Old Tue, Aug-11-2015, 02:28:49 PM   #11
VinceSE2
FKA VinceSE
Sweden
Default Re: Has anyone else experienced leaking BW/C&R oil cooler?
This is how the under tray looked after a35 mile drive
I have now swapped back to the old OE cooler as I plan on doing a track session this evening. The first since October last year.
Old Tue, Aug-11-2015, 03:46:39 PM   #12
RaviCSF
Reputation: 0 RaviCSF is on a distinguished road
Originally Posted by VinceSE2 View Post
Thank you Ravi for sharing your expertise.
If C&R will not replace my cooler (has been on the car for less than a year and less than 5000 miles) with one with their revised design (i was just made aware that they are revising the design), is my cooler repairable?
I'm thinking a pro radiator tech must be able to cut of the tank, weld the tubes and then weld the tank back on?
Or are the tubes not weldable BC of thinness and the use of adhesives?
I can't give you a definitive answer without seeing the cooler up close and knowing who would be doing the repair job. Your best bet would be to take it to a highly skilled radiator repair facility and ask for their advice. Good luck!
Jump to top RaviCSF is offline   Reply With Quote
Old Tue, Aug-11-2015, 06:09:46 PM   #13
camdinans3
Resident Rabble Rouser
camdinans3's Avatar
Reputation: 0 camdinans3 is on a distinguished road
wait....so you're telling them to pound sand? And you guys are ok with that?
Andrew: AVUS 1995
///95 Supercharged Club
Jump to top camdinans3 is offline   Reply With Quote
Old Tue, Aug-11-2015, 06:34:51 PM   #14
Drewster
Drewster's Avatar
Last I checked , CSF is not C&R...
Old Tue, Aug-11-2015, 06:36:09 PM   #15
camdinans3
camdinans3's Avatar
my bad.
Andrew: AVUS 1995
Old Tue, Aug-11-2015, 08:47:30 PM   #16
VinceSE2
FKA VinceSE
Sweden
Via BimmerWorld C&R let me know that they can't do anything for me as the cooler is 8 months out of the 12 month warranty.
That means they chose to ignore the fact that I installed it 4 months after the purchase and that my car (and the oil cooler) has been sitting on jack stands for 4 months. Not impressed by their customer care!
I guess this is what you get for paying a premium.
Had I had a CSF oil cooler I would have been fine as their warranty is 24 months. And from what I understand it is also a tougher, more robust, design.
It's pretty ironic as i had plans for the C&R water cooler to complement the C&R oil cooler (could have needed a set of higher capacity coolers on the track this evening).
Now it may be a set of CSF coolers, or custom/repaired C&R oil cooler.
Old Fri, Aug-14-2015, 09:21:05 PM   #17
VinceSE2
FKA VinceSE
Sweden
As the radiator techs told me this kind of leak demands replacement of the core in order for the repair to be "solid", I have now placed an order for the CSF oil cooler.
Essentially the tube and fin core used by C&R seems to be to flimsy/fragile. So I opted to go for the more sturdy bar and plate core of the CSF cooler.
It also feels good that CSFs warranty is double that of C&R.
Old Fri, Aug-14-2015, 11:12:09 PM   #18
GrendelsbaneM3
GrendelsbaneM3's Avatar
Reputation: 0 GrendelsbaneM3 is on a distinguished road
Is this the CSF oil radiator you purchased?
http://www.rogueengineering.com/rogu...-E46M3-OC.html
Cheaper than the C&R oil and Mishimoto oil coolers.
2004 Silver M3 / SMG / Koni Yellow shocks and struts / Vogtlands lowering springs / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / Laser Interceptors / Clear Bumper Reflectors / Mishimoto Aluminum Radiator / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune
Jump to top GrendelsbaneM3 is offline   Reply With Quote
Old Sat, Aug-15-2015, 06:57:42 AM   #19
VinceSE2
FKA VinceSE
Sweden
Yes, that is the one I have ordered.
Old Wed, Aug-26-2015, 03:49:01 PM   #20
VinceSE2
FKA VinceSE
Sweden
Default Has anyone else experienced leaking BW/C&R oil cooler?
And today the CSF bar & plate oil cooler arrived.
It's very sturdy, but unfortunately also noticeably heavier. I don't have a scale, but I would guesstimate about 50% heavier.
Discussing Has anyone else experienced leaking BW/C&R oil cooler? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
