Old Tue, May-16-2017, 10:15:37 PM   #101
Default Re: Torque Spec thread
Originally Posted by CrookedCommie View Post
Meaning they are single use, when you tighten them down they deform, so you can't effectively reuse them.
I know what Torque to Yield means. Typically a bolt that is used in that application has a angle you turn it after jointing torque. Bolts that have a one shot torque measurement are usually reusable. I've never seem them listed as TTY.
I know this quote is stating head bolts, but still applicable.
How can you tell TTY head bolts from ordinary head bolts? TTY head bolts are typically longer and narrower than standard head bolts. Factory service manuals will tell you which applications use TTY bolts, and you can often tell from the head bolt tightening procedure if the bolts are TTY or standard. TTY bolts typically have an angle tightening specification rather than a specific torque value (which requires using an angle gauge when tightening the bolts).
Old Wed, May-17-2017, 07:31:02 PM   #102
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Both the TIS and the Bentley manual state to use new bolts. Your call.
Old Wed, May-17-2017, 07:37:59 PM   #103
I don't reuse them, but many people do and even retailers like UUC say to reuse their bolts. If you do, a thread sealant is needed. Red loctite is actually a widely popular choice as well (done it many times on my S52 when running a SM flywheel).
For reference the used sets I have here all measure;
Set1: 57.5x-57.6xmm
Set2: 57.55-57.58mm
I need a new bolt to judge if these are stretch or not (I'm thinking no).
Old Wed, May-17-2017, 10:33:14 PM   #104
ThrowinShapes
ThrowinShapes's Avatar
Reputation: 0 ThrowinShapes is on a distinguished road
Ah, I had been looking for that clutch disc wear spec actually!
Jump to top ThrowinShapes is offline   Reply With Quote
Old Mon, Jul-17-2017, 04:06:25 AM   #105
Ridgey
Reputation: 0 Ridgey is on a distinguished road
Beautiful thread. Thanks guys.
Jump to top Ridgey is offline   Reply With Quote
Old Mon, Dec-18-2017, 08:12:15 PM   #106
malacai17
Reputation: 0 malacai17 is on a distinguished road
I'm about to rebuild my calipers, and I noticed that the specs for Front and Rear Caliper Carrier Bolts (16mm head) are different:
Front
http://m3.madrussian.net/diy_front_brake_rotors.shtml
"Apply some anti-seize on the 16mm hex bolts before putting them back in.
Torque the bolts down to 110 nm."
Rear
http://m3.madrussian.net/diy_rear_brake_rotors.shtml
Torque the bolts down to 67 nm."
A separate source states:
http://www.bimmerfest.com/forums/sho...61&postcount=2
"Rear carrier retaining bolts: 48 ft-lb (65 Nm)
Front carrier retaining bolts: 81 ft-lb (110 Nm)"
Can someone with a Bentley manual triple-check this information and confirm? Then we can get the PDF updated so that no one strips (or breaks!) a rear carrier bolt.
Jump to top malacai17 is offline   Reply With Quote
Old Tue, Dec-19-2017, 01:28:50 AM   #107
Da Jemster
Institutionalized User
Da Jemster's Avatar
Reputation: 0 Da Jemster is a jewel in the rough
Here...
2008 E93 - AW - DCT - Stock...for now
2004 E46///CB-BLK///SMG II///D/A tuned///AFE Stg 2///SS Stepped///SS Metallic Cats///Eisenmann SS X-pipe///SS Race///4.10 diff///ACS CF Front Lip///6000K Xenons & Fogs///CF Grills & Gills///Angel Eyes///Clear Corners w/Solaris///Painted Reflectors///Black'd Sides & Tails///TEIN S
Jump to top Da Jemster is offline   Reply With Quote
Old Tue, Dec-19-2017, 01:40:43 PM   #108
malacai17
Originally Posted by Da Jemster View Post
Here...
Thanks!
Discussing Torque Spec thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
