Old Fri, Jun-16-2017, 02:23:45 PM   #21
Jfbsaratoga
Reputation: 0 Jfbsaratoga is on a distinguished road
Default Re: 2002 e46 m3 post vanos rebuild hesitation at warm start up with video!
Originally Posted by gum1993 View Post
Ok thanks for ur input. If they got the timing of the engine wrong is it bad to drive the car? I mean the car runs fine and I've been driving it to work. Hope that doesn't damage anything.
Good question. I've been told that the vanos will adjust up to 8 of the angle to avoid piston to valve contact. I guess it depends on how off it was. If it was way off, you would have a serious problem with the way the engine runs. If it is a little off, you probably won't notice. I think in your case it is somewhere in between.
Sent from my ONEPLUS A3000 using Tapatalk
Jump to top Jfbsaratoga is offline   Reply With Quote
Old Fri, Jun-16-2017, 05:10:51 PM   #22
gum1993
Reputation: 0 gum1993 is on a distinguished road
Ok I see, ya i don't think my problem is too serious. Almost every morning it starts just like normal without a problem, seems like it happens more when the car is warm but yet again it's very random when it wants to hesitate to start. I'll keep u guys posted on whats going on, I really hope it's nothing major.
Jump to top gum1993 is offline   Reply With Quote
Old Sun, Jun-18-2017, 07:39:52 PM   #23
nervous24
Reputation: 0 nervous24 is on a distinguished road
Hmm interesting, that's good to know! I'll prob show this to the shop when i drop it off. What caused the pressure regulator valve to fail? Was it just installed wrong or was it caused just by coincidence?
100% not installed wrong, just a part that went bad. No information beyond that to share.
Have you done a DIS vanos test or pulled any codes yet?
2003.5 Carbon Black ///M3
Instagram @_weaponM
Jump to top nervous24 is offline   Reply With Quote
Old Sun, Jun-18-2017, 09:44:56 PM   #24
02_LSB
Default 2002 e46 m3 post vanos rebuild hesitation at warm start up with video!
OP mentions nothing about cam bolts or chain guide, that means the timing was never affected.
OP, it is not your timing, but could be a million other things.
Check easy stuff first, clean your MAF, I'm also assuming you're running a stock airbox. Check that all ducting is properly tightened.
Ps. The Less good news is that you should've replaced cam bolts and chain guide.
Jump to top 02_LSB is offline   Reply With Quote
Old Sun, Jun-18-2017, 09:54:52 PM   #25
02_LSB
That makes sense about the 8 degrees. When fully retarded camshafts have about 7-10 degrees of freedom, without engaging the spline gear. I actually tried to research of how critical it is to catch the first spline.
Old Mon, Jun-19-2017, 02:11:18 AM   #26
gum1993
No I have not done a dis vanos test. I don't have the equipment to do so. Are local BMW shops supposed to be able to do that? If so I'll take it and get it checked.
Old Mon, Jun-19-2017, 02:20:57 AM   #27
gum1993
Sorry I should of mentioned that my camshaft bolts were replaced both the intake and exhaust side, but my chain guide was not. Also had my spark plugs changed and valves adjusted while they did the vanos work. I personally think it's gotta be something they did wrong or went wrong during the installation.
Old Mon, Jun-19-2017, 02:24:57 AM   #28
02_LSB
Ask them if they used an OE camshaft alignment tool
Old Thu, Jun-22-2017, 07:21:50 PM   #29
gum1993
So the car is at the shop right now and they claim that they took it apart and checked the timing etc which all checked out fine. He said he was getting a code for low fuel pressure. He looked at the fuel filter and claims it needs to be replaced. They replaced the fuel filter but the car is still having hesitation to start. He is trying to do the relearn process on the car but it's not letting them since it's saying dmtl pump failure. They are saying they want to replace that so they can do the relearn process. What exactly is going on? I'm getting confused and frustrated. Am I getting ripped off? What idea dmtl pump?
Old Sat, Jun-24-2017, 12:01:20 AM   #30
K0nArtist
Reputation: 0 K0nArtist is on a distinguished road
Dmtl is the device that checks the fuel system for leaks and sets the check engine light if it finds a leak. It's not super advanced on the e46 , I don't understand what your shop is telling you. If they are confident it's not the timing or vanos work related it might be your fuel pump.
Jump to top K0nArtist is offline   Reply With Quote
Discussing 2002 e46 m3 post vanos rebuild hesitation at warm start up with video! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
