Old Tue, May-23-2017, 03:17:35 PM   #1
R1pilot
Reputation: 0 R1pilot is on a distinguished road
Default Connecting rod bearing torque question
Car has a July of 2004 build date.
Quick stupid question. Do you torque the bolts as follows:
Bolt 1 to 5nm
Bolt 2 to 5nm
Bolt 1 to 30nm
Bolt 2 to 30nm
Bolt 1 105 degrees
Bolt 2 105 degrees
Or
Bolt 1 to 5nm
Bolt 2 to 5nm
Bolt 1 to 30nm
Bolt 1 105 degrees
Bolt 2 to 30nm
Bolt 2 105 degrees
I was going to do it the first way as I have two torque wrenches but the I realize that I can do it the second way as my SnapOn has the torque then angle feature.
I have to figure out if I can set the SnapOn to do torque, torque, angle, angle.
Thanks.
Jump to top R1pilot is offline   Reply With Quote
Old Tue, May-23-2017, 04:40:57 PM   #2
Tp///M3
Got ///M?
Tp///M3's Avatar
Reputation: 0 Tp///M3 will become famous soon enough
Laos
Default Re: Connecting rod bearing torque question
Bolt 1 to 5nm
Bolt 2 to 5nm
Bolt 1 to 30nm
Bolt 2 to 30nm
Bolt 1 105 degrees
Bolt 2 105 degrees
Or
Bolt 1 to 5nm
Bolt 2 to 5nm
Bolt 1 to 30nm
Bolt 1 105 degrees
Bolt 2 to 30nm
Bolt 2 105 degrees
Thanks.
I did the first option of the above and I used multiple torque wrenches also. The angle was used with Snap On torque. It seems to be holding over 4k miles so far. Will get oil analysis on the next oil change.
04 CarbonBlack/ImolaRed
Jump to top Tp///M3 is offline   Reply With Quote
Old Tue, May-23-2017, 05:07:07 PM   #3
gabylonfive
gabylonfive's Avatar
Reputation: 0 gabylonfive is on a distinguished road
I did mine the first way also - used a 3/8" torque wrench for settling and initial torque and a 1/2" snapon techangle for angle torque.
2004 6MT M3 Coupe [Alpine White// Cinnamon]
2008 6AT Cobb Stg2 335i Sedan [Alpine White // Saddle Brown]
2001 5MT 330i Sedan Track Car[Jet Black // #318]
Jump to top gabylonfive is offline   Reply With Quote
Old Tue, May-23-2017, 05:26:41 PM   #4
R1pilot
Perfect. Thanks guys.
I have to do this tonight.
Old Tue, May-23-2017, 08:08:39 PM   #5
And then loosen/repeat!
Old Tue, May-23-2017, 08:18:13 PM   #6
Tp///M3
Got ///M?
Tp///M3's Avatar
Laos
Obioban,
I thought I saw you mentioned this on one of your posts, you repeated 4 times instead of 3. Is there an advantage on this and how many times are allowed on the bolt? Thanks.
Old Tue, May-23-2017, 08:26:08 PM   #7
Originally Posted by Tp///M3 View Post
Obioban,
BMW says to do it 3-5 times. I'm sure 3, 4, or 5 would be fine. But, 4 is the most in the middle of the three
Old Tue, May-23-2017, 09:26:53 PM   #8
R1pilot
Yep! Hopefully it goes smoothly. I have everything ready waiting for me.
Old Sun, Jun-18-2017, 12:31:01 AM   #9
R1pilot
Finally today I had a chance to change the bearings, I am glad I stopped driving the car when I did ...
I stopped driving the car on Thanksgiving of 2016 after my last oil analysis. I am sure I would have spun #5 if I drove it another week. Crank was OK.
Car has 95k miles, MY2004 and quite a few track days.
Thanks for all the help guys and the amazing DIYs.
Old Sun, Jun-18-2017, 01:30:39 AM   #10
Ridgey
Reputation: 0 Ridgey is on a distinguished road
Crazy that the #5 bearing looks like a straight up penny and the others are pretty normal.
Jump to top Ridgey is offline   Reply With Quote
Discussing Connecting rod bearing torque question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
