Old Thu, Jan-26-2017, 10:37:14 PM   #41
Default Re: CMP Auto Engineering subframe kit
Completely agree ^
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · no nav____________________JOURNAL
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped · SS V1 S pipe + 200 cell HFC · OE sect 2 · SS Sport · BMW Motorsport 4.10 · Besian · RE pullies/fan delete · WPC rod bearings · TMS Camber & Subf plates · RE Trans Mounts · AKG poly SUB/DIFF · SDW RTAB · ZHP knob + UUC DSSR · GroundControl S/A (Koni/Eibach 440/550) + tall RSMs · OE CSL trunk · APEX 75mm Studs · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · ss brake/clutch lines · Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · Clarion 10"
Old Thu, Jan-26-2017, 11:26:30 PM   #42
STAATS
STAATS's Avatar
Full disclosure I am a Mechanical Engineer and I did spend 3 years designing and building FSAE cars (admittedly I was the Drivetrain lead and then Project Manager and not directly involved with Chassis).
Also for my particular project I have decided on Redish Motorsport Reinforcement Plates and then VinceBar front bolt-throughs and Mason Engineering GTR bar for the rear... this is currently based on the level of fabrication effort I am planning on... not based on what is best for all...
Overall the RACP has 3 "places" that need to be dealt with:
- Front Mounts
- Rear Mounts
- Under-body reinforcement
The options (mainly) play out as such:
Under-body reinforcement:
- Redish Motorsport reinforcement kit (highly recommended)
- Turner Motorsport reinforcement kit (good option if you want to use epoxy method)
- Custom reinforcement plates
Front Mounts:
- VinceBar Front bolt-throughs (welding and epoxy options)
- Straight bolt through (custom)
Rear Mounts:
- VinceBar (welding and epoxy options)
- CMP bar (welding only)
- Mason Engineering GTR or X brace (bolt in)
Note: there is also the structural foam but that is an additional option to any of the above methods really
For any of the above 3 "places" that need to be addressed you only need to pick one option from the list of available options, there is no requirement to double up on any options (except addition of the foam maybe)
STAATS
Old Thu, Jan-26-2017, 11:54:33 PM   #43
That's a good recap of where we are right now option wise. I've done TMS plates, planning on Mason GTR bar next, then the front mounts either Vince or make my own thing.
Old Sun, Jan-29-2017, 05:18:47 AM   #44
AussieE46M3
Reputation: 0 AussieE46M3 is on a distinguished road
Afternoon guys,
Sorry I haven’t been present here, I've kept myself busy during this Australia day weekend.
Or they were just stiffening up the chassis for homologation purposes (seeing as that was the point of the road going GTR in general)
Possible. I’m not familiar with the regulations so I couldn’t confirm or deny. I couldn’t imagine there’d need to be a factory brace to do bracing for a race car.
Hi Staats,
I don't really want to do my Australian brother out of a sale here but I think if you are going to get the Mason Engineering GTR Rear Strut setup then there is no huge push to get the CMP subframe support or the VinceBar for the rear as well (the Mason Engineering GTR bar does a very similar job it just sends the loads through the strut towers down into the chassis rail... it isn't the most elegant solution but as it is triangulated between both strut towers and you get the added bonus of additional torsional rigidity it makes it a pretty good option + no welding)... at that point if you did a bolt-through at the front (using Vince's method or any number or the other methods) and had reinforcement plates (strongly recommend Redish Motorsport over anything else) then you have dealt with the issue... well as best we know how at this point...
If you are going to go to the effort of a weld in system such as the CMP system and modification of a ready to bolt in solution like the Mason Engineering GTR bar then you might be better off scraping both ideas and getting the fabricator/welder you had planned to weld in your CMP kit / modify your GTR bar to instead custom fabricate you a Road GTR type bar (but take the time when you are there to add the additional insurance of a support between the chassis rail and the bottom subframe bolt point of the GTR bar (essentially emulating the CMP or VinceBar type solution)
I did at a time consider doing the VinceBar and Mason Engineering GTR bar in parallel but the cost to benefit just isn't there providing you have Redish Motorsport plates and add a solution for the front mounts (ie bolt throughs)... Yes the GTR bar
I’d agree with your earlier statement. I have had a few enquiring whether it is possible to install a Mason brace above our kit. I have advised it is not compatible or necessary.
Should it be desired, an experienced fabricator could easily fit a GTR style brace linked to a section of extended vertical tube atop our kit at a relatively reasonable cost. Lighter tube section could also be utilised as the ‘subframe’ is already reinforced.
I personally was not convinced on the strut towers to ‘subframe’ braces available (A chassis member known to flex and fail linked to a shock tower known to mushroom). That as well as boot space, is the reason we chose to develop a kit of our own. I understand the truss configuration is rigid however, where it transfers the load to was deemed not ideal. We have even had enquiries by some considering converting to our system.
Our kit doesn’t just support point loads, it adds rigidity across the entire width of the RACP using a UB layout and ties into the much thicker (4mm) and more rigid chassis rails rather than the shock towers (1.6mm).
The kit also links directly to the female thread insert within the RACP and does not overly compromise boot space which was also a design consideration.
The benefit of the brace above our kit is mostly to reinforce the shock towers and support the suspension point.
Our kit is fully laser cut and CNC brake press bent. It would offer superior precision, guaranteed fitment and a faster turnaround for those offering to repair chassis failures. It is also DIY friendly for those intending to install it themselves.
I too am a mechanical engineer and briefly took part in my Universities FSAE Team.
Our kit does require a reasonable amount of fabrication however, it is necessary to achieve the strength it offers. I personally work in the structural steel industry and am experienced and have access to an abundance of welders, tools etc so the necessary fabrication was not daunting.
We do intend to develop a method of further reinforcing the front mounts in future as well as our own underside plates and strut braces.
Jump to top AussieE46M3 is offline   Reply With Quote
Old Sun, Jan-29-2017, 08:09:57 AM   #45
STAATS
STAATS's Avatar
Haha I thought you might have been just judging by the level of thought and effort you put into your design it just had FSAE graduate written all over it...
What team were you on? I was Curtin Motorsport Team 2008-2010.
I definitely think if the fabricating side isn't a big imposition for you then the weld in solutions for the RACP (like your solution and the VinceBar) are definitely better than the Mason Bar...
TBH I am kind-of annoyed I discovered them AFTER I had done my Redish plates install as it would have been easy enough to do it then while I had a welder/fabricator doing the plates...
But alas I missed out and now I am trying to reduce labour costs wherever possible by doing it myself and basically the only thing I can't do myself is welding haha so as a result I have basically been relegated to the Mason GTR Bar and E&R Vince front bolt throughs... (also the loss of boot space is no biggie for me in my particular build)
For anyone that has done nothing to their RACP so far I would recommend Redish Plates, CMP or VinceBar (this is somewhat preferential depending on how OCD you are really) for the rear and Vince bolt throughs at the front.
STAATS
Old Sun, Jan-29-2017, 10:48:40 PM   #46
AussieE46M3
Morning Staats,
Thanks mate. I wasn't heavily involved. I constantly struggled to find time.
Griffith Racing Team on the Gold Coast.
A few have said that. The prep work is the most time consuming aspect. The welding itself can be done in just over 2 hours if using a MIG. The install can be done cheaply if the prep were done in a DIY fashion and an experienced welder contracted when needed.
The kit can be installed in the vehicle while it's on all 4 wheels however, it still would be easier to do so when plates are going in as all the equipment would be present.
Thanks for the support Staats. Best of luck with your build. I haven't had a thorough read of your road rally thread but I'm keen to see where you go with it. It's a goal of my own to build something similar.
Regarding the front mounts, Do you believe a bolt through system is required in addition to a top side reinforcement? The combined moments under engine load applies an upwards force into the chassis on the front right mount. The force would be transferred through the bushing to RACP interface.
I did not intend to include a bolt through design for our front mount top side reinforcement when we get to that stage. Is there something I may have failed to consider?
Old Sun, Jan-29-2017, 11:15:02 PM   #47
M3_Aaron
Reputation: 0 M3_Aaron is on a distinguished road
Italy
Nice to see a local offering. All the best with it.
E46 M3 Journal
Jump to top M3_Aaron is online now   Reply With Quote
Old Tue, Jan-31-2017, 07:46:04 AM   #48
AussieE46M3
Thanks Aaron,
Your car looks phenomenal!
Old Thu, Feb-02-2017, 01:33:54 AM   #49
Beamrup
Reputation: 0 Beamrup is on a distinguished road
Ok. So.....updates. AussieM3 is hooking me up with a CMP bar that has extended tube connections to the rear subframe mounts.
Im ditching the Mason Bar idea. Instead, Lang Racing is going to replicate the OEM bmw GTR bar by connecting to the cmp extensions. Im also installng the Vince Front kit.
Ill provide pics and updates when I git'r'done
Jump to top Beamrup is offline   Reply With Quote
Old Sat, Feb-04-2017, 04:58:32 PM   #50
jdev
Reputation: 0 jdev is on a distinguished road
Morning Staats,
Having fabricated and done the install, and seen the failures the rear end has under the surface of sealant and sheet metal, I am telling everyone factually that unless you disassemble the rear end you will not address the stress failures and resulting stress risers in your chassis.
Second, reinforcement plates to add thickness and distribute load of the thin and low strength sheet metal that the loads are transferred through should be strengthened. The warping you will find in the front right mount is evidence of the inadequacy.
Third, the front subframe mounts have to be addresssed. Failures in the top below the floor are common. Like mentioned the upward and simultaneous twisting force is significant. Since there is no data yet that indicates the level of force or stress cycles to cause the the Vince bar, combined with the prescribed front mount reinforcement to fail, consider that the extra strength of the cmp bar may or may not be useful over Vince's whole prescribed solution. The front mounts need to be repaired first and and strengthened with the Vince bar, and I wouldn't install the cmp bar without addressing them either.
02 Silver/Red
Jump to top jdev is offline   Reply With Quote
e46, racp, subframe, subframe failure, subframe reinforcement
Discussing CMP Auto Engineering subframe kit in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
