Old Thu, Apr-07-2016, 06:49:11 AM   #21
Flow
Flow's Avatar
France
Default Re: For all you torque wh0res
Originally Posted by cyberlando View Post
Sure thing man!!! I can convert manually for now lol
Just let us know when you update it....Im sure you literally and single handedly saved many people lots of time doing research!
Thanks again man!
Sent from my SM-N910F using Tapatalk
No problem. So much information here that I can only contribute
Originally Posted by Dal View Post
This is just awesome, well done Florian!!
Thank you ! Don't hesitate to share it on m3cutters. Not sure I have an account there.
Also, not sure of how to handle updates to this file. Maybe you could update it on m3cutters when it gets updated here ?
Originally Posted by KubinB View Post
thank you
No problem
Originally Posted by ThrowinShapes View Post
Wow, that looks like a lot of manual labor! Nice work.
You're welcome
Originally Posted by M3GA View Post
Amazing work OP and a huge contribution!
+1 for ft lbs version
I'll to the ft lbs version very soon. I'll update this thread then.
Originally Posted by Amadeus View Post
That is awesome thank you. Just curious, is there a general scale factor for a wet torque, i.e. antiseize?
Well that is a complicated matter. It does not to be a linear thing, AKA small torques should be OK, big torques can get messy real quick.
You can read a lot of things on the web about this, but no definitive answer.
I read somewhere that on small torques, you just make 10% less, and on big torques you can go with factory specs and it should be OK.
Anti-seize is not as bad as lubing the thread. Never use any oil if you cannot use a stretch gauge.
All the lubed threads are jointing torque + angle.
Originally Posted by RedM3/4 View Post
Awesome, thanks!
ADS
No problem
Originally Posted by bimmerfan08 View Post
Great work OP. When you add the ft-lbs values, can you leave the Nm values on there too? Not that's it difficult to convert between the two units, but it's convenient to already have them laid out.
Yes, I will keep both. Easier to have just one file to update if there is a mistake / new torque to add.
Originally Posted by Lightship View Post
Bloody brilliant! Thanks man!
My pleasure
Originally Posted by marioec View Post
awesome thanks !!!
Happy to contribute
Originally Posted by Raw///M View Post
Amazing amount of detail, thank you so much so sharing.
You're welcome
2004 M3 TiAg / LSB SMG
Old Thu, Apr-07-2016, 07:19:58 AM   #22
w3fl3x
...yummy...
w3fl3x's Avatar
Reputation: 0 w3fl3x is on a distinguished road
Nice! Thank you for putting all the torque specs on there! I will have to print this out and put into a three ring binder. It'll go right next to the Bentley on my shelf in the garage!
Thread like this is why I'm more tempted to buy a second e46 m even if people are telling me I'm crazy for thinking about owning two of the same car.
Oh and I was thinking this thread was about torque at the wheel when clicking on the thread.
Jump to top w3fl3x is offline   Reply With Quote
Old Thu, Apr-07-2016, 07:52:06 AM   #23
Flow
Flow's Avatar
France
Yep, wheels to 120 Nm / 89 Ft Lbs
I went through the whole Bentley and wrote down all the torques from there. Some are wrong though since they made it for the regular E46 that has a different differential and so on... Tried to correct it from the TIS.
Tonight I will put the Ft Lbs / In Lbs version here.
Old Thu, Apr-07-2016, 01:20:52 PM   #24
ThrowinShapes
ThrowinShapes's Avatar
Reputation: 0 ThrowinShapes is on a distinguished road
If your going to go through the trouble for this, you may want to go in-lbs for values smaller that 16ft-lbs or so. For example, my 3/8in and 1/4in drive torque wrenches are 5-80ft-lbs and 20-200in-lbs ranges. Or maybe just list both ft-lb and in-lb below a certain torque. I know, crazy Americans
Jump to top ThrowinShapes is offline   Reply With Quote
Old Thu, Apr-07-2016, 02:07:33 PM   #25
SliM3
SliM3's Avatar
Oh this is NICE!! Thanks for sharing your detailed work
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Thu, Apr-07-2016, 04:15:40 PM   #26
Benfro89
Benfro89's Avatar
Reputation: 0 Benfro89 is on a distinguished road
Talking Re: For all you torque wh0res
Good job man I am definitely a torque *****!
We need to keep adding to this and make a complete copy.
-2002 Sapphire Black-M3-SmgII
-Owned by head of EAS used as Display car and primary car
-Now located in Coweta Oklahoma
Jump to top Benfro89 is offline   Reply With Quote
Old Thu, Apr-07-2016, 04:40:57 PM   #27
mgwatson
Reputation: 0 mgwatson is on a distinguished road
You're a good man! Thanks!!
2004 M3 Coupe / 6 spd / Silver Grey / Black Nappa / TMS Reinforcement Plates / AKG RSF & Diff Bushings / GC RSMs / 245/275 Continental DW
Jump to top mgwatson is offline   Reply With Quote
Old Thu, Apr-07-2016, 04:55:08 PM   #28
mlee4984
Slow M3 Driver
mlee4984's Avatar
Reputation: 0 mlee4984 is on a distinguished road
China
Thanks for your hard work! We all appreciate it!
Current: 2005 Interlagos Blau Metallic M3 ZCP
Current: 2014 Citrin Schwarz Metallic M5 ZCP
Gone but not forgotten: 2013 Alpine Weiss X5 3.5i
Gone but not forgotten: 2001 Schwarz M3
Gone but not forgotten: 1997 Estoril Blau Metallic M3
Jump to top mlee4984 is offline   Reply With Quote
Old Thu, Apr-07-2016, 06:18:11 PM   #29
Flow
Flow's Avatar
France
No problem. I was actually wondering when to give ft lb and in lb. You gave me the answer. Very helpful !
No problem
Yes, it should be updated frequently. I'll continue working on it.
Happy to make you happy
Most welcome
Old Thu, Apr-07-2016, 07:36:56 PM   #30
ECSTuning
ECSTuning's Avatar
Reputation: 0 ECSTuning is on a distinguished road
Wow, this is a must have. Thank you!
-James
--edit--
As I'm looking over this I'm overly impressed. This is a seriously awesome reference doc.
Have questions? Need answers? Live Chat us! 8:30am to 12:00am Midnight EST
sales@ecstuning.com | customerservice@ecstuning.com
Customer Service Hours: M- F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172
Facebook | YouTube|OEM BMW Part Number Search
Jump to top ECSTuning is offline   Reply With Quote
Discussing Torque Spec thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
