Old Sat, Apr-16-2016, 01:50:00 AM   #91
10speed
Reputation: 0 10speed is on a distinguished road
Default Re: Has anyone else experienced leaking BW/C&R oil cooler?
sub'd for updates for the new C&R oil cooler.
Jump to top 10speed is offline   Reply With Quote
Old Thu, Jul-21-2016, 07:45:02 PM   #92
Brian N
wubalubadubdub
Brian N's Avatar
Just thought I would update this thread. The new coolers are up on the site for 15% off this month.
-My Journal-
Jump to top Brian N is online now   Reply With Quote
Old Thu, Jan-05-2017, 06:40:04 PM   #93
///mtree
Reputation: 0 ///mtree is on a distinguished road
Anyone have experience with the new design of the oil cooler?
Jump to top ///mtree is offline   Reply With Quote
Old Thu, Jan-05-2017, 07:55:10 PM   #94
BTB
BTB's Avatar
Default Has anyone else experienced leaking BW/C&R oil cooler?
Done one track day with mine, seems to work pretty well. It was ~85 deg F outside and while the oil heated up to 220 or so I didn't have any issues. At least not noticeably different than the original one in my experience. I don't have any hard data really
My Journal
Old Sun, Jan-08-2017, 05:30:30 PM   #95
///mtree
Thanks for the response! Since you had the original leaking version, does this redesign look like an improvement on the weak points?
I hope bimmerworld will chime in on this thread about the redesign.
Old Sun, Jan-08-2017, 07:28:32 PM   #96
BTB
BTB's Avatar
Word I hope so too.
I'm guessing part of the original's problem was that it mounted onto the radiator via rigid tabs welded to the frame of the cooler. Over time, bumpy roads would shake the thing so much that the core fins/cooling passages came apart from the frame. The new one uses the stock shroud so this shouldn't be a problem. The BW website states the new one has "30% greater cooling capacity at half the weight of stock part", that sounds great but I just hope its durable as well. Unfortunately my cars had a few unrelated issues since installing the new cooler so I've only put on about 5k miles. Its held up so far but I haven't used it in the cold yet.
My Journal
Old Sun, Jun-18-2017, 04:11:17 PM   #97
craftyvtec
Reputation: 0 craftyvtec is on a distinguished road
So it's Sunday morning and I'm back home from a race weekend which I was not able to race due to a bad BW CR oil cooler, this is my second cooler they sent me. I did not race last year, this cooler has exactly six races on it and now it's leaking, all the time and money spent to for a race weekend down the drain... I try to buy the best parts possible as per James Clay recommendation however this is a problem and I'm wondering what could be done about it I'm sure I'm out of warranty but there is zero damage on my oil cooler.
2002 M3 Coupe 5MT NASA GTS3 Race car
2003 M3 Coupe 6MT street car
1999 M3 Vert 5MT 27k miles (for Sale)
Jump to top craftyvtec is offline   Reply With Quote
Old Sun, Jun-18-2017, 05:04:54 PM   #98
Brian N
wubalubadubdub
Brian N's Avatar
Was this the new lightweight one or the older one?
-My Journal-
Old Wed, Jun-21-2017, 10:35:24 AM   #99
Argentic
Argentic's Avatar
Reputation: 0 Argentic is on a distinguished road
Bulgaria
I had same experience two oil coolers in the garbage and bunch of excuses from bimmerworld not to replace them
Jump to top Argentic is offline   Reply With Quote
Old Wed, Jun-21-2017, 12:42:04 PM   #100
bjz
bjz's Avatar
Reputation: 0 bjz is on a distinguished road
Spain
I got the lastest version, radiator and oil cooler (PWR Cores) and 0 leaks yet. Crossing fingers... i'm in the other side of the pond and... shippings will kill me, for real.
Jump to top bjz is offline   Reply With Quote
Discussing Has anyone else experienced leaking BW/C&R oil cooler? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
