Old Thu, Dec-29-2016, 04:41:20 PM   #1
Exclamation e46 M3 Special Tool Rental thread
Feels like this is something we should have on this forum! I'll make it a Sticky after a couple days, but at first going to leave it as a normal thread to get some eyes on it.
I'm going to make the 2nd (USA)/3rd (Europe)/4th (ROW) posts in this thread a directory of tools. To get on (or off, if the tool breaks) the list, PM me (or I likely won't see it) the following:
1) What the tool is
2) BMW made or aftermarket made
2) deposit fee
3) rental fee (including shipping within the continental USA)
4) rental duration
5) Country in which you're located
6) Optional: link to thread/tool, to clarify what it is
Assuming you have a sufficient number of non spam/non pointless posts, and your iTrader isn't negative, I'll add you to the list.
I'm not going to suggest any prices, but I would highly recommend that the deposit fee you require is sufficient to cover the tool, if it goes missing or gets broken. I would also suggest not renting to members with low post counts/negative iTrader reviews. As for renters, I would recommend insuring the tools being returned for the deposit fee.
Transactions should go as follows: Entire deposit fee is sent by renter to tool owner. Tool is inspected by renter for damage immediately upon receipt, used, returned within the specified period, inspected for damage immediately upon return, and the deposit is refunded minus the rental fee. If damage has occurred to the tool, the amount required to make the tool whole again should be deducted from the deposit. Shipping should be paid in each direction by the person doing the shipping.
To rent a tool, PM the member with the tool directly.
To rent out a tool on this thread, you must meet the criteria for selling in the FS section.
Old Thu, Dec-29-2016, 04:41:28 PM   #2
Default USA
Format: User, brand (BMW/aftermarket brand), deposit, rental, duration
Engine:
VANOS Pressure tester
User: idntknow2005, Brand: home made, deposit: $125, rental: $15, duration: 2 weeks
Valve adjustment kit (shim kit, shim tool, feeler gauges)
User: Obioban, Brand: BMW, deposit: $500, rental: $50 (plus $20 per shim used not replaced with new, BMW shims, duration: 3 weeks
User: mcfreid, Brand: WiseCo, deposit: $150, rental: $50 (plus $5 per shim uned and not replace with new), duration: Negotiable
S54 timing tools (crank pin, timing bridge, cam pin(s), spacers that go between head and vanos unit, fan clutch tool
User: Obioban, Brand: BMW, deposit: $400, rental: $50, duration: 3 weeks
S54 timing tools (crank pin, timing bridge, cam pin(s), 24mm wrench (cam shaft), 7mm/11mm wrenches for splines, 32mm socket (crank), chain tensioner socket, fan clutch tool
User: 02_LSB, Brand: Mixed, w/BMW timing tools, deposit: $250, rental: $50, duration: 2 weeks
S54 timing tools (Crank Pin, Camshaft Alignment Tool, (1) Alignment Pin)
User: DJAM3, Brand: BMW, Deposit: $170, rental: $30, duration: 2 weeks
S54 timing bridge with two pins
User: legacyej25, Brand: BMW, deposit: $200, rental: $25 duration: 4 weeks
User: sergbaja5t, Brand: BMW, deposit: $160, Rental: $60, Duration: 3 weeks
S54 Vanos Rattle Tools
User: legacyej25, Brand: Beisan, deposit: $30, rental: $10 duration: 4 weeks
Chassis:
Front Suspension:
Rear Suspension:
RTAB tool
User: DJAM3, Brand: MIS, Deposit: $80, rental: $25, duration: 2 weeks
Rear Wheel Bearing and Hub Tool
User: ThrowinShapes, Brand: SIR Tools, deposit: $360, rental: $55, duration: unlimited, link
Rear ball joint tool
User: Obioban, Brand: Koch, deposit: $500, rental: $60, duration: 3 weeks
Rear axle puller tool (pulls the axle in to the hub
User: Obioban, Brand: Klann, deposit: $300, rental: $50, duration: 3 weeks
Electronics:
Other:
Old Thu, Dec-29-2016, 04:41:34 PM   #3
Default Europe
reserved, in case people in europe want to get in on this
Old Thu, Dec-29-2016, 04:41:45 PM   #4
Default Rest of World
reserved, in case people in the rest of the world want to get in on this
Old Thu, Dec-29-2016, 04:46:20 PM   #5
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
Default Re: e46 M3 Special Tool Rental thread
Great idea, Obioban. Definitely looking forward to this as I can only imagine how many people would rather rent than buy twin-tube structural foam guns and diff bushing pullers.
Jared's Daily/Track '02 M3 Convertible: http://www.m3forum.net/m3forum/showthread.php?t=545658
Jump to top JaredMV is online now   Reply With Quote
Old Thu, Dec-29-2016, 04:46:21 PM   #6
idntknow2005
idntknow2005's Avatar
Reputation: 0 idntknow2005 is on a distinguished road
I will rent out my vanos pressure tester.
125 deposit, 110 dollars would be refunded when returned in good working order
2001 E46 ///M3 - LSB+ on Cinnamon - Full Restoration "Brought back from the dead"
Jump to top idntknow2005 is offline   Reply With Quote
Old Thu, Dec-29-2016, 05:20:23 PM   #7
ThunderMoose
Subframe Bushing Tool
User: Thundermoose, Brand: Koch, deposit: $300, rental: $50, duration: 3 weeks
Front Hub Tool
User: Thundermoose, Brand: BMW, deposit: $150, rental: $25, duration: 3 weeks
Foam Applicator
User: Thundermoose, Brand: Unknown, deposit: $25, rental: $25, duration: 4 weeks
#67 2017 NASA TX TT3 Champion
Old Thu, Dec-29-2016, 05:25:57 PM   #8
If you wish to be included in the thread, pm me the info requested.
Old Fri, Dec-30-2016, 03:03:14 AM   #9
ThrowinShapes
ThrowinShapes's Avatar
Reputation: 0 ThrowinShapes is on a distinguished road
PM'ed. Great idea, thanks for putting this together!
[06' AW/Cinnamon] [6MT] [Slicktop] [Manual Seats]
Journal - Update 2017-02-28
FS: Center Console | US Headers / Rear O2 | Rent: SIR B90-BMW Rear Wheel Bearing Tool
Jump to top ThrowinShapes is offline   Reply With Quote
Old Fri, Dec-30-2016, 12:44:16 PM   #10
First batch added.
Also, feel free to PM me even if the tool in question is already added-- having multiple people renting out each is not a problem.
Discussing e46 M3 Special Tool Rental thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
