Old Mon, Jun-19-2017, 02:43:40 PM   #31
mpower22
CPV O-Ring Guy
mpower22's Avatar
Default Re: Running hot in higher temp climates
Exactly on point. Regardless if I was on the fences or not about that topic, it's safe to say I'd go with the guy with 33,000 posts
///M3 - Dream Car: Acquired
15-Year Member
2003 M3Laguna Seca Blue/6MT/Black Leather Cloth Interior/Full [CSL] Exhaust/evolve-R
Old Mon, Jun-19-2017, 02:49:26 PM   #32
RedM3/4
This kind of stuff always gets me going, so my brief research shows:
- Deionized water typically is flowed through resin to remove + ions (Na+, Ca2+), from the pipes (Fe2+, Cu2+); there can be other impurities and residue from the resin itself.
- Distilled water is also deionized.
- Deionized water will become acidic if left open to the atmosphere, as it sucks in ions from CO2 and other sources to find equilibrium. CO2 absorption results in carbonic acid. This doesn't happen instantly, but tells me a bladder or pushing the air out of a plastic milk carton type container are good ideas for storing deionized/distilled water.
- If a cooling system boils and has tap water in it, it is primarily these same compounds that leave crust on the inside.
- These elements removed from deionized or distilled water allow more current flow in tap water; conversely, since the water is in motion, tap water generates some current, which will tend to precipitate out impurities. This is part of the reason you put coolant in, to counteract this activity. There is less concern, therefore with corrosion from deionized water, without antifreeze (not suggesting going without).
- 50/50 mix takes boiling point from water (212) to mix (223). I didn't reseach calculations, but it is generally accepted that water will pull away WAY more heat than coolant. If you want a bunch of facts on this check out Redline water wetter spec pdf. (I'm not a redline fan overall, but this stuff looks good and lots of facts on this sheet - like that in some situations, water only can freeze with AC use in warm temps).
ADS
Old Mon, Jun-19-2017, 05:51:44 PM   #33
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
A few months ago, replaced the coolant with 5 qts of distilled water, 5 qts of factory coolant, installed ActiveAutowerk's sport fan clutch and a new BMW fan. Drove to Reno this past Friday. It was 105+ deg in Sacramento and about 110 deg driving through Placerville on Hwy 80. Had the AC on the whole time. No problems at all; the temp. gauge needle never went past 12:00 o'clock position. For clarification, I had a new genuine BMW radiator installed some years ago, and it's holding up fine; strangely enough, this new radiator cools better than the one the factory installed. Phew!
Jump to top Speed Monkey is offline   Reply With Quote
Old Mon, Jun-19-2017, 05:55:19 PM   #34
Good
@GOOD_M3
Good's Avatar
Check your water pump, make sure it is not leaking. I have the same issue, I'm swapping it out this weekend.
Exhaust: Active Autowerke Headers, Euro Section 1, Statusgruppe Resonated X-pipe Section 2, Supersprint Sport Section 3
Suspension: Polyurethane FCAB, ST XTA Coilovers
Other Mods: B-Spec Tune, Mishimoto Electric Fan, Macht Schnell Elbow/filter, Xtrons Headunit.
Major Maintenance: WPC Rod Bearings, Cooling System Refresh, Subframe Bushings & Reinforcement, Differential rebuild, Beisan solenoid.
Old Tue, Jun-20-2017, 10:00:42 AM   #35
silaciM3CS
Reputation: 0 silaciM3CS is on a distinguished road
This topic emerges every summer. 3/4 is not overheating nor abnormal, especially when going uphill.
Check the manual, normal operating range is between blue and red, and 3/4 is 100C
Still, there are many who never see above 1/2, but they also never changed the upper water temp sensor which can read lower over time. A friend of mine was in this category, never went above 1/2. We tapped another sensor and sure enough his temps were actually higher. He changed his temp sensor and now his needle does go above 1/2 when going uphill.
Jump to top silaciM3CS is online now   Reply With Quote
Old Tue, Jun-20-2017, 12:57:24 PM   #36
I'm sorry, but this is just not correct. I've had three e46 M3s, two from brand new, two of which were tracked. It is not "overheating" (engine damage), but it is abnormal and indicative of a cooling system that is not functioning properly. I've never seen any of them hit the 3/4 mark in any condition.
Including driving through the desert in the summer. Including on track.
(both of which I've done with them)
Old Tue, Jun-20-2017, 03:22:36 PM   #37
E46Hoonigan
Reputation: 0 E46Hoonigan is on a distinguished road
How does 20 coolant/80 water in Georgia sound? Rarely goes below freezing here.
Jump to top E46Hoonigan is offline   Reply With Quote
Old Tue, Jun-20-2017, 03:31:12 PM   #38
I wouldn't run anything other than 50/50 outside of a dedicated race car with insufficient cooling system capacity.
Old Wed, Jun-21-2017, 01:55:12 AM   #39
///M3 NA
Reputation: 0 ///M3 NA is on a distinguished road
If it's over heating in motion, the rad's the problem (assuming you got an OE water pump/thermostat).
If it's overheating at rest, you need a new fan clutch and/or aux fan (start with fan clutch).
This is probably partially true, my rad is fine but was overheating in motion. After fan clutches replaced, no more overheating.
Evolve
Evolve Eventuri
AutoSolutions SSK 30%
RE Transmission Mounts
CDV Delete
Intravee II
Jump to top ///M3 NA is offline   Reply With Quote
Old Wed, Jun-21-2017, 04:19:46 AM   #40
silvergray545
silvergray545's Avatar
This is my same issue. Overheating on track. Everything is new except fan clutch (didn't change due to possibility of doing the electric conversion), wondering if new fan clutch will solve the problem.
2004 BMW M3 6MT - TiAg/Gray
B&B TriFlow Section 3 | AP V2 headers | TMS Power Pulleys | aFe Drop In Dry Filter | Macht Schnell Intake Elbow | TTFS Tune | CSF Radiator & Oil Cooler | AST 4200 Coilovers | Ground Control Race Camber Plates & RSMs | TMS Rear Camber Arms | Hotchkis Front Sway Bar | Stoptech ST40 Front & Rear BBK | UUC EVO3 SSK with DSSR | ZHP Knob | Orion V4 | Matte Black Kidney/Side Grills | 35% Tint | Apex 75mm Wheel Studs | H&R Trak+ 10mm Spacers | 19" VMR CSL Reps | 245/275 Continental ExtremeContact DW
Track Stuff: Apex ARC-8s 18x10 ET25 | 275/35/18 Nitto NT01s | Schroth Quick Fits | PFC 08s
TCK D/A | Lightwerkz Projector Headlights | LeatherZ Interior Bits | BMW Performance Knob | OEM Square 17x9 Roadstars
2016 BMW M3 ZCP 6MT - AW/SO
Color Matched Front Reflectors | Lightweight Front Lip | M Performance Rear Spoiler | Black 666Ms
Instagram
E46 M3 Build Journal
coolant, temperature
Discussing Running hot in higher temp climates in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
