Old Sun, Jun-11-2017, 09:16:34 PM   #1
gum1993
Reputation: 0 gum1993 is on a distinguished road
Default 2002 e46 m3 post vanos rebuild hesitation at warm start up with video!
Hey guys!
So quick history:
it's a 2002 m3
Almost at 90k miles
Car is manual
Drives with no problem like it should.
So about a month ago I had a knocking sound coming from my vanos which was resolved 2 days ago by rebuilding the vanos (consisted of besian anti rattle kit with rebuild kit and oil pump disk and all new seals) at a BMW shop near by. I picked up the car 2 days ago and right when I started it, the car hesitated to start. I drove the car and it drove just fine. Next morning I go out and crank it and it cranks but doesn't start, second try it fired right up. Now this happens randomly where sometimes it hesitates and sometimes it fired right up. The shop says it needs time to get used to all the new parts but to me that sounds like b.s.
Oh and a side note I told the shop to change my oil and they over filled it by a quart and half. They drove it over 100miles with the over filled oil in it. Do u think that has anything to do with it ? I really appreciate ur guys help and I hope we can figure this out!
VIDEO:
Jump to top gum1993 is offline   Reply With Quote
Old Mon, Jun-12-2017, 02:31:04 AM   #2
gum1993
Default Re: 2002 e46 m3 post vanos rebuild hesitation at warm start up with video!
Bump guys I'm sure someone has had experience with this
Old Mon, Jun-12-2017, 03:06:27 AM   #3
K0nArtist
Reputation: 0 K0nArtist is on a distinguished road
The shop you took it to did the vanos, overfilled the oil and told you car needs to get used to it but they drove it a 100 miles. Sounds like the shop messed up your vanos rebuild and oil change.
Jump to top K0nArtist is offline   Reply With Quote
Old Tue, Jun-13-2017, 02:37:15 AM   #4
gum1993
Well they didnt really mess up my vanos, that part got fixed. My car was making a loud knocking noise from the engine, it sounded like a diesel but that got fixed. now it takes two cranks for it to start. I really dont know if the shop caused it or it was just coincidence. I wanna know could this be caused because of the vanos?
Old Tue, Jun-13-2017, 03:31:04 AM   #5
K0nArtist
You said you picked it up and right away it had a hesitation problem they did a fair amount of work on it. What are the odds it's a coincidence?
Old Tue, Jun-13-2017, 05:14:48 PM   #6
nbriggs1988
Reputation: 0 nbriggs1988 is on a distinguished road
FWIW, when I was swapping my new(er) S54 in last year, I just did the Beisan Seals (should've done the whole anti rattle fix) and I felt like it took a couple weeks for the vanos seals to break in. I had some vanos rattle for a few weeks and it gradually went away. My theory is the new O-rings we're seating in. Hope your noise goes away, double check your cam bolts and rod bearings if you haven't already!
Sent from my HTC 10 using Tapatalk
Jump to top nbriggs1988 is offline   Reply With Quote
Old Tue, Jun-13-2017, 08:16:45 PM   #7
gum1993
Yes, that's what I'm thinking. Also I did have the cam bolts changed since they were all loose. I called the shop back and he said to bring it in next week and he will recheck all the work. I really hope it just goes away on its own and I don't have to mess with it anymore. The car was sitting for over a month not being driven so I really miss it haha. We will see.
Old Tue, Jun-13-2017, 09:18:01 PM   #8
redline8000
M-Power Hungry!
redline8000's Avatar
Reputation: 0 redline8000 is on a distinguished road
I will be honest to say that any shop who is careful and is familiar with working on BMW cars, nonetheless an M car should know enough that the car takes 6.9 Quarts of motor oil specifically made for the car. The fact in itself alone that they overfilled your engine by 1.5 quarts says they are idiots (excuse my French).
A healthy BMW engine with no issues should have absolutely no hesitation when starting up warm, cold, hot, semi-warm, semi-cold, sitting for a day, sitting for an hour or even sitting for months or years.
It sounds like something may be wrong.
Any internal work on this car is one I would absolutely never cheap out on.
GL buddy...
“Everything is determined…by forces over which we have no control. It is determined for the insect as well as for the star. Human beings, vegetables, or cosmic dust—we all dance to a mysterious tune, intoned in the distance by an invisible piper.”
—Albert Einstein --- Quoted in interview by G.S. Viereck , October 26,1929. Reprinted in “Glimpses of the Great”,1930.
Jump to top redline8000 is offline   Reply With Quote
Old Tue, Jun-13-2017, 09:22:10 PM   #9
K0nArtist
He has a hesitation starting problem not noise, am I correct op?
Old Tue, Jun-13-2017, 11:58:53 PM   #10
gum1993
Yes sorry for the confusion but yes I'm having the hesitation with the car starting after I got the vanos rebuilt which the sound is gone now.
Discussing 2002 e46 m3 post vanos rebuild hesitation at warm start up with video! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
