprint Sport BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings
-TMS Camber & Subf plates RE Street Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines
-Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Fri, Jun-16-2017, 11:53:45 PM   #7
thatg
Thanks for the advice everyone, looking at front and rear bushings, I know people recommended the Meyle bushings on here. They go for $70 for the fronts and $50 for the rears. Do i need the whole kits? Should i go for just the oem rubber bits and try to swap them into the existing metal brackets?
https://www.fcpeuro.com/products/bmw...-31126757623my
https://www.turnermotorsport.com/p-3...6-e46-z4-pair/
Does anyone know the part number for the strut mounts and spring pads?
I'd like to get the car slightly lower for a more aggressive look, interested in a set of apex, i like these new FL-5 with the lip, more aggressive than the oem 18s
Old Sat, Jun-17-2017, 12:37:19 AM   #8
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Very dependant on roads and driving. I have done Drivers at ~ 80k miles passenger at ~100k miles and now just had to do the drivers again at 140k miles.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Jump to top Sandeep1212 is offline   Reply With Quote
Old Sat, Jun-17-2017, 06:06:31 AM   #9
I didn't take cold climates into consideration, so that's possible.
But I don't agree about driving and roads as I beat on my car and roads are not that smooth here.
Old Sat, Jun-17-2017, 06:09:00 AM   #10
You're welcome. I would only use Lemforder as the OEM choice if not going with genuine BMW, personally.
Discussing Suspension advice at oem 100k in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
